20 degree BBC w/alcohol - Page 3 - Yellow Bullet Forums
Old 11-12-2019, 07:37 PM   #31
WickEdSix98
Launchin
WickEdSix98's Avatar
Default Re: 20 degree BBC w/alcohol
I have no dog in this fight but does anyone notice that the people fighting FOR methanol are the ones who have already spent money for an alcohol setup yet haven't ever run it.
WickEdSix98 is offline   Reply With Quote
Old 11-12-2019, 10:17 PM   #32
dakster1a
Member
Pullin gears
Quote:
Not quite sure what that means Wicked, but I run mine every chance I get.
dakster1a is offline   Reply With Quote
Old 11-13-2019, 12:56 AM   #33
goneracin
goneracin's Avatar
Quote:
Originally Posted by Horndog View Post
Thanks ... overlooked it.
His cam is pretty close --- 3* shorter LSA and 4* shorter duration
3* lsa is "close" ? really? thats like saying an apple is close to a water buffalo
idiot
stay out of big boy discussions.
btw, I run an inch of lift at 8200 for 200 laps on springs and lifters
if you have a clue, its totally doable.
The king of the internet forum billy badass bullshit
goneracin is offline   Reply With Quote
Old 11-13-2019, 07:21 AM   #34
Coloradoracer
Coloradoracer's Avatar
Quote:
idiot
Bob, question for you. Have you guys done any methanol specific builds? If so, how did they compare to similar combos built for gas? What changes, if any, did you make to get them to run well?
Mark Goulette
Owner and driver, Livin' the Dream Racing Dragster
Speed kills but it's better than going slow!
www.livinthedreamracing.com
Authorized Amsoil Dealer
Coloradoracer is offline   Reply With Quote
Old 11-13-2019, 08:07 AM   #35
ndmp40
idiot
Good advice here.....
ndmp40 is offline   Reply With Quote
Old 11-13-2019, 09:05 AM   #36
Graphic Man
Wild Addiction
Graphic Man's Avatar
in a nut shell.......Alky will peek sooner in the rpm rage than gas and alky will make more TQ and peek sooner than gas,....but alky will loose on higher rpm motors.....(EX) for max effort N/A, Gas will make more in the upper rpm range...let say for conversation above 8500+,....in my own experience you should cam alky the same as gas,...for the heads, the chamber will need a lot less quench, a soft chamber will help a lot
2015 & 2016 O.T.T.P.A Points Champion
Thanks to:
Uratchko
Diesel Dr.
TRB Machine
4sale SB2.2 heads
Graphic Man is offline   Reply With Quote
Old 11-13-2019, 10:06 AM   #37
Coloradoracer
Quote:
Ok, understandable. But a couple of more questions for you. If the power on alky peaks sooner than gas, and gas makes more power at higher rpm, what is the cause of this? There are alky combos out there that turn very high rpm and run very well. What was changed on those setups so they would? And how does cubic inches play into this, ie. "Big inch engines don't run well and will lose power on alky over gas"?
Why do some people say alky won't work with certain combos but other people have used it successfully? What are they doing different to make it work?
Trying to learn....while at the same time getting the thought process going.
Mark Goulette
Old 11-13-2019, 10:15 AM   #38
RCM Racing engines
RCM Racing engines's Avatar
Default
Exhaust valve opening and closing events are different for Methanol than Gas.
Gas has more Btu's then alky too.
In my opinion, they are not cammed the same as a gas engine.
Just an old' Mennonite..........
RCM Racing engines is offline   Reply With Quote
Old 11-13-2019, 10:24 AM   #39
WickEdSix98
Launchin
Quote:
Not directed at you as you have real world data that you’re sharing. Some of the others trying to help do not
Old 11-13-2019, 10:55 AM   #40
dakster1a
Member
Pullin gears
Not directed at you as you have real world data that youíre sharing. Some of the others trying to help do not
Gotcha. I read it wrong, or it just didnít compute in my pea brain. Thanks
Old 11-13-2019, 11:17 AM   #41
Graphic Man
Wild Addiction
i can only speak on my own junk,...when i say high i am talking 9000+, cam it correctly ( should ) work well with both fuels. but everyone has there own opinion and experience, the quench area is a place to look at when running alky.....again just my $0.02
Thanks to:
Uratchko
Diesel Dr.
TRB Machine
4sale SB2.2 heads
Old 11-13-2019, 11:33 AM   #42
Coloradoracer
And your input is helping how? How about instead of making dumbass statements, ask a valid question or provide examples of your obviously unlimited profound knowledge and experience....
Mark Goulette
Old 11-13-2019, 11:37 AM   #43
Coloradoracer
When run at the correct af ratios though, the total btu output of methanol fueled engines is actually higher than that of gas. Plenty of data to prove that.
As to the cam, what differences are there between the two, and what kind of profile would benefit each fuel the most?
Mark Goulette
Old 11-13-2019, 11:40 AM   #44
Coloradoracer
Ok, regarding the quench area, what favors alky? More or less? I've heard of guys picking up performance when running a softened chamber over a standard one, but would that be a typical thing or more of a specific build deal?
Mark Goulette
Old 11-13-2019, 12:06 PM   #45
69427
A Senior Member
69427's Avatar
Hmmm. Flame speed of the fuel?
Do these 20 degree and less angled heads have a large quench pad? Would rolling the quench pad towards the plug help?
69427 is offline   Reply With Quote
