what should the no prep rules be for small tire cars? - Page 3 - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Fire your bullets!!! > Grudge, No ET and No Prep Racing
Grudge, No ET and No Prep Racing Talk about Grudge and No ET racing. Trash talk is allowed. Use common sense when posting..
Old 12-20-2016, 11:48 AM   #31
Shawn Finn
Shawn Finn's Avatar
Default Re: what should the no prep rules be for small tire cars?
Thanks Dennis and Rob. I dont have facebook so might have to use the girlfriend for that one.
Salem Ohio actually isnt that bad of a drive for me, might not be able to do a 1 day event but if they had a 2 day thing it would definitely be something to try and make
The Engine Shop
Farks Supercars
718 594 3003
562 DRCE1 Engine for sale
Dealers for: Ferrea, Mark Williams, Aeromotive, Procharger, Fueltech, PST.
Shawn Finn is offline   Reply With Quote
Old 12-20-2016, 12:09 PM   #32
Speedracer61
Speedracer61's Avatar
This is definitely a conversation that is subjective to what a person runs. Where as the OP says the limit should be a 4 link back half small tire, there are many with frame rails all the way back, stock type suspensions and small tires that will argue otherwise. One might say a back half is back seat rearward, really what difference does it make running the chassis 4 more ft to the firewall? If the weight is the same and the suspension is the same, what does it matter? If people believe a good stock type suspension is as good as a 4 link then tire size and weight should equal the class, but it doesnt seem to work that way. Personally we have all of them covered as we have a true back half big tire car, a 3/4 back half big or small tire and a full frame small tire car. And where as I do think a good stock type suspension can work very well, the adjustability of a 4 link cant be beat.
Speedracer61 is offline   Reply With Quote
Old 12-20-2016, 11:26 PM   #33
badfarmtruck
they should have small tires.
badfarmtruck is offline   Reply With Quote
Old 12-20-2016, 11:36 PM   #34
JL Performance
You haven't seen my lower control arm brackets LOL.
JL Performance is offline   Reply With Quote
Old 12-24-2016, 02:12 PM   #35
4406
True back half should be permitted. Stock floor and suspension from B pillar forward. Tube chassis big tire only. IMHO
Ray
Misc Odd Parts Assembled Recklessly
4406 is offline   Reply With Quote
Old 12-25-2016, 12:02 PM   #36
THE STING
It is a 1 day event....I know 3 of the races will be on a Friday and 3 on Sunday..
But..... the 3 of the Friday grudge races will be followed by the DADs heads up series at Quaker....and the other 3 will follow the DADs heads up series..
So it is two different events ( 1 prepped 1 not) but on the same weekend..
The DADs event and rules are on the quaker city dragstrip website....the grudge event and rules I don't believe are posted yet.
(aka AMC Boyz) Rob.
THE STING is offline   Reply With Quote
Old 12-25-2016, 12:18 PM   #37
THE STING
Originally Posted by chriscrna View Post
Well a true backhalf should be able to run with the "stock suspension" cars. The full tube stuff should be limited to big tire.
I agree , SS or true back half only and a tire rule is all ya need for no prep...keep it simple.
(aka AMC Boyz) Rob.
Old 12-26-2016, 06:23 PM   #38
Mr Z
Mr Z's Avatar
DADS is a prepped track an the other is NO Prepp ! one weekend a month of badass Heads Up Drag Racing, pick your poison !
Mr Z is offline   Reply With Quote
Old 12-26-2016, 08:19 PM   #39
shadys281
Small tire
Stock type front suspension, no fiber/carbon bodies less it came that way, and small tires.. If you want more rules then that go class racing..
Big tire
No fiber/carbon bodies less it came that way and whatever tire you want..
shadys281 is offline   Reply With Quote
Old 01-01-2017, 11:57 AM   #40
sr71
stock style rear suspension rules are fine....as long as you drive a mustang. but what happens if you prefer a body style that came with leaf springs, or god forbid, irs??? a true back half has NO advantage over the modern mustang bolt in stuff.
sr71 is offline   Reply With Quote
Old 01-01-2017, 12:15 PM   #41
z289sec
z289sec's Avatar
IMO, a well thought out leaf spring car.....because of the way the suspension works, has just as good a setup as a Mustang for no prep. Call me crazy if you want.
RTCTTFMF!!!!
Stock suspension 67 Camaro
565 Conventional head BBC with fogger and a plate on 275's
Just about done
Texas Racewerks, Sanger, Texas
Nyes Automotive Racing Engines, Muncie, Indiana
FTI Converters and Transmissions, Deland, Florida
ACE Racing Transmissions, Garland ,Texas
z289sec is offline   Reply With Quote
Old 01-02-2017, 06:26 PM   #42
4406
X2
Ray
Old 01-04-2017, 10:22 AM   #43
chriscrna
chriscrna's Avatar
Agreed, no prep is a different animal. The double frame rail 3/4 chassis can shed a couple hundred pounds mote than a true back half with stock floors and firewall. That is my issue. I personally wouldn't run a double framerail small tire car because there is zero flex and is harder to get down cleanly on no prel
chriscrna is offline   Reply With Quote
