bbc tunners please come in- help - Page 6 - Yellow Bullet Forums
Old 11-06-2019, 08:51 PM   #76
Mean Lx
Gas Passer
Mean Lx's Avatar
Default Re: bbc tunners please come in- help
It sounds to me like valves just are not adjusted correctly.
SOMETHING WICKED THIS WAY COMES
Thanks to Tony Bischoff BES/Sam Vincent, Joey Martin/Tim Lyons, Induction Solutions, Casey Buschmeyer, and Bruce Oliver
Mean Lx is offline   Reply With Quote
Old 11-06-2019, 09:21 PM   #77
pontiaco
Pre-Staged
Here is the video of the exhaust temps, they are all over the place
wtf?
pontiaco is offline   Reply With Quote
Old 11-06-2019, 09:27 PM   #78
61-4SPEED
61-4SPEED's Avatar
you need to readjust your valves first... pass side is louder than the drivers side..ive also seen some rocker arms hit the inside of the valve covers on the "tubes" that are welded inside where the bolts go
THANKS TO:
JK CUSTOM FABRICATION
NEW EAGLE PA
61-4SPEED is offline   Reply With Quote
Old 11-06-2019, 11:08 PM   #79
Shoedoos
OP please show a video of the timing light on your engine - at idle and at various places until you are all in.....does the timing walk around when you're at idle?
Shoedoos is offline   Reply With Quote
Old 11-06-2019, 11:32 PM   #80
pontiaco
Pre-Staged
Default
The light doesn't jump around but I will try to ge a video tomorrow, thanks guys
Old 11-07-2019, 09:44 AM   #81
Dave Koehler
Member
Pullin gears
Dave Koehler's Avatar
Fix the darn valve lash issue before anything else!!!!
Dave Koehler
Koehler Injection
www.koehlerinjection.com
Fuel Injection - Nitrous Charger - Nitrous Master software - Balancing
Dave Koehler is offline   Reply With Quote
Old 11-07-2019, 10:46 AM   #82
Horndog
Quote:
Originally Posted by pontiaco View Post
That's it, I'm pulling the cam
DON'T ... NOT YET !!!!!
Reset the preload in all lifters before doing anything else.
Just be sure that the lifter you are adjusting is on the base circle of the cam lobe.
Jim Horner
" ...oh no, what the fuck was that?
...the motor ... we've thrown a rod.
...is that serious?
...yup."
“And if all others accepted the lie which the Party imposed—if all records told the same tale—then the lie passed into history and became truth." -George Orwell
I really don't know which is worse ..... all of DOTARD's lies all the time, or all the trumphumpers lapping them up with not even giving them a critical thought
Horndog is offline   Reply With Quote
Old 11-07-2019, 10:48 AM   #83
Breadburner
LOL...
Breadburner is offline   Reply With Quote
Old 11-07-2019, 10:56 AM   #84
Horndog
Quote:
Originally Posted by yeti View Post
... well .. yeah ...... I was just throwin' some chum to see if he had anything else to say ...
Got a cam from CC for a lift rule deal that was so crazy he might have ground it. Plotted on a graph the lobes were like you cut the top off of one and the bottom off another and put the two together, like paper dolls. At near mid-lift there was a distinct oblique angle where the two slopes met and the velocity changed. Nuts. It floated at 5000-5500 and their advice was add spring pressure, which reduced the torque nearly a ft. lb. per each lb. of additional seat pressure.
OP, see if you have any cold header pipes.
I've bought four of their 'shelf' cams over the years. Never had any issues. I do have a tool to check the cam's firing order.
So you spec'd a cam from them, and because you got a piece of shit, you think that's a regular occurrence? Don't choke on your own chum, yeti.
Jim Horner
...is that serious?
...yup."
Old 11-07-2019, 11:03 AM   #85
Breadburner
LOL...!!!
Old 11-07-2019, 11:47 AM   #86
69427
A Senior Member
69427's Avatar
pontiaco
I believe you said this is a hydraulic roller? It sounds like a Singer sewing machine in the video. You need to address that. And look at the cam card and see if there is a 47S at the end of the grind number.
69427 is offline   Reply With Quote
Old 11-07-2019, 12:04 PM   #87
1Azgerman
1Azgerman's Avatar
Default
Part number given in first post for the camshaft references a SBC cam? XR 294HR - 10 ?
Steve
1Azgerman is online now   Reply With Quote
Old 11-07-2019, 12:46 PM   #88
69427
A Senior Member
69427's Avatar
Quote:
Originally Posted by 1Azgerman View Post
Part number given in first post for the camshaft references a SBC cam? XR 294HR - 10 ? Steve
Oops I forgot he posted everything.
https://www.summitracing.com/parts/c...make/chevrolet
So that eliminates the 4-7 swap.
Wasn't there a thread about specials oils being required for a HR? Centipedes or something?
Old 11-07-2019, 02:01 PM   #89
1Azgerman
1Azgerman's Avatar
Default
OP ask for help with his BBC however he has posted a SBC part number that he is using in his engine? He must have written the wrong part number?
Steve
Old 11-07-2019, 06:33 PM   #90
yeti
You really are that stupid, aren't you. I didn't spec anything except the maximum lift and what the cam was for. CC was asked for their best cam for a lift rule and they supplied a cut and paste "custom grind" piece of junk that wouldn't turn over 5500 without severe valve float with 180# on the seat and 380# over the nose with only .480" lift. A monkey could have made a better lobe with a belt sander. Started with their advised installed pressure and when that didn't work added 30# and the engine lost 30 ft.lbs. and the valve float was no better. The lobe had a ramp jump in the middle of the lift. The rate of lift changed suddenly from one 5 deg. increment to the next. It didn't float over the toe, it floated on the way up the ramp. Comp Cams "custom grind" wasted a lot of money and dyno time. Too bad none of this helps the OP.
#7 was cold in the heat gun video. I would just swap 4 and 7 to see if it made it worse or better. No harm no foul if it isn't the problem and easy to do and undo.
yeti is offline   Reply With Quote
