why does no one build a BBF 460 - Yellow Bullet Forums
Old 05-01-2017, 08:25 PM   #1
89 FOX 351
Member
Pullin gears
89 FOX 351's Avatar
Default why does no one build a BBF 460
serious question. because i don't know dick about this stuff. i've always wanted to stuff a big block in a foxbody, and a 460 stroked out to make a gas guzzling street machine sounds fun and a bit different. why don't more people do it? not practical? not reliable?
89 FOX 351 is offline   Reply With Quote
Old 05-01-2017, 08:26 PM   #2
CompNut
Default Re: why does no one build a BBF 460
BBC is superior!
CompNut is offline   Reply With Quote
Old 05-01-2017, 08:39 PM   #3
Topfun99
Topfun99's Avatar
Location: Orlando, then Alamogordo, NM, Manchester, TN and back to Orlando!!!!
Weight - too heavy on the front end unless it's a tube-chassis car. And the size makes it difficult to get down low in a stock chassis.
Try not to take everything so literally. Just because someone suggests it's time to deal with the Elephant in the room doesn't mean you should break out the peanuts.
Thanks to:
HALTECH (Elite 2500 plus REM)
TRZ MOTORSPORTS
REAL STREET PERFORMANCE
FB PERFORMANCE
PTC
M/T Tires
Kris Starnes Racing
EMAIL - [email protected]
Topfun99 is online now   Reply With Quote
Old 05-01-2017, 08:40 PM   #4
underatree
underatree's Avatar
Bbf can be made to badass.The problem is that ford never built a performance 460.They were always torque motors for trucks and land barges.
So you pretty much have to change everything on and in the engine to get them to run good.
I have heard of people putting 460s in foxbodys.But your putting a heavy ass engine in a light car. ..
I haven't got much.But I got enough....
underatree is offline   Reply With Quote
Old 05-01-2017, 08:48 PM   #5
A sad fat dragon
A sad fat dragon's Avatar
Surely a Super Cobra Jet and 429 Boss is a performance big block?? Ok they're 429 but dimensionally they're the same.....unless you have the boss motor in which case the hemi heads make it a bit wider
Half arsedly posting shit......
A sad fat dragon is offline   Reply With Quote
Old 05-01-2017, 08:52 PM   #6
tmodlin
tmodlin's Avatar
I used to read on here a bunch. http://www.460ford.com/forum/
The 460 can be built to be a badass motor for sure.
tmodlin is offline   Reply With Quote
Old 05-01-2017, 08:53 PM   #7
Jn3fj
Don't listen to these responses. Nothing wrong with bbf unless you try to spray a lot of nitrous then it becomes a problem. Boost is good
Jn3fj is offline   Reply With Quote
Old 05-01-2017, 08:54 PM   #8
Erik-427
Quote:
Plenty of people do it and they only weigh about 15-20lbs more than a BBC.
Erik-427 is offline   Reply With Quote
Old 05-01-2017, 08:55 PM   #9
A sad fat dragon
Quote:
Why is nitrous an issue but boost isn't?
Old 05-01-2017, 08:55 PM   #10
Erik-427
That can be said for all factory motors.
Old 05-01-2017, 08:56 PM   #11
Mike Swann
Q(t)=ṁCpΔT
Mike Swann's Avatar
Garage
10" deck height. Get a late model aluminum head. Use a mopar rod and offset grind the crank; you can make 488 ci with a stock bore.
Easy 900-1000HP, and it isn't going to be any bigger or weigh more that an equivalent BBC with an iron block.
Fortuna audentes juvat
“The inherent vice of capitalism is the unequal sharing of blessings. The inherent virtue of Socialism is the equal sharing of miseries.” —Winston Churchill ....House of Commons, 22 October 1945.
Mike Swann is online now   Reply With Quote
Old 05-01-2017, 08:57 PM   #12
skinny chicken
skinny chicken's Avatar
I just don't think they have caught on. I've seen some big numbers from a simple set of heads.
Definitely doesn't have the cylinder head options every other engine does.
skinny chicken is offline   Reply With Quote
Old 05-01-2017, 08:58 PM   #13
Erik-427
Quote:
Nitrous hits like a cannon being slammed into by a truck.
Old 05-01-2017, 08:58 PM   #14
jimmylauri
Excellent source^
71 Nova. 632 conv.head. Smith Race Craft Round tube clip. Split mono's. Asassin bars. Drag radial. #1 THRILL BILLY
jimmylauri is offline   Reply With Quote
Old 05-01-2017, 08:58 PM   #15
Erik-427
Google is your friend.......hint.
