Nova weight loss - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Stock Suspension - TRZ Motorsports
Old 06-19-2009, 02:30 AM   #1
71Hellride
Spooled up
71Hellride's Avatar
Default Nova weight loss
I've got a 71 nova and need some ideas on how to drop some weight off it. Current weight right now is 3570 with driver. It's got a 10.2 deck 598 in it. I've been thinking about replacing the stock a-arms and also going to a rack setup. Does anybody know how much weight that will save roughly? Everything is factory on the front end and has cal trac suspension in the back. I have a glass hood and bumpers and factory glass windows. Don't want to put anymore glass on it. Just wondering what you guys do to lighten them up. Trying to keep from buying a mustang. Thanks guys
71Hellride is offline   Reply With Quote
Old 06-19-2009, 01:50 PM   #2
nastynovaII
FAQU
nastynovaII's Avatar
Default Re: Nova weight loss
Hellride, I just went through all this months ago while it still snowing and nothing else to do. Here's a list of the things I took off and what my total weight savings were when done.
Replaced stock upper & lower control arms 47#
TRZ Upper & Lower control arms 21#
Total weight savings was 26#
Replaced OEM power steering box 29#
Stock manual steering box 19#
Total weight savings 10#
Replaced OEM Front Disc Brakes 69#
Aerospace Front Disc Brakes 29#
Total weight savings 40#
Replaced OEM rear drum brakes 40#
Aerospace Rear Disc Brakes 27#
Total weight savings 13#
By doing these things I took off a little more than 90# off the car.
Instead of using two bumper brackets on each side on the front bumper we used one on each side and it saved us another 5#'s which isn't a lot but it all starts adding up.
nastynovaII is offline   Reply With Quote
Old 06-19-2009, 01:54 PM   #3
Mills588
Mills588's Avatar
588ci - 72 Nova here... same deal. I have the TRZ upper and lower control arms and dbl adj. coilover shocks.. 40lbs off the nose. I have glass hood and decklid. Still have original bumpers, need to go fiberglass. I am going with some Wilwood front brakes shortly.. Im hearing another 40lbs just with these brakes! but we'll see... Bottom line, it's weight reduction... I have stock 72 Nova Discs up front and Wilwoods in the back. I am going to one battery in back (Odyssey PC1500), instead of two... and am going to remove the inner fender wells.. another 20 to 30lbs I'd imagine... Mine was heavier than yours,.. I also have wheelie bars on mine, which hopefully I will not need... another 30lbs or so... Im curious to hear what you get yours down to. Whatever you do - don't buy a Mustang!!! Ugh! lol. Take care.
N/A 8.77 ET @ 153.4 * 1.26 - 60'
Power & Parts by DG Machine!
3410lbs & Leaf Sprung!
EMAIL @ [email protected]
Smith Bros, ATI PROCHARGERS, AFR, Dart, Brodix, CFE & BMF, Profiler, Manley, Callies, Erson, JE, Ross, Wiseco, Ferrea, Moroso, Pro Systems, Comp Cams, Erson, Hughes Performance, Trans- Specialties Full Line, ISKY, Strange Engineering Entire Line, TRZ Suspension Components, Smith Racecraft!.. and more!
Mills588 is offline   Reply With Quote
Old 06-19-2009, 02:26 PM   #4
nastynovaII
FAQU
Quote:
It's true!
Old 06-19-2009, 04:43 PM   #5
71Hellride
Spooled up
71Hellride's Avatar
Thanks guys. I plan on putting a rack on it first to help out with steering. Does anyone know if this saves any weight? Oh and I hate to buy a mustang but that's all we ever race against and those guys are light. It started out as just a small block street car and we just kept making if faster. And the weight just kept coming up as well. Once again thanks guys.
Old 06-19-2009, 05:08 PM   #6
genie
Pre-Staged
Smile Re: Nova weight loss
my blown 383 72SS is 2872# fueled with me in it
I have Dave Lemmonds rack ,control arms and A arms all lexan and glass one piece front end.
genie is offline   Reply With Quote
Old 06-19-2009, 08:59 PM   #7
the eightball
Launchin
how much does the driver way.?
the eightball is offline   Reply With Quote
Old 06-20-2009, 02:08 AM   #8
Green&Silver95
Green&Silver95's Avatar
my dads 74 nova weighs 3150 with 200 pound driver. glass hood, bumpers, ladder bars, 30 x 10.5. 9'' with huge ass drums, aluminum headed 468 big block, glide, all factory glass. 12 point mild steel cage, mini tubed and still has all the shit for the deck lid to hinge and stay up.
Green&Silver95 is offline   Reply With Quote
Old 06-20-2009, 02:11 AM   #9
Green&Silver95
forgot it dont have a rack and is not back half or front half
Old 06-20-2009, 08:35 AM   #10
Slow 69 SS
Slow 69 SS's Avatar
I have pretty much done all of the lightening mentioned above. Beyond the fiberglass hood and bumpers, I have removed the door regulators and glass, and have Lexan installed. Also, the door framing has been shaved off and I have aluminum skins to hold what is left off the door together. Both door reworks were worth 38lbs total.
The trunk bracking was all cut out, and I used some 1/2" light gauge square tube to brace from the corners to where the lock goes, this eliminated 12 lbs.
With a factory block 406 and a glide I was 3075 lbs with driver. I now have a Dart block and TH400, and tip the scales at 3280lbs with driver.
Dave
Ignorance can be fixed, but Stupidity lasts forever!
__________
If government were the answer to our problems, we would have no problems.
Slow 69 SS is offline   Reply With Quote
Old 06-20-2009, 09:07 AM   #11
HAYWIRE
Burnout box
My buddy tells me the easiest way and cheapest way to lighten up the hotrod is to quit eating at Mcdonalds and cut out the beer as well......with friends like that enemies not required lol....Lorne
Im not drunk....I can still opperize a motorated vehicle....
HAYWIRE is offline   Reply With Quote
Old 06-20-2009, 12:41 PM   #12
71Hellride
Spooled up
71Hellride's Avatar
The class rules I race wont allow lexan. It also requires door to be stock, with the windows working. Two years ago with ladder bars and a 477 bbc it weighed 3370 w driver. Only thing changed was stock suspension and the 598. So that picked me up 200 lbs. I don't really want to gut it out i just need to lose 100 lbs or so. Oh and the driver weighs 190. Maybe I need to find a horse jockey that can cut a light lol.
Old 06-20-2009, 06:44 PM   #13
NOVALOU
Member
Pullin gears
NOVALOU's Avatar
Is your cage chrome molly? If not, that maybe something to consider.
NOVALOU is offline   Reply With Quote
Old 06-20-2009, 07:29 PM   #14
71Hellride
Spooled up
71Hellride's Avatar
Quote:
No its mild steel 10-point. Any idea what a chromoly 8.50 with funnycar cage weighs?
Old 06-20-2009, 11:27 PM   #15
Elowe65
Spooled up
Elowe65's Avatar
take out the factory dash (complete side to side) and replace with a fiberglass replica.
Elowe65 is offline   Reply With Quote
