Plug cap closed up - Yellow Bullet Forums
Old 06-14-2019, 01:04 PM   #1
rob71458
Default Plug cap closed up
Don't hate on me but, My nephew runs a turbo charged Honda LSV in a 1992 Hatchback. He's running 17 psi boost with 10.3 cr. on pump gas. Car has run a best of 11.3 @123. He made two runs the other night. First run there was a sputter/backfire in the top of third gear.Continued to pull strong in fourth. Did an 11.7 time. Second run was even better, with no missfire. Did a 11.5 time. Some oil puke out of the catch can, but he hadn't drained it five runs. It holds about 16 oz. He checked the plugs and all the gaps were very tight. Compression is even at 185 all 4. Runs fine. I suspect detonation? What do you guys think?
rob71458 is offline   Reply With Quote
Old 06-14-2019, 04:04 PM   #2
Screwblower
Default Re: Plug cap closed up
Run it.
If it gets faster then the motor is almost broke.
Loose is fast and then it lets go.
Screwblower is offline   Reply With Quote
Old Today, 02:42 AM   #3
Topfun99
Topfun99's Avatar
Location: Orlando, then Alamogordo, NM, Manchester, TN and back to Orlando!!!!
I think at that power level you should have some data-logging capability so you know where the AFR is and a damn good ignition system including wires.
Missing is not unusual but when boosted engines backfire that is NOT good.
IMO detonation will not show up as missing or backfire. On a boosted engine it will show up on the plugs. It doesn't take much detonation at all to see aluminum or electrode damage.
According to the APA, Yellow Bullet currently has the highest ratio of Paraphiliac forum members on the internet. Makes a fellow member proud.
HALTECH (Elite 2500 plus REM)
TRZ MOTORSPORTS
REAL STREET PERFORMANCE
FB PERFORMANCE
PTC
M/T Tires
Kris Starnes Racing
EMAIL - [email protected]
Topfun99 is offline   Reply With Quote
Old Today, 03:59 AM   #4
richie webb
richie webb's Avatar
If plug gaps are getting smaller/tighter? says to me rod bearings are gone and pistons are hitting plugs
Dreaming big
Europes 1st 7 second VW
PB [email protected] may 2015
Beetle Cabrio Race car [turbo]
Europe's quickest & fastest Aircooled VW
https://www.youtube.com/watch?v=cYGgrq_pPiw
Beetle Cabrio street car[turbo]
[email protected] mph
https://www.youtube.com/watch?v=TVtjQQcIoFg
Daily driver beetle saloon[nitrous EFI]
[email protected] September 2015
https://www.youtube.com/watch?v=p0-VKLRqT6Y
richie webb is offline   Reply With Quote
