what should the no prep rules be for small tire cars? - Page 2 - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Fire your bullets!!! > Grudge, No ET and No Prep Racing
Grudge, No ET and No Prep Racing Talk about Grudge and No ET racing. Trash talk is allowed. Use common sense when posting..
Old 11-16-2016, 10:17 AM   #16
chriscrna
chriscrna's Avatar
Default Re: what should the no prep rules be for small tire cars?
Do u think a 4 link has an advantage over a top of the line x275 rear suspension set up?
chriscrna is offline   Reply With Quote
Old 11-16-2016, 04:13 PM   #17
mustangmafia
Spooled up
mustangmafia's Avatar
This discussion is as bad as "What defines a street car?". People are always going to try and make the rules fit their car perfectly to where they are the fastest. The promoter makes the class rules and you will either put your car in a class that fits or you wont race lol. In turn promoters will modify the class rules over time to try and get the highest car count possible. I personally think it should be limited to tire size only. Either you're fast enough or you're not. This isn't suppose to be like class racing....
1989 25.3 Mustang Coupe
1999 Viper GTS
mustangmafia is offline   Reply With Quote
Old 11-16-2016, 09:13 PM   #18
HEMIROC
Quote:
Nope
HEMIROC is offline   Reply With Quote
Old 11-16-2016, 10:12 PM   #19
1969dart
1969dart's Avatar
Garage
Well a true backhalf should be able to run with the "stock suspension" cars. The full tube stuff should be limited to big tire.
agree^^^^^
recommendation:
stock firewall and floor back to "B" pillar or rear of cab for trucks
2x3 square tube back half or OEM frame (no chassis cars)
steel rear quarters and roof for cars and steel roof and bed sides for trucks (other then OEM glass or aluminum vehicles)
All the BS pro-mod top sportsman cars need to be put into another class--then they can decide if they want small or big tires themselves.
1995 S10 421 sb glide 4 link 33x18.5x15 street drive
1986 Mustang 5.0 / 5speed convertible 36K 2nd owner
1974 Nova Hatchback 383/ TH350/ 12 bolt 4:11
soon to be 4 speed car
Wanted 4 SPEED PEDAL ASSY Nova/Camaro will work.
1969 Dodge Dart 340 swinger
1969dart is offline   Reply With Quote
Old 11-17-2016, 12:34 AM   #20
z289sec
z289sec's Avatar
Actually, in my personal opinion, I would rather have my leaf spring setup on a no prep track than a 4 link.
RTCTTFMF!!!!
Stock suspension 67 Camaro
565 Conventional head BBC with fogger and a plate on 275's
Just about done
Thanks to:
Texas Racewerks, Sanger, Texas
Nyes Automotive Racing Engines, Muncie, Indiana
FTI Converters and Transmissions, Deland, Florida
ACE Racing Transmissions, Garland ,Texas
z289sec is offline   Reply With Quote
Old 11-17-2016, 07:16 AM   #21
chriscrna
chriscrna's Avatar
Quote:
Originally Posted by 1969dart View Post
agree^^^^^
recommendation:
Thee 2x3 back half is maybe 75 lbs tops and no advantage suspension wise so i would't care if it was round tube. If someone is building a round tube is like a moly cage. It sells faster and holds a b it more value.
Old 11-29-2016, 11:27 PM   #22
JL Performance
Stock front suspension stock front frame rails from motor plate back, stock firewall, stock floors to the back seat, no more than a 29.5 non W. Weight, rest of it run whatever, just have the needed safety shit for how fast your junk is.
JL Performance is offline   Reply With Quote
Old 11-30-2016, 08:37 PM   #23
chriscrna
chriscrna's Avatar
Quote:
That is pretty much what I think but the bolt in racecraft stuff for earl nova and Camara should go to.
Old 11-30-2016, 08:44 PM   #24
Shawn Finn
Member
Pullin gears
Shawn Finn's Avatar
Guys is there any place or site that has Grudge/NT shootout events posted for the year. Would like to do some of the no rules shootout style races this coming year
The Engine Shop
Farks Supercars
718 594 3003
[email protected]
562 DRCE1 Engine for sale
Dealers for: Ferrea, Mark Williams, Aeromotive, Procharger, Fueltech, PST.
Shawn Finn is offline   Reply With Quote
Old 11-30-2016, 11:20 PM   #25
chriscrna
chriscrna's Avatar
Old 11-30-2016, 11:23 PM   #26
chriscrna
chriscrna's Avatar
Quote:
None that I know of and I haven't heard of any rule changes. Pretty much a true 29.5 no wide others are max ture is a true 28.0 . Any suspension from the factory and a backhalf are legal for the small tire. Tube Frame is big tire only. Some of the back half are really 3/4 chassis.
Old 12-05-2016, 08:10 PM   #27
JL Performance
Yes I agree, but with a 50 lb weight penalty so no one is at any advantage of running that stuff.
Old 12-07-2016, 10:11 AM   #28
Gmr-Performance
Member
Pullin gears
Gmr-Performance's Avatar
Its tough really there are so many variables involved.. I get asked to the tail gate class.. well great but I have a huge curb weight compared to most . I do not dis connect swap bar etc.. I go but its a blow out as I am 1000 lbs heavier .. Hard to make that up in 660 feet.. Then you add the guy that is close to the weight but coil over .. Even true street gets outside of a fair race.. I know gut the truck set it up for racing but I really drive it 8000 + plus a year pump gas .. I want to be comfortable while driving as well .. Good luck on this one . It comes to opinions more so than anything ..
Gmr-Performance is offline   Reply With Quote
Old 12-12-2016, 01:58 PM   #29
dennish
dennish's Avatar
Yes, the N\T Racing group on FB. I'm trying to find the list someone posted, but you can keep up with all things grudge racing on there.
Dennis
dennish is offline   Reply With Quote
Old 12-18-2016, 12:14 PM   #30
THE STING
Quaker city dragway in Salem Ohio is going to have several 1/8 mile No Prep/No ET events in 17...
Schedule is not known yet as I was just notified about it this past Friday by my cousin (one of 3 organizers) for the event.
Had a trial run this past season with a decent car turnout....spectators where off the chart , the most I have ever seen there.
(aka AMC Boyz) Rob.
THE STING is offline   Reply With Quote
