How much power per inch can you make with... - Yellow Bullet Forums
Old 08-11-2016, 02:48 PM   #1
George Bryce
George Bryce's Avatar
Default How much power per inch can you make with...
There are many good, talented and accomplished engine builder/designers on this forum. This is my "go to" place for good answers.
As title asks, how much power per cubic inch do you think could be made with a 2 cylinder, stay with me here, a 640 cubic inch "Pro Stock" version, BUT, the front two cylinders, only, no 8 cylinders helping, just two pistons.???
Right now we use two 5.127 bore pistons, 3.875 stroke, 2.75 intake valves, 2.00 exhaust valves, .600 lobes with 1.85 rocker ratio. 8.6 long pushrods.
We turn it 10,000 rpm. We run EFI. We are allowed one injector per cylinder.
We run it from 8,000 to 10,000 rpm.
I believe we can get to 400 HP, not there yet. But when we do get there, that will only be 2.5 HP per inch. I think it is because there is not much help to rotate the crank with only two cylinders firing. If the rotation load was shared by 8 cylinders, it could make a lot more per inch.
This NHRA two cylinder is 160 cubes.....if it was a V 8, it would be a 10,000 rpm 640 cubic inch engine. I would love to hear and see your ideas and comments....this will be a technical sharing forum please.
Thanks!!!!
"If it was easy, it would be in a box, for sale, on the shelf at Walmart."
"I know enough to know I dont know enough."
"My opinion on "engine design" rules are good for 5 days!"
George Bryce is offline   Reply With Quote
Old 08-11-2016, 03:08 PM   #2
E.R. Racing
E.R. Racing's Avatar
Default Re: How much power per inch can you make with...
Are you limited to 10,000? How much does your piston and rod combo weight? Do you have a common plenum or individual runners and throttle bodies?
E.R. Racing is offline   Reply With Quote
Old 08-11-2016, 03:49 PM   #3
George Bryce
Quote:
Great questions.
We can rev it till it blows.
Individual runners with 3.3 throttle bodies, like F1 cars
Old 08-11-2016, 04:22 PM   #4
E.R. Racing
Quote:
Originally Posted by George Bryce View Post
Great questions.
Would more RPM not produce an opportunity for more hp?
Old 08-11-2016, 04:36 PM   #5
BBF612
BBF612's Avatar
On Jon Kasse's web site they advertise his 820 Ford hemi as making 1900 plus hp at what rpm (?) and that's a little over 2.3 hp/cuin, so if you can source the parts to be able to run the same bore stroke as you are along with the same size valve sizes, 2.5hp/cuin is not out of the question. But with a smaller bore/valve size and longer stroke it would be harder to do so. Most of RM's larger standard type engines are around 2 hp/cuin, some a little more or little less.
4 times the cyl's friction start to add up fast at 10000 rpm.
BBF612 is offline   Reply With Quote
Old 08-11-2016, 04:38 PM   #6
George Bryce
Absolutely, we are trying to be able to turn it more.....we run over parts over 10200, so far.
We are addressing the weakest links everyday. But 65875 average piston speed at 10200 is hard on parts
With 600 gram pistons.....over 5 and an eight inches bore.
Old 08-11-2016, 04:50 PM   #7
225digger
time to go racing yet ?
225digger's Avatar
lol 5-1/8" bore ... great thread something i have always wondered myself .......
225digger is offline   Reply With Quote
Old 08-11-2016, 04:59 PM   #8
BBF612
BBF612's Avatar
This older 730 Hemi head nitrous build (no nitrous) made 2.2 hp/cuin at 8000 rpm.
http://www.maxracesoftwares.com/foru....php?f=5&t=246
Old 08-11-2016, 05:01 PM   #9
bottlefed1
bottlefed1's Avatar
George saw the prior post on the bottom end.
Are you guys required to run the pickle fork rod or is it just a function of the rule requiring the cylinders to be inline?
I am not an engineer/engine builder and this may be a stupid question but.... If the rule is the latter, has anyone ever tried run conventional rods with an offset to allow a one piece crank and to get rid of the pickle rod?
bottlefed1 is offline   Reply With Quote
Old 08-11-2016, 05:21 PM   #10
Bill Diehl
Bill Diehl's Avatar
That's a lot of bore to get a flame front to run across at 10,000 rpm
Plug location....I am sure you are central located
Fuel....am sure you are restricted to blend
___________________________
Bill Diehl is offline   Reply With Quote
Old 08-11-2016, 05:30 PM   #11
George Bryce
Yes Sunoco SR-18 by rules.
We run 2 plugs per cylinder.
We do have to run the Knife and Fork/ Male and female rod set up.
Because S&S thought it needed to be a version of the Harley engine, XLCH.
Harley team runs automotive side by side rods, I think.
Our engine is inline front to rear....
The new Victory engine that is up for approval is side by side, again I am told.
Old 08-11-2016, 06:31 PM   #12
Chris Uratchko
Moderator
Chris Uratchko's Avatar
600 grams seems unusually heavy.... To me.
Chris Uratchko is offline   Reply With Quote
Old 08-11-2016, 06:36 PM   #13
scott foxwell
scott foxwell's Avatar
Quote:
For 5-1/8" bore? I was thinking it was pretty light, and still stays together.
Induction Development Specialties
Retail/wholesale parts sales
Custom cams
423 391 7774
Acts 2:38, the perfect answer to the perfect question.
If God is your co-pilot, change seats!
scott foxwell is offline   Reply With Quote
Old 08-11-2016, 06:37 PM   #14
scott foxwell
If you had a firing order which you could build a scavenging ex system, how much more do you think it would help"?
Custom cams
423 391 7774
Old 08-11-2016, 06:58 PM   #15
CFMCNC
2 Cylinders,Very little power overlap,lots of time between firing cycles.Its pretty impressive what George has accomplished and his relentless pursuit to find more.Bill C.
Checkered Flag Machine & Ceralli Competition Engines
Racing engines and induction development
http://www.checkeredflagmachine.net/
CFMCNC is offline   Reply With Quote
