Does my tuneup need to be adjusted when going from Renegade to VP - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Racing Fuels
Old 05-31-2019, 03:34 PM   #1
Bellman
Bellman's Avatar
Default Does my tuneup need to be adjusted when going from Renegade to VP
I've got my tune pretty much dialed in using Renegade 120+ race gas..
Now my supplier has changed from a Renegade dealer to a VP dealer.. So I just purchased a few cans of C16..
Will I need to change my fuel delivery to maintain the same A/F ratio ??
This is on a race only, max effort turbo setup..
Also.. Will I need to flush my fuel system of Renegade fuel, before switching to VP ??
86 Mustang GT
383 ci SBF
Garrett GTX5518r turbo
Close Ratio TH400 Tranny
Bellman is offline   Reply With Quote
Old 07-04-2019, 10:26 AM   #2
mike gerlach
mike gerlach's Avatar
Default Re: Does my tuneup need to be adjusted when going from Renegade to VP
Better read up on the VP lawsuit posted...
mike gerlach is offline   Reply With Quote
Old 07-04-2019, 05:52 PM   #3
nitrolx
nitrolx's Avatar
Quote:
C16 isn't oxygenated so isn't effected by the issues in the lawsuit.
nitrolx is offline   Reply With Quote
Old 07-04-2019, 09:46 PM   #4
nitrolx
nitrolx's Avatar
Haven't made that switch personally; but looking at the specs of both fuels; C16 will want to be a little richer (14.7 vs 15.0 stoich) so adding a bit of fuel certainly won't hurt. Bearing in mind boosted stuff is usually living on the richer side anyway. The C16 is a bit heavier; and has a pretty low RVP so you might find you need a little bit more ignition timing to get back to where you were on the Renegade.
JMO.
