Dyno Videos and Results - Page 58 - Yellow Bullet Forums
Old 09-08-2019, 12:02 AM   #856
Gary Blair
Gary Blair's Avatar
Default Re: Dyno Videos and Results
Originally Posted by Mitch H View Post
Oliver
Thanks. I've been going back and forth. Steel or GRP billet aluminum.
Gary Blair is offline   Reply With Quote
Old 09-09-2019, 01:53 PM   #857
Orr89rocz
https://ibb.co/CKbhgdx
Alittle disappointing but maybe not all things considered...
555 bbc 10:1, built for turbo, so thick rings, heavy duty rotator, 15w40 oil
E85
Dart 345cc based casting with a cnc program run thru it. 425/304 at .800
Super victor efi intake. Mildly ported but wouldnt say a whole lot done to it
Wilson 4500 elbow with a 102mm throttle
2 1/8 header into 3.5 collector but tapers into 3” dual exhaust very quickly like in 8-9” or so.
Cam is around 267 deg at .050”, mid 700’s lift on a 114.
Th400 with tighter 9.5” ptc converter for turbo. 12 bolt rear for now
Pulling near 2-2.2” of vacuum. So that cant help numbers, along with the long small exhaust. Didnt play with fuel too much it was near 12.4-12.6 range gas scale. May be some left there. 37 deg made best power.
Honestly thought more like 550+ whp, or 750+ flywheel. Seems like its restricted to 650 right now. Peak rpm seems much lower than expected as well. Oh well boost shoukd cure it
1989 Camaro IROCZ
400" sbc twin turbo
8.24 @ 169 street car
Orr89rocz is offline   Reply With Quote
Old 10-15-2019, 11:53 AM   #858
scott foxwell
scott foxwell's Avatar
470" truck pull motor, 990 iron heads & Vic Jr both ported in house, 4150 carb, Straub custom 3 lobe cam, 1-7/8 header rule. We were fighting a carb issue...this pull to 7000 was the only real "clean" pull we made. Shows good tq, nice curve.
This pull wasn't so clean, about 5 hp off average form pull before but shows good peak number. Should carry out nicely.
Induction Development Specialties
Retail/wholesale parts sales
Custom cams
423 391 7774
Acts 2:38, the perfect answer to the perfect question.
If God is your co-pilot, change seats!
scott foxwell is online now   Reply With Quote
Old 10-15-2019, 11:59 AM   #859
NPS Nova
NPS Nova's Avatar
Well that's some pretty nice results. Especially with the OEM 990 heads that many say are junk or too big etc.
Looks like only 12.5 to 1 compression ratio as well???
THIS is the type of engine people could be putting in there cars are more the "sleeper" look, "just a mild 454 with OEM cast heads, got a small cam, small headers and Edelbrock intake." SLEEPER. Then turn around and run low 9's in a Normal looking Chevelle. HELL past it off as a 396 in a stock-ish Nova/Camaro
Nice work, CONGRADS
Whatever, just bring it.
NPS Nova is offline   Reply With Quote
Old 10-15-2019, 01:44 PM   #860
scott foxwell
Nice work, CONGRADS
The three lobe .800" 280* cam might be a dead give away...
Custom cams
423 391 7774
Old 10-15-2019, 01:55 PM   #861
NPS Nova
NPS Nova's Avatar
Yes true. Reminds me of a beautiful green 69 Chevelle SS396 Toronto streetracer back in the early 90's. Car looked like a nice clean stocker with rallys, till it started.
Still nice results
Old 11-10-2019, 08:30 PM   #862
Chad Speier
Personal engine for my street car. Going to be EFI and TB. Dyno'd with a carb.
Needs a bigger carb, left power on the table but just wanted some break in runs, switch to EFI, and chassis dyno tune.
[email protected] [email protected] 500hp from 5300-up. Needs a bigger carb.
4.165 x 3.48
VFactor v2.35 ProFiler 205cc CNC
Ferrea 2.08/1.600 LS Valves
KMotion K800 springs
LGM rockers
Motown EFI Ported manifold
Scat LW crankshaft
Scat LW 6.00 rods
Mahle 1/1/2mm pistons
10.5-1
TPiS/Howards Billet solid roller
231/235 112 LSA 108 ICL
.580 lift
3/8 pushrods
Morel full time oiling lifters
SA Billet chain
cast aluminum chain cover w/roller bearing
BBK billet pullies
Tuff Stuff aluminum water pump
TCI Rattler
Kevco NHRA Pan
Nitrous outlet elbow
TPiS 58mm billet TB
36lb injectors
Edelbrock Rails
Aeromotive regulator
Custom fabricated valve covers
Wix filter
Comp break in oil
VFactor NATION
SRH Speier Racing Heads
785.623.0963
Chad Speier is offline   Reply With Quote
