Cam gear for Howard's cams hydraulic roller in a Gen 1 small block Chevy - Yellow Bullet Forums
Old 10-21-2019, 02:20 PM   #1
notched
Launchin
notched's Avatar
Default Cam gear for Howard's cams hydraulic roller in a Gen 1 small block Chevy
I just purchased a new hydraulic roller cam from Howard's for a 90s small block with a factory hydraulic roller. Their tech line is telling me I could use either the iron cam gear used on the flat tappet small block or the melonized gear used on the factory hydraulic rollers. I was always under the assumption that any kind of roller cam needed to have the harder cam gear. I am posting to get some opinions from those who have been down this road before. I really don't want to take a chance of trashing a $350 camshaft. Any professional advice would be greatly appreciated!
78 Malibu Classic factory 4 speed
87 Grand National
66 Corvair Corsa turbo
notched is offline   Reply With Quote
Old 10-21-2019, 02:26 PM   #2
Horndog
Default Re: Cam gear for Howard's cams hydraulic roller in a Gen 1 small block Chevy
My personal choice would be the melonized gear.
Also, one trick that is worth doing is to cut a small groove in the dist housing between the oil feed band and the gear. No bigger than 1/8" x 1/8"
Jim Horner
" ...oh no, what the fuck was that?
...the motor ... we've thrown a rod.
...is that serious?
...yup."
I really don't know which is worse ..... all of DOTARD's lies all the time, or all the trumphumpers lapping them up with not even giving them a critical thought
Horndog is offline   Reply With Quote
Old 10-21-2019, 05:56 PM   #3
MN Hemi
The Phantom Machinist
MN Hemi's Avatar
Depends, is it a cast core or a billet 3 piece core with a cast dist gear? If so, you’re fine with an iron or melonized gear.
If it’s a billet one piece core, use the composite gear. I’ve had great results.
MN Hemi is offline   Reply With Quote
Old 10-21-2019, 06:30 PM   #4
RCM Racing engines
RCM Racing engines's Avatar
Default
Seriously....
Have you ever seen how much oil an 1/8" groove would move..
Bad idea, not needed, plenty of splash oil flying around to oil that gear......
Bad advice....
Period.
Just an old' Mennonite..........
RCM Racing engines is offline   Reply With Quote
Old 10-21-2019, 10:43 PM   #5
notched
Launchin
notched's Avatar
I believe the camshaft is ground on a SADI core. Would that make a difference?
87 Grand National
Old 10-21-2019, 11:19 PM   #6
RCM Racing engines
Default
Quote:
If so, that is a soft core, you can run a regular gear.
Did you ask Howard's??
Old 10-22-2019, 12:21 PM   #7
Horndog
Quote:
Originally Posted by RCM Racing engines View Post
Seriously....
Bad advice....
Period.
It's painfully obvious you missed these words ------ "no bigger than".
Jim Horner
...is that serious?
...yup."
Old 10-22-2019, 01:08 PM   #8
kimosabi
Seriously....
Bad advice....
Period.
Only "mod" I do is to grind of casting flash on the cheap distributors. Some have a big enough ridge it restricts oil to the lifters.
kimosabi is offline   Reply With Quote
Old 10-22-2019, 02:34 PM   #9
RCM Racing engines
Default
Quote:
Originally Posted by kimosabi View Post
Seriously....
Bad advice....
Period.
He is talking about from the oil groove that feeds the lifters down towards the cam/dist gear.
Old 10-22-2019, 02:36 PM   #10
RCM Racing engines
Default
Seriously....
Bad advice....
Period.
It's not....
If you are even grinding a 1/16" groove you are moving a shit ton of oil... it's just not needed... Some of you guys create your problems.....
Kinda like a self inflicted gun shot to the chest....
Old 10-22-2019, 07:55 PM   #11
Horndog
It's not....
Been doing that mod for years and never had that first oiling issue.
Jim Horner
...is that serious?
...yup."
Old 10-23-2019, 02:35 AM   #12
kimosabi
I know, was just adding. That extra path is not needed IMO. If anything you're taking oil from the lifters adding to where there is already plenty of oil.
