Lightening Program for CID BE Intake??? - Page 2 - Yellow Bullet Forums
Old 10-22-2019, 03:03 PM   #16
dtimmer
dtimmer's Avatar
Default Re: Lightening Program for CID BE Intake???
I have a lightening program for the SBF one. If I remember correctly it sheds 10-11 lbs.
-Derik
Visner Engine Development, LLC
Kentwood, MI
616-726-6600
dtimmer is offline   Reply With Quote
Old 10-23-2019, 12:36 AM   #17
Z'Stein
Z'Stein's Avatar
Originally Posted by Brian261 View Post
you will only really need to clean up the inside ....not really port it. It weighs 33 pounds as cast and Losito at Ultra Pro has a cnc lighten program for them and its $1100 and it weighs 16 pounds after he cnc it
Wow! To lighten it costs more than the intake itself! lol I guess it will be ran as is. I was looking to spend no more than 400.00.
Pure Muscle Racing, 407 Cubic Inches of Nasty Small Block Ford!
Z'Stein is offline   Reply With Quote
Old 10-23-2019, 12:38 AM   #18
Z'Stein
Z'Stein's Avatar
Check PM
Old 10-23-2019, 12:49 AM   #19
G-Code
Long Live The King
G-Code's Avatar
grinding wheel .... get to work
IRONY IS WASTED ON THE STUPID
"My job is not to represent the world, my job is to represent the United States of America " DJT 2-28-2017
58.3% of All Statistics are made up.
G-Code is offline   Reply With Quote
Old 10-23-2019, 12:54 AM   #20
Z'Stein
Z'Stein's Avatar
I may!
Old 10-23-2019, 01:02 PM   #21
litshoot
Double cut carbide burr, wax, ear buds, dust mask, ear pro, face shield and time. It goes quick, just be conservative and with each cut slowly creep up on final cuts. It will be fine
litshoot is offline   Reply With Quote
Old 10-23-2019, 01:28 PM   #22
65StickStang
65StickStang's Avatar
Pretty common when paying the pro's for their experience and talents. Buying my 2928 was the cheap part, lol
Powerglide - The Sleeping Pill Of Drag Racing
65StickStang is offline   Reply With Quote
Old 10-23-2019, 02:57 PM   #23
n2omike
n2omike's Avatar
Keep in mind... it takes a LOT of aluminum chips to add up to 10-15 pounds! With a hand grinder, you'll be at it for a LONG TIME! If using carbide burrs, the aluminum will clog up the flutes if you don't dip the burr in wax regularly as you go. Eastwood makes something called 'Grinders Grease' that I like. It's a hard, white wax substance in a can. Lower the burr into the can, quickly blip the switch to get in embedded in the burr... and go to town. Once the burr is hot, the wax will melt onto the burr. One can of Eastwood's Grinders Grease goes a long way.
You'll also want to get yourself looking like Darth Vader before you dive in to it. Glasses, face shield, HAT, ear plugs, respirator, etc... You'll be in your own little world, not aware of anything else around you for long periods of time. lol Wear a hat because you do not want chips in your hair. They tend to wash/fall out, and be a PITA. Had to get a chip dug out of my eye from that once. NOT fun.
Good Luck!
1966 Mustang
3300lbs w/driver pump gas street car
306 w/200hp plate 4-speed toploader
9.88 @ 135.67
n2omike is offline   Reply With Quote
Old 10-23-2019, 05:39 PM   #24
SCM 4V
You won't need wheelie bars with such a heavy Intake 😂.
SCM 4V is offline   Reply With Quote
Old 10-24-2019, 12:20 PM   #25
Z'Stein
Z'Stein's Avatar
That's a plus but it will also kill weight transfer. I think I will port-match it and put it back in the box and pull it out when I run at sea level. At this elevation it may hurt hp more than help.
