what gauge for aluminium turbo exhaust? - Yellow Bullet Forums
Old 10-30-2015, 03:44 AM   #1
tower_monkey
Member
Pullin gears
tower_monkey's Avatar
Default what gauge for aluminium turbo exhaust?
looking to change over to alum down pipe.
currently aluminized steel with a short muffler out the front bumper.
did a search with no help soooo.....
what gauge alum are you guys using?
this is on a S480, so it will be 5"
thanks for any help
tower_monkey is offline   Reply With Quote
Old 10-30-2015, 07:51 AM   #2
LS1NOVA
LS1NOVA's Avatar
Default Re: what gauge for aluminium turbo exhaust?
11gauge for the first two feet, 16 for the rest.
www.One-guys-garage.com
LS1NOVA is offline   Reply With Quote
Old 10-30-2015, 11:17 AM   #3
Brian Brown
Quote:
You can do this, but the exhaust will not last as long. I would just use 11g for the entire length. I've been down this road a few times, and it's just easier to bight the bullet and due it right the first time. We have plenty in stock if we can help.
Thanks,
Brian
601.218.3848
www.quicktimemotorsports.org
[email protected]
Dealer for Turbosmart, Chiseled Performance, ProTorque, JGS Precision Turbo, Big Stuff 3, Garrett Turbo, Billet Atomizer Injectors, Racecraft, Inc., MSD, SpeedWire Systems, Weldon Racing, SPD Exhaust, Neal Chance, Strange Engineering, Peterson Fluid Systems, RedHorse Performance, NLR Systems (AMS 1000), mandrel tubing, V-band Flanges,etc
Brian Brown is offline   Reply With Quote
Old 10-30-2015, 11:38 AM   #4
Shearer
Shearer's Avatar
Why not run .035 or .049 stainless? Will be nearly as light and hold up much better IMO.
And Brian speaks the Truth! If you go Aluminum. Go 11 gauge the entire way.
Borg Warner, Callies, DART, Davies Craig, Diamond Pistons, Earls, Forced Performance, Garrett, Holley, K1, Precision Turbo, Stainless Works, TiAL, Trick Flow, Turbosmart, Vibrant, Wiseco, Xona Rotor Turbos
Dealer inquiries are welcome
216-242-2909
www.shearerfabrications.com
[email protected]
Shearer is offline   Reply With Quote
Old 10-30-2015, 12:10 PM   #5
woodrow5.0
woodrow5.0's Avatar
i agree to run 11 gauge the entire way but i have plenty of both in stock if you need some help with some
racepartsolutions.com
if you cant race it or take it to bed,it ain't worth havin
woodrow5.0 is online now   Reply With Quote
Old 10-30-2015, 12:17 PM   #6
rgreule
rgreule's Avatar
I ran 11 the entire way. Havent ran it yet to see how it holds up though..
70 duster turbo street car
https://www.yellowbullet.com/forum/sh...6eb2c&t=932290
rgreule is offline   Reply With Quote
Old 10-30-2015, 12:17 PM   #7
hostile
hostile's Avatar
That thin wall large diameter tubing has to be pretty rare. SPD doesn't even stock thin wall straight 5 inch.
You can get 11 guage dirt cheap in 5 inch, and it cuts with a wood band saw without issues.
hostile is offline   Reply With Quote
Old 10-30-2015, 01:09 PM   #8
Shearer
Shearer's Avatar
Missed the 5" part. Not sure I've ever seen .035" 5"
216-242-2909
[email protected]
Old 10-30-2015, 01:34 PM   #9
Collinsautomotive
I have built street stuff with 11 guage, holds up great.
Henry Ford, on the stock market
Quote:
"As betting at the race ring adds neither strength nor speed to the horse, so the exchange of shares in the stock market adds no capital to business, no increase in the production and no purchasing power to the market."
Collinsautomotive is online now   Reply With Quote
Old 10-30-2015, 02:40 PM   #10
tt68camaro
Spooled up
Mine is 5" 16 gauge right off the turbo with an immediate 90. Been on there 2 years now with probably 500 miles a year on the street and 30-40 passes with no issues. It is ceramic coated I don't know if that helps but that's my personal experience.
tt68camaro is offline   Reply With Quote
Old 10-30-2015, 05:11 PM   #11
tower_monkey
Member
Pullin gears
thanks for the help guys. will most likley do the 11 gauge alum. the entire exhaust is only 2 feet long.
Old 10-30-2015, 05:16 PM   #12
LS1NOVA
LS1NOVA's Avatar
I forgot to add that if anyone does do 16 gauge aluminum don't try it with any bends. The tubing is too thin on the bends and will give out. I've got stainless until the trans area and then 16 gauge aluminum to the axle with Vibrant aluminum mufflers. Couple thousand street miles and 100 1/4 mile passes. Whole thing only weighs 14 lbs.
Old 10-30-2015, 05:31 PM   #13
tower_monkey
Member
Pullin gears
Quote:
did a search, didnt find any place with 5" .035 wall stainless. any idea where to look? or if its made?
thanks shearer
Old 10-30-2015, 05:39 PM   #14
tower_monkey
Member
Pullin gears
what about mandrel bends with the 16 gauge?
my current setup comes off the turbo about 6 inches, then 45* and then out the bumper. if a guy used a mandrel bent 45 would it be ok?
Old 10-30-2015, 06:08 PM   #15
TurboII
TurboII's Avatar
Garage
You definitely want to use 11ga bends. Even mandrel bends formed with plenty of lube stretch the outside radius just as much as it bends them. I have seen almost every 90* elbow I have cut to be more like 16ga on the outer side. This is why the other guy cautioned you about the 16ga bends. They don't stretch as much since they are easier to bend but they are still too thin to use anywhere near the turbo end of the system. For the OP's application there is almost no weight difference so the 11ga is the logical choice.
TurboII is online now   Reply With Quote
