752 hp 408 Cleveland Teardown - Page 7 - Yellow Bullet Forums
Old 01-23-2019, 10:41 PM   #91
Bill Diehl
Bill Diehl's Avatar
Default Re: 752 hp 408 Cleveland Teardown
They are stronger, thus they can be made smaller and....smaller is lighter, than Tia
___________________________
Bill Diehl is offline   Reply With Quote
Old 01-31-2019, 02:10 PM   #92
DragBoss
Member
Pullin gears
DragBoss's Avatar
Here is the next episode in my series update. Subscribe and share
408 Cleveland, 9.69 at 136mph with a 1.27 60 ft. Just starting to fine tune.
DragBoss is offline   Reply With Quote
Old 01-31-2019, 03:28 PM   #93
BOSS#1540
Launchin
BOSS#1540's Avatar
Another good vid man. I also switched to Brad Penn and made sure oil drains were aligned, only 7 Qt pan in fox body though, but it's rear sump with scraper, kick outs and trap doors, so hopefully that helps. Kevco pan. Looking forward to seeing what the bores look like, hopefully o.k.
You need a few more BG400's !
BOSS#1540 is offline   Reply With Quote
Old 01-31-2019, 03:59 PM   #94
Tater
Tater's Avatar
Default
Cool video Tim. I’ve had good luck using Brad Penn oil here too. Sorry to hear the Track Boss block delay but look forward to your freshening up on your old mill. I totally agree with you on the garage heating comments. I’ve always used kerosene for garage heat here and would like to do something else in the future. I think your collecting BG fuel pumps might be as bad as I am with collecting 351C parts!! LOL
Tater is offline   Reply With Quote
Old 01-31-2019, 04:43 PM   #95
DragBoss
Member
Pullin gears
DragBoss's Avatar
You are Prob ok with rear sump and with kick out even better. Yes can't wait to see inside. Always looking for more BG pumps lol.
Old 01-31-2019, 04:45 PM   #96
DragBoss
Member
Pullin gears
DragBoss's Avatar
Quote:
Originally Posted by Tater View Post
Cool video Tim. Iíve had good luck using Brad Penn oil here too. Sorry to hear the Track Boss block delay but look forward to your freshening up on your old mill. I totally agree with you on the garage heating comments. Iíve always used kerosene for garage heat here and would like to do something else in the future. I think your collecting BG fuel pumps might be as bad as I am with collecting 351C parts!! LOL
Thanks man. It will all work out the way it should. Yes have had my share of fumes for sure. Like you also have extensive collection of Parts. Sure beats collecting coins or stamps. Stay tuned.
Old 02-05-2019, 08:30 PM   #97
DragBoss
Member
Pullin gears
DragBoss's Avatar
Episode 7 Making some head weigh.......
Old 02-05-2019, 09:57 PM   #98
brmustang
Thanks for making these videos. I’ve been subscribed for a couple weeks now and I’m ready to see the new block in a video good luck. Has anyone heard any update on the CGI block yet?
brmustang is offline   Reply With Quote
Old 02-05-2019, 11:26 PM   #99
Tater
Tater's Avatar
Default
Glad everything on the Ole 408 so far looks good after pulling the heads off. April will be here before ya know it! Hopefully the bottom end looks good since the oil n drain plug didn’t seem to have any metal collection. Are you gonna bother cutting the filter open since your gonna go thru the bottom end anyways?
Old 02-06-2019, 11:42 AM   #100
BBF612
BBF612's Avatar
https://www.enginelabs.com/news/a-mo...orsepower-n-a/
BBF612 is offline   Reply With Quote
Old 02-06-2019, 03:02 PM   #101
DragBoss
Member
Pullin gears
DragBoss's Avatar
Your welcome. thanks for subscribing. I know the second round of aluminum blocks have been poured, mine is one. Once it gets machined and bronze bushings fitted, have him ship to me, along with a callies crank I have for the build. The cgi has been put on back burner, as the people really want a cast block. I think Tim needs to get the blocks out there, most popular is grade 40 iron, I may wrong on the grade stuff. Get some engines built and tested, only Steve Ks number one build has been dynoed. That is getting some trick up grades. I would also like a cast iron one too, in the future.
Old 02-06-2019, 03:05 PM   #102
DragBoss
Member
Pullin gears
DragBoss's Avatar
Glad everything on the Ole 408 so far looks good after pulling the heads off. April will be here before ya know it! Hopefully the bottom end looks good since the oil n drain plug didnít seem to have any metal collection. Are you gonna bother cutting the filter open since your gonna go thru the bottom end anyways?
I dont know tater, if I got a few minutes, may slice her open for forensic evaluation. It looks good so far. Clean up parts today, and get a better look. Thanks for staying tuned.
Old 02-06-2019, 03:07 PM   #103
DragBoss
Member
Pullin gears
DragBoss's Avatar
Quote:
Originally Posted by BBF612 View Post
Yes, I saw that he is making with single 4, he making 1.86hp/cube, I am not far behind at 1.84hp/cube. Very impressive.
Old 02-06-2019, 03:38 PM   #104
BBF612
BBF612's Avatar
Just spreading the cleveland love around, didn't mean for it to be hp/cuin war. I wish there were more FE love, lol.
Old 02-06-2019, 07:19 PM   #105
BOSS#1540
Launchin
BOSS#1540's Avatar
Good stuff Tim, nice to see everything coming apart ok and looking good. I know you're not one for change but just thought I'd mention for others that Jomar makes an oil filter with no by-pass, part# 9025, has more filter area and claims 1 psi increase. You can still put your magnet on it! Actually I'm going to get one of those.
