List your 93 octane boost, compression and timing - Page 2 - Yellow Bullet Forums
Old 09-23-2019, 11:40 PM   #16
TurboII
TurboII's Avatar
Garage
Default Re: List your 93 octane boost, compression and timing
I built this one but didn't tune it. Stock ECU.
5.7L LS6
838rwhp
Stock unported heads
Stock crank
YSI pulley'd down to only make 21psi max
18*-19* @ 21psi
A2A IC in C5 Vette
9.6CR
235/247 .620"/.623" 116*LSA
Leader of the Methanol Mulisha
KINETIC RACECRAFT
"Turning your potential into motion"
[email protected]
Dealer for: Haltech EFI, Billet Atomizer Injectors, ProTorque Converters
Coming Soon - 6000HP Mainline Pro Hub Dyno
Manifold EFI conversions, Fuel Hoop installation, Dry Deck Conversions, LS/LSX 1/2" Stud Conversions
Custom crimped AN hoses
"He who is without oil shall throw the first rod."
-Compressions 11.5:1
TurboII is offline   Reply With Quote
Old 09-28-2019, 01:23 PM   #17
boostedbowtie
boostedbowtie's Avatar
20 degrees at 18psi with 93
388 sbc , AFR195 heads
-15 custom dish JE pistons
copper gaskets , o-ring block
water to air , no ice
small shot of Boost Juice starting at 13psi
Conservative on the street as it doesnt need to be on the edge .
Track tune is on 34psi of boost , so no pump gas there . No water meth either . Ice and C16 .
boostedbowtie is online now   Reply With Quote
Old 09-28-2019, 01:31 PM   #18
Screwblower
Quote:
Originally Posted by midnightlaundry View Post
Here we go, shut the fuck up.. If you don't like the topic, then fuck off..
Go fuck yourself.
You fuck a lot threads with your little dick attitude.
Screwblower is offline   Reply With Quote
Old 09-29-2019, 03:06 PM   #19
redvictor
from across the pond...
redvictor's Avatar
Garage
Back in the day 12 years ago. 7.7s at 190 mph. 3400 lbs on bfg radials. Same car ran 7.41 at 197mph on Q16 and ET streets, same weight. Approx 2200hp.
540ci BBC
8.5 to 1
28psi on Hybrid Holset turbos
19deg timing
11.2 afr
Bosch injectors
Electromotive ECU and Ignition.
Powerglide trans.
Gone from this place...
redvictor is offline   Reply With Quote
Old 10-07-2019, 08:54 PM   #20
midnightlaundry
midnightlaundry's Avatar
Quote:
Originally Posted by Screwblower View Post
Go fuck yourself.
You have over 15,000 post's in 3 years. Nobody is on here crying like a bitch more than you, asshole..
Get off you're fatass and do something else beside hide behind your keyboard..
YBTOBT.. Land of the Desktop Baller..
midnightlaundry is offline   Reply With Quote
Old 10-07-2019, 11:46 PM   #21
Screwblower
Stop little girl.
Old 10-08-2019, 09:48 PM   #22
93hatch
93hatch's Avatar
you bumped a 10 year old thread then attack someone calling you stupid
93hatch is offline   Reply With Quote
