yates c3, d3, brodix neal, sc1 exhaust bolt patterns.. - Yellow Bullet Forums
Old 11-04-2019, 10:28 PM   #1
94_CobRa
Launchin
94_CobRa's Avatar
Garage
Default yates c3, d3, brodix neal, sc1 exhaust bolt patterns..
Are they all the same? Looking at all the mentioned heads, it looks like they all have about the same casting and all use the same exhaust bolt pattern.. like 2.75" diagonally? With just slightly different ports, some square, some D shaped, round, etc.
If so, are all the exhaust ports the same height relative to the deck surface? or are some bolt patterns higher or lower?
thank you
Twin turbo 94 cobra in the making.
-AMP EFI Ms3
-ZSR Engines
-Team UPR
New 2.0 build thread-
https://www.yellowbullet.com/forum/sh....php?t=2497066
old build thread -https://www.yellowbullet.com/forum/sh....php?t=1066874
94_CobRa is offline   Reply With Quote
Old 11-05-2019, 11:36 PM   #2
BOSS#1540
Launchin
BOSS#1540's Avatar
Default Re: yates c3, d3, brodix neal, sc1 exhaust bolt patterns..
I know the first A3's had two different patterns, not 100% sure on the others. Dan Jones has a lot of info and George Klass may be able to help, he makes headers.
BOSS#1540 is offline   Reply With Quote
Old 11-06-2019, 10:09 PM   #3
Ben Mens
Ben Mens's Avatar
The bolt holes are usually / probably in the same location. Having the port location in the same position referenced to said bolt holes unfortunately is not. Not to mention the physical size of the port. Bigger header tubes may get you matched up to a couple / few versions.
Ben Mens is offline   Reply With Quote
Old 11-11-2019, 10:26 PM   #4
94_CobRa
Launchin
94_CobRa's Avatar
Garage
Quote:
thanks for the post, my thoughts were right in line with exactly what you said.
-AMP EFI Ms3
-ZSR Engines
-Team UPR
Old 11-12-2019, 09:25 AM   #5
DragBoss
Member
Pullin gears
DragBoss's Avatar
The early heads A3 had 2.77 inch center to center, there after changed to 2.94 inch, after that. not sure about about d3 stuff.
408 Cleveland, 9.69 at 136mph with a 1.27 60 ft. Just starting to fine tune.
DragBoss is offline   Reply With Quote
