Turbo LS E36 M3 - Page 7 - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Fire your bullets!!! > Build Threads > Other Builds
Other Builds Share any build that doesn't fit into the other categories.
Old 08-29-2015, 08:48 PM   #91
F-350
Spooled up
Default Re: Turbo LS E36 M3
Badass build
F-350 is offline   Reply With Quote
Old 09-03-2015, 08:22 PM   #92
jon volk
jon volk's Avatar
Been a little bit since I last updated. Car is running great. Biggest issue I had so far was the mystery mileage Volvo fan burning up on me. Replaced that and have been good to go. Car runs at 187-190 with the stock radiator. Just added the heavy wastegate spring as it was only making 6psi at 70% duty cycle. It now makes 9-10psi on just spring pressure. I haven't gotten on the throttle too much as I'm still breaking in the clutch. Did a quick 2nd and 3rd gear pull and it's at 10.5:1 a/f at 10psi. Need to dial that back and put some timing in it. Also bought some Konis and have Ground Controls en route. Hopefully making the first 130mile round trip to work late next week.
92 325i Mtech, 4.8 LS, th400.
95 M3, forged L33, 7675 CEA, TH400/Gear Vendors
[email protected] on pump gas at 3530lbs
jon volk is offline   Reply With Quote
Old 09-07-2015, 02:37 PM   #93
jon volk
jon volk's Avatar
Some pics not taken with a potato.
Old 09-07-2015, 05:33 PM   #94
Firetruck1
draggin' ass
Firetruck1's Avatar
Wait till you realize it magically gets 25 mpg on the highway and its a great commuter car! The progress and results are great.
Michael
Thank you to all who have helped me on my projects:
Dan Neumann Race Cars
Fast Forward Race Engines
FTI Converters and Transmissions
Holeshot Wheels
Jones Racing Products
NRC Motorsports
TRZ Motorsports
“Le Petomane Thruway? Now what'll that a**hole think of next? Does anybody got a dime? Somebody’s gotta go back and get a sh**-load of dimes!”
I have sincere gratitude for gold star families. Thank you
Firetruck1 is offline   Reply With Quote
Old 10-09-2015, 01:06 PM   #95
jon volk
jon volk's Avatar
Been awhile since an update. Been driving the car a ton. I had an issue where I thought the clutch was done, but it ended up being an axle stub coming off. It must never have need seated correctly. The diff makes one hell of a grinding noise with one axle de-coupled.
Anyway, I have it tuned to just under 18psi on pump gas and spraying windshield washer fluid through 2 5gph nozzles. Flat 11:1 a/f at 11 degrees of timing. That's about as far as I'm going to push it for now.
Im going to add a fluid pump to spray the 1-3gear set as I've picked up a whine after extended high boost highway pulls.
Old 10-24-2015, 11:31 PM   #96
gnx7
Member
Pullin gears
gnx7's Avatar
Are you planning on making any 1/4 mile passes? Great fab work man! Love the car.
Street car: FD RX7, PT8847 LS9, T56Mag, Holley EFi, [email protected] 275/50/15 Drag Radial 197mph 1/2 mile
https://www.youtube.com/watch?v=y472n4EbWO0
Street car: FD RX7, LS7, T56Mag, McLeod RXT, Holley EFi [email protected] 165mph 1/2 mile!
2015 project: 1969 Chevelle, alum 5.3 GTS76, Chiseled A/W, T56Mag,9", full cromo cage, 25mpg, a/c, p/s, full interior, 9'[email protected] goal.
***Retailer for Tremec, McLeod, Holley, Molnar, Ohlins, Wilwood, BrianTooleyRacing parts
gnx7 is offline   Reply With Quote
Old 10-25-2015, 10:49 AM   #97
jon volk
jon volk's Avatar
Quote:
Yeah, I plan on taking it to the strip as well as the roll race events out in by Slipstream at Pocono Raceway. I was originally supposed to go to Pocono this month, but I ended up selling my ticket and was going to a 1/4 mile rental instead. That got rained out so this year is done.
I'm glad it's almost winter since last weekend this motor let go at the top of 4rth at just under 18psi. 11 degrees of timing on 93. The only thing that went wrong was the meth didn't come on till 5500rpm. I forgot there was a temp threshold of 60 degrees that I didn't change. I figured why the hell would my temps ever be that low. Well, Sunday was fucking cold! There was a few more threads of color on the plugs, buy nothing crazy. I'm not 100% convinced the meth not turning on was the cause. Number two rod went through the pan, but everything else looked fine so far.
Datalog shows good air fuel, rpm spike is a touch of 4rth gear wheel spin. Knock sensors don't show any loud noise until decel from this run. The a/f spike was a throttle blip before completely dropping out of it.
From the endoscopic camera....
Bottom of number 2
Top of number 2
Old 10-26-2015, 10:52 PM   #98
89jyturbo
Burnout box
My guess is you reached to power limit of the gen 3 rods. Unless the ring lands butted and the rod ripped itself off the bottom of the piston (though if that was the case you'd think the ring lands would fail before the rod broke out the bottom). I'm curious to see what you find once you get the piston out.
89jyturbo is offline   Reply With Quote
Old 10-27-2015, 07:58 PM   #99
jon volk
jon volk's Avatar
I'm curious to tear it down. Nothing went through the exhaust wheel. If my cam made it out alive, it's no loss. I've been looking for a motor with the better rods, but everything locally is $600-1000+. For not much more money, I'll just build a basic forged 5.3 with Wisecos and Chinese rods. That seems like a better long term solution to pushing it hard all the time.
Old 10-29-2015, 06:21 AM   #100
Rodchucker
Clevelands Rule.
Rodchucker's Avatar
Bad luck mate.
How did the wife take the news?
Rodchucker is offline   Reply With Quote
Old 10-29-2015, 01:09 PM   #101
jon volk
jon volk's Avatar
Ha, she knows I run this stuff hard and shit happens. We took the car out a bunch of times. My 18 month old had zero reaction to any pulls. Just chilled in her car seat munching on whatever snack she had. It'll be back together relatively soon.
Old 10-29-2015, 03:05 PM   #102
Shearer
Shearer's Avatar
Quote:
Originally Posted by jon volk View Post
That didn't take long!
Borg Warner, Callies, DART, Davies Craig, Diamond Pistons, Earls, Forced Performance, Garrett, Holley, K1, Precision Turbo, Stainless Works, TiAL, Trick Flow, Turbosmart, Vibrant, Wiseco, Xona Rotor Turbos
Dealer inquiries are welcome
216-242-2909
www.shearerfabrications.com
[email protected]
Shearer is offline   Reply With Quote
Old 10-29-2015, 03:19 PM   #103
jon volk
jon volk's Avatar
I also had 40+ datalogs from WOT pulls. It was beat hard every time the was out.
Old 11-10-2015, 12:27 PM   #104
jon volk
jon volk's Avatar
New bullet for the chamber arrived today.
L33. 70-80lbs lighter, better rods, better heads, more compression for better spool. Should be fun. Motor seems to be in fantastic shape so far.
Old 11-11-2015, 09:29 AM   #105
Firetruck1
draggin' ass
Firetruck1's Avatar
What will you do to the motor to prep it for the car? Do you mess with hone, ring gap or bearings? Studs and head gaskets I would assume? I have a ton of respect for the junkyard motor builds.
Michael
Holeshot Wheels
NRC Motorsports
TRZ Motorsports
