Project Snow Coyote - 1964 Fairlane 500 Coyote Swap - Take 2 - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Fire your bullets!!! > Build Threads > Ford Builds
Ford Builds Share your Ford Builds in this section.
Old 07-05-2017, 07:03 PM   #1
SnowCoyote
Pre-Staged
SnowCoyote's Avatar
Garage
Default Project Snow Coyote - 1964 Fairlane 500 Coyote Swap - Take 2
***So Photobucket decided to hold everyone's photos hostage for third party links, so the old build thread has been killed. (Old Thread Here) I moved the photos to Amazon and will be hosting through them. I'm recreating the build here so people actually see the photos.***
Introducing Project Snow Coyote - a 1964 Ford Fairlane 500 Hardtop Coyote swap. It started as a basic stock Fairlane with a small block 289 and a C4 with some minor modifications to the top end of the block. I had previously done some work in adding subframe connectors, replacing floor pans, sealing interior, new carpet, adding stereo, front disc brakes, etc. The C4 kept on giving me grief with a persistent leak despite two rebuilds. A plan for replacing the C4 turned into replacing the transmission, engine, front suspension, rear suspension, exhaust, brakes, etc. Basically the entire drivetrain and then some. The idea was to keep it fairly stock looking, however, with a little bit of stance to it.
99%+ of the fabrication and build work is being performed by CHE Performance in Girard, PA. Great shop and owner. Highly recommended. Tuning and swap advice from Powerhouse Automotive. Body and paint by Conneaut Collision.
Here is a summary of changes:
Custom CHE Independent Front Suspension
Tubular Upper and Lower A-arms
Fabricated Front Crossmember
Tubular Shock Tower Brace
Tubular Subframe Connectors
Rack and Pinion Steering
Coilover Shocks
Custom CHE Rear Suspension
Tubular Torque arm
Double Adjustable Lowers
Watts Link
Sway Bar
Coilover Shocks
2 Mini-Tub
Drivetrain
5.0L 4V Coyote Crate Engine
Tremec TKO 5-Speed Transmission
Custom Dual Air Inlet
Custom Aluminum Fuel Tank
Stainless Steel Fuel Lines
Aluminum Radiator
Custom 2-Fan Shroud
Modified Engine Cover
4 Aluminum Driveshaft
Moser Fab-9 Axle
Hydraulic Clutch
Brakes
Wilwood 4-Piston Front and Rear Calipers
Drilled/Slotted Rotors
Wilwood Master Cylinder
Custom Stainless Brake Lines
Exhaust
Modified, Ceramic Coated Headers
Custom CHE Stainless Exhaust
Custom CHE X-Pipe
Borla Pro-XS Mufflers
Interior
CHE 4-Point Harness Bar
Vintage Air Magnum A/C Unit
Custom Underdash A/C Vent Panel
Custom A/C Control Panel
Speedhut Gauges and Shift Light
Wiring by CHE Performance
Paint and Body
Wimbledon White Single Stage
Body and Paint by Conneaut Collision
Suspension Powder Coated by CHE
A couple more things that I can't think of right now...?
Where we started:
A finished product pic. It may look like not a ton has changed - wheel and tire package and stance. As you'll see in this thread, a ton changed. That's why Chuck at CHE calls it the plain white wrapper.
It's gonna take me a while to recreate this, so bear with me...
SnowCoyote is offline   Reply With Quote
Old 07-05-2017, 07:39 PM   #2
superd54
superd54's Avatar
Default Re: Project Snow Coyote - 1964 Fairlane 500 Coyote Swap - Take 2
What a difference the wheels make
I hear a Blower Car!
superd54 is offline   Reply With Quote
Old 07-05-2017, 08:32 PM   #3
67jjkk
67jjkk's Avatar
Nice looking ride
0 Fucks Givin
67jjkk is offline   Reply With Quote
Old 07-05-2017, 09:18 PM   #4
SnowCoyote
Pre-Staged
SnowCoyote's Avatar
Garage
More of what we started with:
289:
The thing that started this whole build, the C4:
Pretty good stock interior:
Some underbody shots:
Old 07-05-2017, 09:56 PM   #5
SnowCoyote
Pre-Staged
SnowCoyote's Avatar
Garage
Back in 2012, before CHE got a hold of it, my brother and I had redone the interior. Here's a brief tour of that project:
Stripped the interior:
Replaced some floor pans:
Added some subframe connectors:
Sealed it up with some KBS Rust Seal:
and put in some new carpet:
Old 07-05-2017, 10:06 PM   #6
Bigswede
Member
Pullin gears
Sweet ride!
Bigswede is online now   Reply With Quote
Old 07-05-2017, 10:07 PM   #7
SnowCoyote
Pre-Staged
SnowCoyote's Avatar
Garage
Weight prior to major changes:
Old 07-05-2017, 10:15 PM   #8
SnowCoyote
Pre-Staged
SnowCoyote's Avatar
Garage
Teardown time:
Front clip off:
Motor out:
Cut out the shock towers:
Entire drivetrain out, blasted, primed, then off to CHE Performance:
Old 07-05-2017, 10:45 PM   #9
chriscrna
chriscrna's Avatar
How did you host through amazon. I moved pics over and copied the links but no pics is coming up for me
chriscrna is offline   Reply With Quote
Old 07-05-2017, 11:44 PM   #10
SnowCoyote
Pre-Staged
SnowCoyote's Avatar
Garage
Default
Quote:
You have to click on the pic in amazon photos so that it enlarges, then right click on the pic and "copy image address". Use that link in your post.
Old 07-06-2017, 07:38 AM   #11
SnowCoyote
Pre-Staged
SnowCoyote's Avatar
Garage
Mini-tub time. Went from 235s to 295s.
Old 07-06-2017, 07:52 AM   #12
SnowCoyote
Pre-Staged
SnowCoyote's Avatar
Garage
Now for the good stuff. CHE Performance designed a custom Coyote crossmember for the Fairlane, which they are turning into a IFS Kit for the 62-65 Fairlanes. There are also plans to make a kit for first generation Mustangs.
Old 12-05-2017, 04:31 PM   #13
myfast70
Launchin
SO how do we see all of your build pics?
myfast70 is offline   Reply With Quote
Old 12-16-2017, 09:54 AM   #14
66SatBB
66SatBB's Avatar
Quote:
her is the link great build
https://www.yellowbullet.com/forum/sh....php?t=2088065
66SatBB is offline   Reply With Quote
Old 12-16-2017, 08:17 PM   #15
Superduty63
Burnout box
Superduty63's Avatar
Snow Coyote/Fairlane belongs to my brother. I'll get a hold of him and have him reload the pics. I was able to drive the car this past summer... Freaking unreal. Chuck from CHE Performance knows how to do Coyote swaps!!
Superduty63 is offline   Reply With Quote
