It's time - Head recommendations. 20 degree ? - Page 9 - Yellow Bullet Forums
Old 05-10-2019, 12:55 PM   #121
scott foxwell
scott foxwell's Avatar
Default Re: It's time - Head recommendations. 20 degree ?
Quote:
Originally Posted by Mills588 View Post
Looks beautiful Scott .. very nice!
Thanks Mills.
Induction Development Specialties
Retail/wholesale parts sales
Custom cams
423 391 7774
Acts 2:38, the perfect answer to the perfect question.
If God is your co-pilot, change seats!
scott foxwell is online now   Reply With Quote
Old 05-10-2019, 12:56 PM   #122
scott foxwell
Quote:
Originally Posted by Motofitmike View Post
Very nice, what degree valve seat angles are you using?
Thanks. We can do 50 or 55. These are 50 using Brodix' cutters.
Custom cams
423 391 7774
Old 05-10-2019, 07:30 PM   #123
Rapidray
Rapidray's Avatar
Scott
Is that machining on the head surface intake side something you are playing with or is that just the semi-rough before the head is resurfaced?
Rapidray is offline   Reply With Quote
Old 05-10-2019, 07:48 PM   #124
scott foxwell
Quote:
Originally Posted by Rapidray View Post
Scott
That's the "softened" area. It's a 2* "dish" cut into the chamber that effects the quench areas.
Custom cams
423 391 7774
Old 05-10-2019, 09:50 PM   #125
Rapidray
Rapidray's Avatar
Is that something you are doing for nitrous or has it shown other benefits in uses?
Old 05-11-2019, 09:00 AM   #126
scott foxwell
It's usually associated with lots of nitrous and higher compression but I think some guys are starting to use it in high boost/big hp apps as well especially with small flat chamber heads with real shallow valve angles.
Custom cams
423 391 7774
Old 05-11-2019, 09:17 AM   #127
Warp Speed
Warp Speed's Avatar
Quote:
I know your customer uses a facility that has cylinder pressure data capabilities. Have you tested this mod to see its effect on burn rate?
Research and Development is allot like life in general...........................it's all about managing disappointment!
Quote:
Originally Posted by lun40119 View Post
My name isn't Jake........and I don't have a red chevelle. I am a keyboard junkie, in my mom's basement, with no pants on.
Warp Speed is offline   Reply With Quote
Old 05-11-2019, 09:27 AM   #128
scott foxwell
Quote:
No, that would mean a before and after. We just don't have time or resources for that kind of testing. Wish we did because I'd like to see that data. On chamber softening, I am 100% just going off what I'm told by others and hoping it works.
Have you guys tested anything like this?
Custom cams
423 391 7774
Old 05-11-2019, 12:19 PM   #129
Rapidray
Rapidray's Avatar
He'd have to kill you if he told you their results!
Old 10-12-2019, 01:34 AM   #130
Mills588
Mills588's Avatar
"It's Time" .. is finally happening!! Thought I'd share a few shots. More to come!
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Power & Parts by DG Machine!
NA 10.5! Leaf Spring Nation!
EMAIL @ [email protected]
Smith Bros, ATI PROCHARGERS, AFR, Dart, Brodix, CFE & BMF, Profiler, Manley, Callies, Erson, JE, Ross, Wiseco, Ferrea, Moroso, Pro Systems, Comp Cams, Erson, Hughes Performance, Trans- Specialties Full Line, ISKY, Strange Engineering Entire Line, TRZ Suspension Components, Smith Racecraft!.. and more!
Mills588 is offline   Reply With Quote
Old 10-12-2019, 02:04 PM   #131
BOSS#1540
Launchin
BOSS#1540's Avatar
Awesome looking components, glad it's coming together, hope it all works out for you.
BOSS#1540 is offline   Reply With Quote
Old 10-14-2019, 01:14 PM   #132
calypso50kid
All motor wannabe
calypso50kid's Avatar
your plug wires should be in tomorrow fyi jeff
I remember when I used to race.
New Location for Hays Consulting we are now in Greenville, SC
Hays Consulting Racepak, Holley, MSD, Earls Dealer, UPR, Viking shocks, Strange Engineering and more.
Contact me at 7349266067 or email at [EMAIL="[email protected]"]
Thanks to
Efi University
PSI Springs
Holley EFI
Racepak Data Systems
calypso50kid is offline   Reply With Quote
Old 10-14-2019, 02:25 PM   #133
Jp outlaw
I kill parts
I don't think that little spring on the front is gonna cut it......
Jp Shawgo - Close E'nuff Racing
www.sandeperformance.com
Jp outlaw is offline   Reply With Quote
Old 10-14-2019, 03:40 PM   #134
TheNovaMan
TheNovaMan's Avatar
Nice build! What diameter wrist pins?
~Pete
I know enough to know that I don't know enough.
Quote:
Originally Posted by ten5nova View Post
I know you're the Cragar king
You got that right!
Quote:
Originally Posted by Chris Uratchko View Post
there is nothing in an LS that will support more hp per CID than a Gen 1... absolutely zero.
TheNovaMan is offline   Reply With Quote
Old 10-16-2019, 03:12 AM   #135
Mills588
Mills588's Avatar
Default
Quote:
Thanks! I appreciate it.. been a long wait; had a lot of great help .. can’t wait to get it fired-up and on the dyno!
EMAIL @ [email protected]ts.com
