Ford rear main seals - Yellow Bullet Forums
Old 10-21-2019, 05:05 AM   #1
AA Performance
Default Ford rear main seals
Can some one tell me the difference between the felpro 2921 and the 2942. When should each one be used? The only difference is the ID of the seal and that's around .010" Surely they can be interchanged?
AA Performance is offline   Reply With Quote
Old 10-25-2019, 12:17 AM   #2
WoundUp
WoundUp's Avatar
Default Re: Ford rear main seals
I believe there's a difference in rubber compound, one being stiffer than the other. One is flouroelastomer aka FKM(2921) and the other is made from Polytetrafluoroethylene aka PTFE(2942)
WoundUp is offline   Reply With Quote
Old 10-25-2019, 07:33 AM   #3
AA Performance
Thanks for that, just couldn't work out the difference and wasn't sure why they made the two.
Old 10-28-2019, 12:13 AM   #4
WoundUp
WoundUp's Avatar
This may be of interest. It explains the differences between the 2 and which environment each type is best for. One seems to be better for sealing against chemicals and one is better for higher temps.
https://www.tritec-ps.com/ptfe-vs-elastomer/
https://trp.co.uk/fkm-rubber-vs-ptfe/
