Anyone ever have a jesel belt "jump a couple teeth"??? - Yellow Bullet Forums
Old 11-15-2009, 03:16 PM   #1
Brady
Roll Tide!
Brady's Avatar
Default Anyone ever have a jesel belt "jump a couple teeth"???
Last month in testing we went a 4.84. All I did before 1st round of qualifying was move some timing retard in the 7531 box. 1st round of qualifying the car launched and then bucked a couple times and Tommy aborted the pass. After that pass we found 4 bent pushrods. We fixed that and the car still ran like shit. 60' went from 1.18 to 1.38.
We changed everything we could think of and the car just continued to run like shit.
We pulled it apart and found exhaust valve p/v contact. It wasn't there before, but it is there now. Also found it bent all exhaust valves and guides.
Anyway, I pulled the balancer off and found the dots on the jesel drive weren't aligned. It's off by two teeth. I know with 100% certainty that it wasn't like that before.
I don't know exactly how old the belt is, but we're obviously getting a new one.
I've never heard of a belt jumping, has anyone else experienced this and is there anything that can be done to prevent it?
It's a 632- EFI on Methanol with twin gear driven prochargers.
Brady is offline   Reply With Quote
Old 11-15-2009, 03:20 PM   #2
smallblockcamaro
smallblockcamaro's Avatar
Default Re: Anyone ever have a jesel belt "jump a couple teeth"???
that's a first. don't have any issues with my jesel. how much spring pressure are you running? it could have been an old stretched belt that did it
smallblockcamaro is offline   Reply With Quote
Old 11-15-2009, 04:22 PM   #3
Lightners
Lightners's Avatar
I have sheared the key, between the spider and the part that physicly bolts to the cam, that'll retard your timing in a hurry..
Rod Lightner
Lightners is offline   Reply With Quote
Old 11-15-2009, 04:49 PM   #4
ASH
mfi turbos rule
ASH's Avatar
yeeh,
i had a comp cams belt drive jump a few teeth..
i got a stone caught between the bottom gear and belt.
this is in an open car, sbc , 125 inch altered
all exhaust valves bent, not a good feeling
MFI fuel injection
http://www.quillenmotorsports.com/
ASH is offline   Reply With Quote
Old 11-15-2009, 04:52 PM   #5
Brady
Roll Tide!
Brady's Avatar
Springs are 400# on the seat. ~1100# open.
Old 11-15-2009, 04:58 PM   #6
ASH
mfi turbos rule
ASH's Avatar
also, check you cam bearings, and see if any has grabbed...
MFI fuel injection
Old 11-15-2009, 05:05 PM   #7
smallblockcamaro
belt could have lost tension due to the extremely high spring pressures and therefore jumped a couple teeth. just my .02
Old 11-15-2009, 05:58 PM   #8
SHAKEY
SHAKEY's Avatar
brady, did it ever kickback?? or try to run backwards?? or hydraulic itself.. after any type of backfire, kickback, or if you think you hydrauliced it, you must check or change the belt!! i know its a lesson learned now... but i know what you will check next time..
523 CID STOCK BLOCK BBF, TWIN TURBO, STREET RIDE!!
I SURVIVED DRAGWEEK 09
BIG STUFF 3 DEALER/ INSTALLER/TUNER
HOLLEY EFI DEALER/ INSTALLER/TUNER
FAST XFI TUNING
STS TURBO DEALER/INSTALLER
OWNER/OPERATOR OF MUSTANG 1750HD CHASSIS DYNO
SCT TUNING AND CHIP BURNING
HP TUNERS CUSTOM TUNING
www.schexnayderracing.com
SHAKEY is offline   Reply With Quote
Old 11-15-2009, 06:06 PM   #9
Mike Beck
EFI/N2O JUNKIE
Mike Beck's Avatar
What do you mean about running backwards?
Mike Beck is offline   Reply With Quote
Old 11-15-2009, 06:20 PM   #10
Brady
Roll Tide!
Brady's Avatar
Earl, of course it kicks back, backfires, hydraulics, and runs backwards all the time. You know who's tuning it
It does kick back occasionally when trying to start it in low ambient conditions. But nothing out of the ordinary under power. Maybe just an old belt??? I looked the belt over the best I could and didn't see where it was damaged- but something had to give??
Old 11-15-2009, 06:30 PM   #11
Bammer540
Member
Pullin gears
Bammer540's Avatar
Check the keyway in the upper pulley and also check the bolts that hold the outer ring gear on the upper pulley, I have seen those get loose and timming slip on the pulley and it look like the belt slipped.
Bammer540 is offline   Reply With Quote
Old 11-15-2009, 07:37 PM   #12
SHAKEY
SHAKEY's Avatar
hell, i dont remember working on it at all....
FAST XFI TUNING
Old 11-15-2009, 10:59 PM   #13
89CIG
Launchin
89CIG's Avatar
Isnt jesel making some new belts that are white?
89CIG is offline   Reply With Quote
Old 11-16-2009, 07:06 AM   #14
another69camaro
another69camaro's Avatar
that upper key way is so small i could see that letting go.they should make it a double key way.
1969 camaro. tube chassis pro street car. 540 W/ TBS 871.
HD 09 vrod muscle. Blacked out and lowered. Stage 2 cams. Vreeland cnc ported heads etc 146 rwhp.
Sold 69 camaro
functional glass windows/lights etc
598
fogger and real street plate
single carb/conv heads
25.2
3150lbs
[email protected]
Sold 2003 svt cobra terminator street car
whippled @19psi
624rwhp.
another69camaro is offline   Reply With Quote
Old 11-16-2009, 07:33 AM   #15
excelerater
Senior Frog
excelerater's Avatar
On a normal heavy nitrous application they say the belts are done at around 100 runs....
In a Orange Crush tuned monster that has to be a fraction of that LOL
excelerater is offline   Reply With Quote
