What psi radiator cap - Page 3 - Yellow Bullet Forums
Old 09-28-2019, 01:07 PM   #31
Topfun99
Topfun99's Avatar
Location: Temporarily Away, Check Back Later For Updates
Default Re: What psi radiator cap
Quote:
Originally Posted by Coloradoracer View Post
I run a 16 lb cap and zero issues with copper gaskets. Have yet to have one leak...
I personally have no direct experience. I've just run across many comments from users of copper gaskets regarding water leaks.
Try not to take everything so literally. Just because someone suggests it's time to deal with the Elephant in the room doesn't mean you should break out the peanuts.
Thanks to:
HALTECH (Elite 2500 plus REM)
TRZ MOTORSPORTS
REAL STREET PERFORMANCE
FB PERFORMANCE
PTC
M/T Tires
Kris Starnes Racing
EMAIL - [email protected]
Topfun99 is online now   Reply With Quote
Old 09-28-2019, 01:10 PM   #32
Topfun99
Topfun99's Avatar
Quote:
Originally Posted by boostedbowtie View Post
Is it normal to still have pressure in the system , even after sitting for 5 days or so ?
Started noticing this after putting a new cap on .
Its a 16lb lever style cap like this
Dave - When I had that happen to me on my car it was the result of water reacting with the system metals. Let's put it this way, I've never had that happen when my car had anti-freeze in the cooling system.
Thanks to:
TRZ MOTORSPORTS
FB PERFORMANCE
PTC
M/T Tires
Kris Starnes Racing
Old 09-30-2019, 07:41 PM   #33
1leg
Member
Pullin gears
1leg's Avatar
Garage
Quote:
This is correct. you are likly having a chemical reaction with something in your coolanat system. Complety drain and flush and just use plain water(if you have good local water) and a little bit of coolant.
https://www.aa1car.com/library/cooli..._corrosion.htm
1leg is offline   Reply With Quote
Old 10-01-2019, 01:24 AM   #34
MN Hemi
The Phantom Machinist
MN Hemi's Avatar
Depends on the head gasket too. If youíre using copper head gaskets, keep it at or under 8#. They can weep otherwise. The cylinders seal up fine, but the water can weep.
On everything else I run, I use a 16# cap with no problems.
MN Hemi is offline   Reply With Quote
Old 10-01-2019, 01:33 AM   #35
MN Hemi
MN Hemi's Avatar
Quote:
Originally Posted by Kane View Post
Why the lower pressure for copper gaskets??
What Iíve seen is, with copper and o rings, the cylinder gets good pressure to seal, but the water jackets can weep.
The problem is a little more common with aluminum blocks. The sleeves generally are .004Ē proud on the deck and reduces the clamping force around the water jacket. Also, many times the factory surface on the block before the sleeves go in is less than perfect, and then distorts a little from the press fit. They are always much nicer when we're able to correct the deck nice and then install the sleeves.
On my Mitchell X block, it will weep a little bit when it first goes in the car after freshen. Quits leaking after a few heat cycles and I also add a sealant tablet to the system. Itís not much, like a little drip on a corner or something, and then none. I use an 8# cap.
Iron blocks with a good finish are way less likely to leak, but being copper is dead soft, it will give over time. They can develop a leak with a high pressure cap occasionally.
Old 10-11-2019, 03:36 PM   #36
blackmagicturbo
Member
Pullin gears
blackmagicturbo's Avatar
Garage
The fastest 4.6 modular engine builder in the world told me that you want higher pressure to push water to the metal surfaces of the engine under power, so there is no steam. i run a 30+ pound cap.
blackmagicturbo is offline   Reply With Quote
Old 10-11-2019, 05:46 PM   #37
brmustang
Do you think it’s possible it is creating a vacuum as it cools down?
brmustang is offline   Reply With Quote
Old 10-12-2019, 03:00 PM   #38
Topfun99
Topfun99's Avatar
Quote:
That's a funny way to say "higher pressure raises the boiling point temperature".
Thanks to:
TRZ MOTORSPORTS
FB PERFORMANCE
PTC
M/T Tires
Kris Starnes Racing
Old 10-12-2019, 03:03 PM   #39
Topfun99
Topfun99's Avatar
Quote:
Originally Posted by brmustang View Post
Do you think itís possible it is creating a vacuum as it cools down?
A properly functioning radiator cap will not allow the system pressure to go much lower then atmospheric pressure as long as the water height in the overflow reservoir to close to the same height as the top of the radiator.
Thanks to:
TRZ MOTORSPORTS
FB PERFORMANCE
PTC
M/T Tires
Kris Starnes Racing
Old 10-15-2019, 12:35 PM   #40
1leg
Member
Pullin gears
1leg's Avatar
Garage
This is why in some boosted applications a mechanical driven water pump works better then and electric water pump. Most electric water will only create about 5psi if you deadhead it. A mechanical pump can create 20psi or more. This is why I will almost alway recommend a mechanical water pump on land speed race cars.
