376" LS3 build... kind of surprised me - Yellow Bullet Forums
Old 02-12-2015, 11:12 PM   #1
E.R. Racing
E.R. Racing's Avatar
Default 376" LS3 build... kind of surprised me
Over the past several months I've been working in my spare time putting together an LS3 out of mostly spare parts. Basically seeing what I could do on a budget. Used a stock block, stock crank, used rods, small dome piston, stock casting heads, and 455 lobe nitrous grind cam. Ported on the heads off and on when I had time, and bought some used titanium valves off ebay and cut & regrooved them. Had some used stud mount rocker arms that I fit to the heads (which took an unnecessary about of machining to make fit) and made some stud girdles. Bought a used super victor manifold that I hacked up and ground holes all in (splash zone to the rescue). In the end, I was more than happy with the results. My goal was 700hp peak at 8000rpm. I was pleasantly surprised when I surpassed that by almost 100hp. Ended up making 790hp @8400 and 554tq @ 6400. Started having some high rpm oil pressure issues so I cut the session short. Gonna change some stuff and shoot for 820hp next go-around. I think it's attainable with some work.
Posted a vid in the dyno sticky but here it is again. It's one of the first pulls we made. Didn't get any of the good ones
E.R. Racing is offline   Reply With Quote
Old 02-12-2015, 11:28 PM   #2
69chicken
69chicken's Avatar
Default Re: 376" LS3 build... kind of surprised me
Congrats! It sounds good!
69chicken is offline   Reply With Quote
Old 02-13-2015, 03:11 AM   #3
PuRpS
FUCK TONS OF FUN
PuRpS's Avatar
Garage
2.1 per cube is a lot
How much comp and what fuel
The #2 Dart Fan boy
PuRpS is offline   Reply With Quote
Old 02-13-2015, 04:53 AM   #4
Graphic Man
Wild Addiction
Graphic Man's Avatar
Very Nice !!
Graphic Man is offline   Reply With Quote
Old 02-13-2015, 06:44 AM   #5
T-flow
T-flow's Avatar
Nice! What are the cam spec's? (if you cont mind)
I have been thinking of doing the same with a bunch of spare stuff here at the shop. Just never get time....
T-flow cylinder heads
www.tflowheads.com
T-flow is offline   Reply With Quote
Old 02-13-2015, 07:28 AM   #6
E.R. Racing
12.5-1 compression, 455 lobes, 272/288 @ .050"
Old 02-13-2015, 08:53 AM   #7
CFMCNC
Nice E.R. !!!! This is a great example of what some forward thinking can do! Well thought out and executed and a simple parts roster. Love the high winders...nice job! Johnny
Checkered Flag Machine & Ceralli Competition Engines
Racing engines and induction development
http://www.checkeredflagmachine.net/
CFMCNC is offline   Reply With Quote
Old 02-13-2015, 09:04 AM   #8
DBN
Member
Pullin gears
DBN's Avatar
Very impressive.
DBN is offline   Reply With Quote
Old 02-13-2015, 09:19 AM   #9
67shoebox
67shoebox's Avatar
WOW image with air pump
67shoebox is offline   Reply With Quote
Old 02-13-2015, 12:45 PM   #10
turboluv
Launchin
turboluv's Avatar
I call bull crap on that one right there ER! O wait I was there , never mind. LOL
turboluv is offline   Reply With Quote
Old 02-13-2015, 12:57 PM   #11
Jumpcannon
Launchin
Jumpcannon's Avatar
Garage
Badass!
Jumpcannon is offline   Reply With Quote
Old 02-13-2015, 04:58 PM   #12
PuRpS
FUCK TONS OF FUN
PuRpS's Avatar
Garage
All the money we have spent. Should have just build one of. These
Bet it sounded pretty on the dyno
The #2 Dart Fan boy
Old 02-13-2015, 06:05 PM   #13
fatman
what makes that a nitrous grind cam?
What would an NA cam do for it?
fatman is offline   Reply With Quote
Old 02-13-2015, 06:23 PM   #14
E.R. Racing
Valve events are different. If I was to change cams, I would take a little duration out of it, and change the valve events. It's peaking a little higher than I wanted. Not sure what that would do... hopefully help it but who knows.
Old 02-13-2015, 07:00 PM   #15
fatman
Thanks. Can you share some details on the heads? Valve sizes, area, flow, whatever?
What size headers were used?
