New personal best, thanks bullet! - Page 2 - Yellow Bullet Forums
Old 10-14-2019, 11:20 PM   #16
camarols1
camarols1's Avatar
Default Re: New personal best, thanks bullet!
Thanks man.
I'm pouring over the logs and I'm honestly stoked about the potential for a sub 8.5x pass on 25psi when I get the 60 in line.
It's been 1.32 on the back tires, so it's a no brainer on a warm track.
It feels great to be motivated about the car again.
I will add the Holley boost control and a chute over the winter.
Now, how greedy do I get with boost?
My gut is telling me 30 ish to the 1/8 then tame it down out the back to help it live?
Stock crank, eagle h-beams with arp2000 bolts, je pistons.
Hmmmm......
79 Camaro 6.0 LSA heads, Twin borg s366's
8.69 @ 160.28 - NEW best pass
1.301 best 60FT ...getting there!
8.69 pass below
https://youtu.be/EwJYvhk7aEo
http://m.youtube.com/user/jimnorman74
camarols1 is offline   Reply With Quote
Old 10-15-2019, 09:17 AM   #17
cam406406
cam406406's Avatar
35lbs all day!!
cam406406 is offline   Reply With Quote
Old 10-15-2019, 01:33 PM   #18
boostedbowtie
boostedbowtie's Avatar
Awesome !
boostedbowtie is online now   Reply With Quote
Old 10-15-2019, 08:11 PM   #19
7secTurboLX
Pre-Staged
Nice job!!
93 LX Twin turbo 347, 275 DRs
7secTurboLX is offline   Reply With Quote
Old 10-15-2019, 08:17 PM   #20
camarols1
camarols1's Avatar
Thanks.
Maybe she's got a 7.99 in her?
8.69 pass below
Old 10-16-2019, 11:34 AM   #21
tblentrprz
Spooled up
RPM is your friend with cam and valve train setup to handle it. Then just feed it boost and fuel. Good luck and well done.
tblentrprz is offline   Reply With Quote
Old 10-16-2019, 11:58 AM   #22
C5 Pete
AMP Racing member
C5 Pete's Avatar
Awesome man! Congrats! Looking forward to results in the spring
2 Weld V series Spindle mount wheels for sale. 15x3.5
99 C5 - work in progress
D&F Performance - Berlin NJ
Brian Tooley Racing
Hi-Tech Tuning
Forced Inductions
C5 Pete is offline   Reply With Quote
Old 10-16-2019, 12:15 PM   #23
camarols1
camarols1's Avatar
Thanks guys!
I'm going to work on improving the 60 and 330 numbers before I throw more power at it.
I can probably knock off a couple tenths with a better launch alone.
8.69 pass below
Old 10-16-2019, 12:28 PM   #24
tempname
Default
What is your finish line rpm. Got room for more gear ratio?
tempname is offline   Reply With Quote
Old 10-16-2019, 01:27 PM   #25
camarols1
camarols1's Avatar
Just over 7k, so I have a little room.
8.69 pass below
Old 10-16-2019, 01:59 PM   #26
camarols1
camarols1's Avatar
Based on this pass, I'm seeing 5.6% slip at 7,109rpm.
That said, I should be ok to right at 170mph with a 7,500 limiter.
8.69 pass below
Old 10-16-2019, 04:17 PM   #27
tempname
Default
If you have more steam to throw at it I would hold off changing gears
Old 10-16-2019, 05:07 PM   #28
camarols1
camarols1's Avatar
Agreed.
I'm not going to change gearing.
8.69 pass below
Old 10-28-2019, 11:04 PM   #29
steel town
steel town's Avatar
I left on 8.5 lbs but only 15 lbs down track. I just broke the pinion so I've changed the gear ratio to 3.70's. Thinking about changing to a glide over the winter. You've done well.
Orange Boost- 6L Twin turbo LS on E85
steel town is offline   Reply With Quote
Old 10-29-2019, 12:08 AM   #30
camarols1
camarols1's Avatar
Awesome ride!
Get her fixed up and back out there in the spring!
Thanks!
8.69 pass below
