cleaning hyd roller lifters in ultrasonic tank - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Valvetrain
Old 08-15-2019, 10:27 PM   #1
badfarmtruck
Default cleaning hyd roller lifters in ultrasonic tank
yes or no? if so, what cleaning solution? they are not grimey, just been sitting around(covered).
badfarmtruck is offline   Reply With Quote
Old 08-16-2019, 10:42 AM   #2
bigblockmark
bigblockmark's Avatar
Default Re: cleaning hyd roller lifters in ultrasonic tank
Ultrasonic you can not use anything flammable. Water base cleaner only. May not want anything that can rust inside lifter? Clean mineral spirits in a container may be all you need.
I use Simple Green and filtered water, 20:1 concentration, in my ultrasonic for most not too dirty engine parts and carbs. Nice because it will not harm the carb decals some custom builders use on bowls.
bigblockmark is offline   Reply With Quote
Old 08-17-2019, 10:08 AM   #3
TxRed
TxRed's Avatar
I use a small glass bowl of solvent (from the parts washer) set in a water bath in the ultrasonic cleaner. Let it get up to about 120* and do them one pair at a time. I've never done hydraulics but it works well on solids.
TxRed is offline   Reply With Quote
