What bearing for stock crank LS 1000hp - Page 2 - Yellow Bullet Forums
Old 10-19-2019, 02:24 PM   #16
gnx7
Member
Pullin gears
gnx7's Avatar
Default Re: What bearing for stock crank LS 1000hp
Calico coated bearings, stock LS3 style crank, Compstar rods spinning to 7000-7800rpm doing lots of street pulls, LS9 block, about 60-80 1/4 mile track passes and easily 150 1/2 mile passes if you include the street. 3000-4000 miles on it before I snapped the stock crank at 7/8 rod journal (where it is hollow and drilled through after doing a big 1st thru 4th gear burnout and hooking up after letting out of the throttle in gear (T56 Magnum).
This motor had a TC78 on it... then a Precision GTS76 that went 9.20'[email protected] (made just over 1000rwhp maxed out) and now a Precision 88 (T4) (made 1060rwhp at 14psi on e85) that has tons left and went [email protected] with a 1.59 60ft and no traction control and non aggressive boost ramp.
New motor going in with K1 stock stroke and Calico coated bearings again this fall after a 3 year hiatus (self employed and growing my business so no real time for cars).
Street car: FD RX7, PT8847 LS9, T56Mag, Holley EFi, [email protected] 275/50/15 Drag Radial 197mph 1/2 mile
https://www.youtube.com/watch?v=y472n4EbWO0
Street car: FD RX7, LS7, T56Mag, McLeod RXT, Holley EFi [email protected] 165mph 1/2 mile!
2015 project: 1969 Chevelle, alum 5.3 GTS76, Chiseled A/W, T56Mag,9", full cromo cage, 25mpg, a/c, p/s, full interior, 9'[email protected] goal.
***Retailer for Tremec, McLeod, Holley, Molnar, Ohlins, Wilwood, BrianTooleyRacing parts
gnx7 is offline   Reply With Quote
Old 10-19-2019, 05:52 PM   #17
Caseville1
Burnout box
For a forged aftermarket crank I prefer clevite H series over the king XP. I have had many inconsistencies with the XP for bearing clearances. Clevites are always dead on.
Caseville1 is offline   Reply With Quote
Old 10-19-2019, 10:38 PM   #18
short1
Spooled up
I decided to try out the King MB5013XP bearings when I redid my 5.3. I installed them and found the clearance to be .0035 . A bit looser than Id like. I put a set of clevite 2199P bearings in and got .0025. I couldn't tell why the kings were looser; I micd the wall thickness of the 2 brands and they were identical to .0001. Its like the Clevites had more crush and were smaller ID when installed. Weird.
short1 is offline   Reply With Quote
Old 10-30-2019, 05:40 PM   #19
RonSSNova
Launchin
RonSSNova's Avatar
We actually called King about this. They did not recommend the softer bearing. They recommended their coated bearings.
69 Nova 5.3 S476 Billet ([email protected])
2000 C5 10.99 @ 124 LS1
RonSSNova is offline   Reply With Quote
