Quiet down 4" exhaust - Yellow Bullet Forums
Old 10-21-2019, 08:56 AM   #1
forcd02
forcd02's Avatar
Default Quiet down 4" exhaust
Trying to quiet down my truck, has a 6.0, turbo, and 4" exhaust to the rear bumper.
I have one round, straight thru Dynomax (22" case) before the rear, and another 12"
after the rear, then a short tailpipe. Trying to get the cab quieter, def going to do a lot
of insulating this winter, hopefully that helps that part. I was thinking of splitting the exhaust
into dual 3" and mufflers, not sure how much that helps. There was a muffler that had a flap
inside, open up under pressure, but finding 4" stuff reduces choices. They make some diff.
valves that open by pressure, or elect. I know the Hellcats used something to open up the
exhaust in perf. mode. Curious what guys are using to quiet things down, yet avoid
exhaust rests.
when your credit cards are max\'ed-call and raise the limits
forcd02 is offline   Reply With Quote
Old 10-21-2019, 11:35 AM   #2
Briansshop
Briansshop's Avatar
Default Re: Quiet down 4" exhaust
Trucks are hard to get the drone out of,I guess the bed has to do with it. I took the single 4" off of mine a did a 3" dual,and was much better.
SBE 351W 10.26/134, 4280lbs
Briansshop is offline   Reply With Quote
Old 10-21-2019, 04:43 PM   #3
93hatch
93hatch's Avatar
Giant diesel straight through muffler
93hatch is offline   Reply With Quote
Old 10-21-2019, 05:06 PM   #4
my69brd
Chief Curmudgeon
my69brd's Avatar
Inyati bed liner in the bed
About as light as you'll get
Dynomat the behind the rear seats
(I know it's not light but it really works)
JMHDAO
my69brd is offline   Reply With Quote
Old 10-21-2019, 08:18 PM   #5
Or this .
[IMG]Picture083 by David Cedoz, on Flickr[/IMG]
Old 10-21-2019, 09:55 PM   #6
forcd02
forcd02's Avatar
Originally Posted by boostedbowtie View Post
Or this .
Thats kind of what Im thinking, split it up-did that to my Nova, was pretty quite, but the mufflers were baffled, rested.
Old 10-21-2019, 10:49 PM   #7
Lumbergh
Lumbergh's Avatar
If you run a kill pipe/cancel pipe or two it might help, but it won’t be a huge difference with a 4” system. This would be a pipe plumbed into the exhaust pipe but running next to it with a capped end to kill/cancel exhaust pulses. Tough to explain, but I’ve seen it used before to eliminate drone on smaller systems and it works.
Edit: found a pic on the net, they call it a “side branch” https://www.yelp.com/biz_photos/blak...MPvk0TP8xN8tyQ
Fuck you Greta!
Lumbergh is offline   Reply With Quote
Old 10-21-2019, 11:32 PM   #8
302StrokerGT
302StrokerGT's Avatar
although its a car a i run a 3in side exit with a magnaflow rectangle/box straight through muffler for daily driving but i have a 4in bumper exit downpipe with a 4in loud valve that opens under boost.
Your Mom Says Hi
Me2 Machine (2)
DDS powder coating and bead blasting
In Gear Transmissions and Differentials
202 east main st
manasquan, NJ 08736
732-722-7387
302StrokerGT is offline   Reply With Quote
Old 10-22-2019, 10:15 AM   #9
vw_chuck
Try necking it down to 3.5" and running a moroso spiral flow muffler. No restriction and they quiet down the exhaust using noise canceling technology. Pretty cool technology for a muffler actually. I run one and it works great.
vw_chuck is offline   Reply With Quote
Old 10-22-2019, 11:06 AM   #10
Orr89rocz
Thats helmholtz resonator tuning. If you know the frequency you are trying to eliminate you can calculate the volume and sizes of the resonator chamber to attach to your exhaust
1989 Camaro IROCZ
400" sbc twin turbo
8.24 @ 169 street car
Orr89rocz is offline   Reply With Quote
Old 10-22-2019, 01:30 PM   #11
forcd02
forcd02's Avatar
I have heard about that, didn't know if it really worked. Some good suggestions.
Old 10-22-2019, 03:17 PM   #12
vw_chuck
That is how the spiral flow muffler also works. It splits the flow and gets half the flow out of phase with the center flow and they cancel each other out when they are reintroduced to each other at the exit of the muffler. Plus they don't cost much.
Old 10-22-2019, 06:48 PM   #13
stevieturbo
I tried 3" Moroso Spiralfow's a few years back.
Unbeknown to me at some point internally they collapsed leaving only the centre hole of around 1.5" inside them
Strangely...never noticed any change in performance.
And this didnt take years...I'd say it must have been weeks or months. Do not use spiralflows.
Really...as big a muffler as possible, I found the perforated tube/packing quieter than any chambered design too.
blow me
https://www.youtube.com/watch?v=Ss_c7fML3rw
What the f****
stevieturbo is offline   Reply With Quote
Old 10-22-2019, 09:34 PM   #14
Tom89lx
Just put a good muffler system on it. I split my car's 4" downpipe into two 3" into Borla XS mufflers (straight through ovals) and it is quiet as can be. Easy handle over 1000 HP with almost no change in pressure from a dump. It isn't even worth using a cut out.
Just be careful how you do the split.
Tom89lx is offline   Reply With Quote
Old 10-23-2019, 01:33 PM   #15
vw_chuck
Yes they have a 1.5 inch hole down the middle and a spiral channel around the outside of the 1.5 inch tube down the middle. half the flow goes down the middle and half goes around the outside. Nothing "collapsed" that is how they are new. You obviously didn't build the system or put them on yourself or you would know this.
