400 Rod Length Advice needed - Yellow Bullet Forums
Old 11-11-2019, 01:13 PM   #1
Rubberduck406
Default 400 Rod Length Advice needed
New build for a bracket car. Little M block, Callies 3.75" Compstar crank, Pro Topline 23* 210cc CNC'd heads on alcohol. 3000lb ladder bar car, transbrake, typically turned under 7000 rpm.
Haven't bought rods or pistons yet and am torn between going with a 6" rod or a 6.125" rod (either length will be a Callies Compstar). Will it be more "efficient" with the longer rod or will I even see a difference in this particular application? Shooting for 13-14:1 compression if that makes a difference.
Rubberduck406 is offline   Reply With Quote
Old 11-11-2019, 03:43 PM   #2
ColeBalster
ColeBalster's Avatar
Default Re: 400 Rod Length Advice needed
I really don't think you'll see a difference.
My choice would be the 6.000" simply for a little less pin height, which would leave more room for the rings/valve reliefs and have a little better stability.
I have the Wiseco "Lil Quick 16" pistons in my 18 degree 406 (4.155" x 3.75" with 6.000" rods and their recommended .043" x .043" x 3.0mm rings).
I also had them change from lateral to vertical gas ports, which they did for no charge.
They offer a hollow dome 23 degree piston in the same design. p/n K0033B3 for 4.155" x 3.75" x 6.000", and rings p/n JG7708-4155-5 .043" x .043" x 3.0mm.
1967 Camaro N/A SBC(10.19 @ 136 mph)
2006 GTO PBM/Black/M6 (gone but not forgotten)
2005 GTO PBM/Red/M6 (purchased 7-18-14 w/ 87K)
- 6.2 w/ LSX-LS7 heads & LSX454 cam / Kooks 1.875" / Exh / Whiteline Bushings / etc.
http://cole.balster.googlepages.com/home
ColeBalster is offline   Reply With Quote
Old 11-11-2019, 04:51 PM   #3
CATCRACKER72
CATCRACKER72's Avatar
6.00 in my book, I don't care for the ring stack with longer than a 6.00 on 3.750 and above strokes.
CATCRACKER72 is offline   Reply With Quote
Old 11-11-2019, 04:59 PM   #4
CNC BLOCKS
CNC BLOCKS's Avatar
I have built them both ways they seem to run good with either rod.
CNC BLOCKS is offline   Reply With Quote
Old 11-11-2019, 07:17 PM   #5
Horndog
X2 ---> 6" rod, least at compromising the ring stack and .043 / .043 / 3mm ring package.
Jim Horner
" ...oh no, what the fuck was that?
...the motor ... we've thrown a rod.
...is that serious?
...yup."
“And if all others accepted the lie which the Party imposed—if all records told the same tale—then the lie passed into history and became truth." -George Orwell
I really don't know which is worse ..... all of DOTARD's lies all the time, or all the trumphumpers lapping them up with not even giving them a critical thought
Horndog is offline   Reply With Quote
Old 11-11-2019, 08:46 PM   #6
Mike Beck
EFI/N2O JUNKIE
Mike Beck's Avatar
Me, and all my friends running a 400-type block, all use 6" rods, except for one, my buddy with a tall deck block is using a longer rod.
Mike Beck is offline   Reply With Quote
Old 11-12-2019, 08:38 AM   #7
MN Hemi
The Phantom Machinist
MN Hemi's Avatar
6” rod. If you’re running a vac pump, .9mm/.9mm 2.5mm ring pack. It will give you some room between the ring lands for an expansion groove.
MN Hemi is offline   Reply With Quote
Old 11-12-2019, 06:01 PM   #8
Rubberduck406
Mahle makes a piston for a 6" rod that'll put me close to 14:1, they're a 1mm, 1mm, 2mm pack. Engine builder has the same piston in the older style that's a 1.5mm, 1.5mm, 3mm pack. Leaning towards the older style with the thicker rings.
Old 11-12-2019, 06:07 PM   #9
novafornow
novafornow's Avatar
You are here asking questions for a reason. You may want to re-think that choice. There is a reason that modern pistons have narrower rings. Just saying.
novafornow is offline   Reply With Quote
Old 11-12-2019, 09:30 PM   #10
Outlaw Bill
Use the Mahle piston with the 1mm rings you will be better off.
Outlaw Bill is offline   Reply With Quote
Old 11-14-2019, 12:15 AM   #11
wes427
i had crower 6.125 had to run .900 base circle cam to clear with cutting on rods, callies has a XD rod with the bolts canted for more clearance to run a standard base circle cam id run a xd 6.oo rod so my valve train would be more stable with a larger base circle cam. would depend how many rpm you would like to turn for how important your cam base circle is
wes427 is offline   Reply With Quote
Old 11-14-2019, 12:24 AM   #12
wes427
*clear with out cutting rods. and yours should live forever @ 7k rpm
Old 11-14-2019, 10:28 PM   #13
engineguy
Rod length for a bracket type engine is not critical, I would go with the 6.00" with 1.0mm, 1.0mm, 2.0mm MAHLE ring pack OR 1.2mm, 1.2mm, 3.0mm ring package.
For a high RPM maximum effort drag race engine, I would go with the longer rod. Remember though, in order to get the optimum results with the long rods, the camshaft needs to be designed to take advantage of the increased piston dwell time at TDC.
Bill
SAE Member (29+ years)
ASE Master Certified Engine Machinist
AERA Certified Professional Engine Machinist
Do what you can, with what you have, where you are.
- Theodore Roosevelt
engineguy is offline   Reply With Quote
