Water Injection Issues - Page 3 - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Supercharged
Old 09-04-2019, 12:03 AM   #31
Hollow65
Hollow65's Avatar
Default Re: Water Injection Issues
Quote:
Originally Posted by Ron Clevenger View Post
When flowing the larger volumes you need two pumps. But I'm talking a 565 inch motor at 42 psi boost. You may need to reel in your goals with that blower.
That blower is spinning itís ass off and itís on a biggish engine. Bigger blower/less timing is what I would try. He likes his hood though which is understandable. Even a 6-71 would have to be overdriven pretty well to make any psi on a 440. Bigger blower, spin it slower, less heat.
At my worst, I'm at my best
Hollow65 is offline   Reply With Quote
Old 09-04-2019, 12:47 AM   #32
short1
Spooled up
Nitro in the tank. Snow used to sell a nitro additive, don't know why they discontinued it. He only needs another 50 HP to hit the 10's ?. Id be thinking of running model heli fuel in the tank
short1 is offline   Reply With Quote
Old 09-04-2019, 01:17 AM   #33
Hollow65
Hollow65's Avatar
Quote:
Can you still purchase toluene?
Old 09-04-2019, 01:50 AM   #34
70cuda
Launchin
70cuda's Avatar
It`s a SNOW kit,base model. Don`t have the model number in front of me.
Been messing with the w/meth for 2 years. Hasn`t helped even once in ET. or MPH.
I`ll keep chipping away at it. Not gonna just throw cash at it.
1st into 2nd on the street is a hoot. Strong.
3rd. it is pretty much spent.................. LOL
70cuda is offline   Reply With Quote
Old 09-04-2019, 05:20 AM   #35
Taff
Launchin
Taff's Avatar
Quote:
Yes, on ebay in 25litre drums, been using it for years. It won't make up for a small blower though, but you could probably add a bit more timing.
Taff is offline   Reply With Quote
Old 09-04-2019, 12:49 PM   #36
stevieturbo
Im running one 500ml nozzle on a centri charged 5.3L. 10 lbs boost. I can see the IAT drop is about 40C at least with the system on.
Check your actual output of the pump/nozzle setup.
Those are claims, I'd love to see some independent tests to verify as such.
If their pump can actually do that, either mine is fucked or shit. But I'm very reluctant to spend the money on a new pump, because I've seen no evidence to suggest any other pumps would be any better, as mine appears to work fine.
The problem is, nobody is actually verifying the output. I spent all day testing, with a couple of different nozzles, various pump duties, frequencies, and actually measuring flow each time spraying into a measuring jug.
Such an eye opener
But almost all of the pumps are based around the Aquatec DD5800. Who knows whether one is better than another, as nobody seems to do any testing. Each seller of each system claims theirs is the best, highest pressure, flows most etc etc. There are definitely some visual differences with the pumps though.
blow me
https://www.youtube.com/watch?v=Ss_c7fML3rw
What the f****
stevieturbo is offline   Reply With Quote
Old 09-04-2019, 11:12 PM   #37
Hollow65
Hollow65's Avatar
Heís a good 60í away from 10ís.
Old 09-07-2019, 08:23 PM   #38
Michael Plummer
Spooled up
Michael Plummer's Avatar
Quote:
Originally Posted by stevieturbo View Post
What system is it ?
I can only imagine those using larger nozzles, spray and pressure drop to shit in the vehicle.
Why more people arent logging meth line pressure is a mystery, it was an eye opener for me.
All these companies run their pumps with their smallest nozzle to get their psi rating. Increase nozzle size or add additional nozzles and pump pressure will decrease. Lower pump voltage also affects flow. Running an inline pressure gauge will show you the truth hence the reason why none of the water/methanol companies sell one.
1994 Mustang GT Procharger D1
852rwhp and 771rwtq SAE
Michael Plummer is offline   Reply With Quote
