And this is why we leave the closed loop enabled w/ Holley EFI - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Electrical
Old 08-13-2014, 10:22 PM   #1
LosLS2
LosLS2's Avatar
Default And this is why we leave the closed loop enabled w/ Holley EFI
So I got this buddy Jeremy that guess by Heavychevy on the forums. He's got a pretty badass Silverado Crew Cab with a 408ish cube motor and a 94mm turbo on E85. So he's racing this CTS-V with a 150-175 shot. Here's the video. CTS-V gets the hit.
Looks like a nice clean pull. With the scramble and everything, that's about 1200 rwhp at like 4500 lbs. Well, what you can't see is that at about 1.5 secs into the run his fuel pressure went from 70 psi to 42-43 psi within the next .75 seconds (pink line). As this is happening, you can see the Holley spring into action with the closed loop correction (green dashes) and the injector duty cycle follow along with it (maroon line). He's not yet sure what happened but I suspect that the diaphragm in the boost reference fuel pressure regulator broke.
This is the 4th vehicle in our crew that has lived thru a 1000+ rwhp pump issue or failure in a multipump setup.
Have faith gentlemen. The shit works!
Independent Holley EFI Instructor
www.facebook.com/holleyefitutor
LosLS2 is offline   Reply With Quote
Old 08-13-2014, 10:27 PM   #2
Loudmouth LS1
Member
Pullin gears
Default Re: And this is why we leave the closed loop enabled w/ Holley EFI
Badass! Heavy's truck has really come a long way!
-Devon
White '99 Z28
Loudmouth LS1 is offline   Reply With Quote
Old 08-13-2014, 10:55 PM   #3
Mike Beck
EFI/N2O JUNKIE
Mike Beck's Avatar
Yes, their wideband does work great. I would also advise to setup some internal safeties.
Mike Beck is offline   Reply With Quote
Old 08-13-2014, 11:16 PM   #4
LosLS2
LosLS2's Avatar
Yeah, I was thinking that maybe a 150% duty cycle spike should light a bulb or pull all the timing or something. I don't know that I want it to activate at 100% (maximum value the Holley will allow me to input as a trigger). I hate false positives and would hate for someone to lose because of one.
Old 08-13-2014, 11:18 PM   #5
heavychevy01
Burnout box
Garage
Quote:
Then I might have lost the race. I'm just kidding. I am going to turn on some of the safties back on. And find the fueling issue. This is second time the holley saved my motor. First time was similar, but was do to alternator failing during pass and massive loss of voltage.
heavychevy01 is offline   Reply With Quote
Old 08-13-2014, 11:20 PM   #6
Rebird
Rebird's Avatar
wow, that is very cool!! Holley rules!
Rebird is offline   Reply With Quote
Old 08-14-2014, 03:26 PM   #7
Smoove
Burnout box
Smoove's Avatar
Garage
badass
Smoove is offline   Reply With Quote
Old 08-14-2014, 03:50 PM   #8
440roadrunner
440roadrunner's Avatar
DAMN. As a Novice running HP on a mild street engine, this is very encouraging. Makes all that money seem a little more "useful."
440roadrunner is offline   Reply With Quote
Old 08-14-2014, 04:06 PM   #9
turbo6man
Member
Pullin gears
turbo6man's Avatar
Quote:
Me to, I lost my alternator on a race against an f1 motorcycle. Car ran perfect but during the race the innovate wideband had an error and as we slowed down the lights were dull. Reviewed the data log and injector duty cycle went form the normal 70% range to 125% due to low voltage/fuel pump pressure. Holley Wideband control FTW!!!!!!
1963 chevyII: 410" dart ls built by modern speed and TFS Frankenstein cathedral heads. Billet atomizer 225 inj 1/2" fuel line(3/8's return) with dual Magnafuel 750 pumps E85 GTX5533-91 turbo Liquid intercooler 5" exh. Four link and ford 9" with 3.25 gear ratio and mini tub with 28X10.50-15 radial drag slicks Checkered racing front clip with Alston coil overs. best time 5.0/[email protected]/173 MPH with 30psi boost ramped in and 1.26 60'
turbo6man is offline   Reply With Quote
Old 08-15-2014, 09:25 AM   #10
AutomagicLS1
Launchin
damn dat duty cycle!
1998 Camaro SS - FR8Train 2.0
408 lsx, single turbo, Holley EFI,
www.facebook.com/thefr8train
AutomagicLS1 is offline   Reply With Quote
Old 08-15-2014, 07:36 PM   #11
LosLS2
LosLS2's Avatar
"Givin' ya all she's got Capt'n! "
Old 08-15-2014, 08:48 PM   #12
ysi363
Pre-Staged
ysi363's Avatar
That's awesome my Holley did the same thing in my race car. Car went 150% duty cycle and the Holley added 70lbs and hr to my setup. Found out mine was my weldon 2025 was down 50 gallons an hr and diaphragm in my regulator broke also so had them upgraded while out. Everything since has been perfect glad your motor is ok
Ed Thomas Performance Engines
Dart block small block Ysi power
Ultra street #1716
ysi363 is offline   Reply With Quote
Old 08-16-2014, 12:10 AM   #13
S2H
S2H's Avatar
Garage
Make a safety output based on sensors...
then (even if you are not using it) add the boost config
then you can use the "Boost safety" and trigger it by the output you set up as a "safety output"
you can then set it to kick on the "Boost safety" if its triggered for more than a specified amount of time (1 second, 2 seconds)
this way you can filter out transient spikes set in the safety output...which can also light a bulb at the same time so you get a visual and it will cut the ignition if it comes on for more than the time specified.
-Scott
Dont forget to Check out Progress on my RaceCar
Project Blasphemy [email protected]
Low 8 Second Street Car...
S2H is offline   Reply With Quote
Old 09-30-2014, 12:41 AM   #14
ysitrim88
Member
Pullin gears
ysitrim88's Avatar
Doesnt FAST XFI 2.0 does the same thing? i run mine in closed loop with 25% positive correction which is the max.
1988 mustang gt dart block 331 ysi supercharged 8.75 @ 158.56
Tuned by Kurgan Motorsports
Linear Fabrication
ysitrim88 is offline   Reply With Quote
Old 09-30-2014, 04:16 AM   #15
Danny Cabral
Danny Cabral's Avatar
Quote:
Originally Posted by ysitrim88 View Post
...with 25% positive correction, which is the max.
Then it's not the same thing. Also, Holley ECUs have a very fast processor speed.
May God's Grace Bless You
New Holley Dominator ECU for sale every month. (Email me for my usual low price: d c f 1 5 0 @ c o m c a s t . n e t)
Danny Cabral is offline   Reply With Quote
