#16 | |
Long Live The King
![]() Quote:
IRONY IS WASTED ON THE STUPID "My job is not to represent the world, my job is to represent the United States of America " DJT 2-28-2017 58.3% of All Statistics are made up. |
Sponsored Links | |||
Advertisement |
#17 |
In just about every build we do the rings are happy at the end of the first pull on the DYNO!.WE use a lot of Total Seal AP rings and no gapless .Bill C.
Checkered Flag Machine & Ceralli Competition Engines Racing engines and induction development http://www.checkeredflagmachine.net/ |
#18 | ||
![]() Quote:
I got my honing down to a science, my first three pulls usually make within 2 HP of each other, when I see that and vacuum climbing I know they were seated of the engine stand, but I still ain't got big enough ballzz to run Synthetic oil right away, and for me it's just not worth it, I'll run break in oil atleast 10-12 pulls, then change it... been working for me so I ain't changing it... LOL
![]() Just an old' Mennonite.......... ![]() |
#19 |
I also got engines that'll pull 20+" of vacuum with regular ring/ non gapless.
I do see a little more with gapless though, but not much.
#20 |
IMHO If you are going to break this engine in on the street (instead of on a dyno) I would make SURE you have the timing and everything set correctly so you can start it up and drive it. Letting an engine idle for 30 minutes does not help ring seal at all.. And you don't want to drive in traffic or steady speed freeway miles. You want to start it, take a quick look for leaks and drive it until it warms up.
Then run 1500 to 3000 and back of and let it decelerate back downto 1500 in gear, repeat two more times, then do the same, three times to 4000 and to 5000 letting it back down in gear each 'pass'. Try and do this in consecutive 'runs', some place not far from your garage. Get back, drain the oil, it will be sparkly, change the filter. Look at it if you want, I like to look at the secnd one. From there I'd run non-synthetic, drive it hard, change the oil at 500 and then at 1500. I like WIX filters. If you want to run premium valve springs put them in after the 2nd or 3rd oil change ...when you could go to synthetic. .....all this is useless without good machine work |
#21 | |
Long Live The King
![]() Quote:
Neither do I, but after break in and 8 pulls I feel comfortable.
#22 |
Spooled up
Great info thanks everyone!
#23 |
Spooled up
I was planning to start engine on start up stand and run for 25-30 minutes at varying rpm between 2500-3000 like you would for a solid flat tappett break in. I was going to do this reguardless of whether I choose the solid flat tappett or hydraulic roller approach. Then I was going to install engine after I knew all aaas well and make some hard high hear type passes to help with ring seal. If it's just hydraulic roller it sounds like I can start it up and go ahead and make those passes to help with the ring seal and forgot the so called break in period. I wasn't planning on dyno. I am however planning on chassis Dyno. Am I off base with this thinking?
#24 |
A Senior Member
If you do a solid flat tappet. I use a bottle of GM EOS with a good dinosaur break in oil like Brad Penn and a WIX 51061r filter. Another suggestion is to buy a filter mount without a buy pass, this way you will filter all the oil.
https://www.summitracing.com/parts/c...SABEgIAIvD_BwE https://www.superiorperformance.net/...ilfilters.html Do the break in like you said varying the rpm for the first 15 minutes 1500-3500 rpm. Like others have said make every effort that it is ready to start and run first time. |
#25 |
Spooled up
Thanks everyone.
#26 | |
Member
Pullin gears
![]() Quote:
![]() Personally I'd use one or the other. Regular oil and EOS or break-in oil, but not both. More isn't always better. |
#27 | |
![]() Quote:
Pre-oil until you see oil coming out of all rocker arms. Make sure carb is filled with motion lotion before you start it for the first time. You'd be surprised how many do not --- those running mechanical fuel pumps.
Jim Horner " ...oh no, what the fuck was that? ...the motor ... we've thrown a rod. ...is that serious? ...yup." “And if all others accepted the lie which the Party imposed—if all records told the same tale—then the lie passed into history and became truth." -George Orwell I really don't know which is worse ..... all of DOTARD's lies all the time, or all the trumphumpers lapping them up with not even giving them a critical thought ![]() |
#28 | ||
![]() Quote:
Quote:
https://rislone.com/product/3x-conce...reatment-4405/ I mix it so I get about 1800ppm zinc. I can't remember the ratio, but I can look it up if you like. From what I've read, 1800 is approximately the point of diminishing returns with zinc. I also like to plug my bypass and run a filter with a stiffer internal bypass, like Hastings LF349, Baldwin B279 or B1441, or Casite CF524. |
Advertisement |
#29 |
Spooled up
Thanks for all the advice Nova you've been nothing but up front and honest with me with all my questions. I don't see alot of those filters around here. I will see what Amazon has to offer. Again thanks for the info....Chris
Thread Tools | |
Display Modes | |
