battery cable thickness - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Electrical
Old 06-25-2019, 12:56 PM   #1
gmo917
gmo917's Avatar
Default battery cable thickness
so over the weekend i had some battery cable/power switch issues.
im just wondering what everyone is using for the master power switches and batter cable thickness. fine wire or course wire?
gmo917 is offline   Reply With Quote
Old 06-25-2019, 05:55 PM   #2
juiced coupe 78
juiced coupe 78's Avatar
Default Re: battery cable thickness
I use a 4 post Cole Hersee switch. 1000 amp intermittent and 125 amp continuous, with 20 amp small contacts. The large posts only handle starting loads and whatever current is required to maintain the battery. The smaller posts actually shutdown the car at the ignition.
I used 2 gauge welding cable when I wired my car years ago and didn't know any better. If I were to do it again, I'd probably use 1/0 cable. The 2 gauge has never given me any problems, but I attribute that to it being a small block with strart retard and a PMGR starter.
juiced coupe 78 is offline   Reply With Quote
Old 06-28-2019, 06:02 PM   #3
gmo917
gmo917's Avatar
i had XS Power fine wire 2 gauge in it and over the weekend it started to smoke while trying to start the truck. so i cut the cable and ran it straight to the battery. the truck started 10x better then it ever has. now i dont know if thats from the wire being to small or the master swtch. but it needs to be addressed before the next event.
Old 06-28-2019, 08:53 PM   #4
juiced coupe 78
When my old switch failed, it caused a lot of resistance and caused the pre-made battery terminal to fail. It failed where the cable was factory mated to the terminal.
After replacing the bad switch, I also converted to mil-spec terminals with crimped lugs on the wires.
Old 06-29-2019, 04:53 AM   #5
aukai
Mike
aukai's Avatar
CEAutoelectric Tony knows his stuff, and has great products.
https://ceautoelectricsupply.com/
Mike Lewis street 572 with Holley EFI
http://www.lewisracingengines.com/
Cale Aronson
http://www.blackmagicclutches.com/
Marcella Manifolds
UDHarold, .456 x 1.8/1.7
GF5R,3 pedals
Menscer Motorsports
http://menscerms.com/
Ultra Carbon
http://www.ultra-carbon.com/
aukai is offline   Reply With Quote
Old 06-29-2019, 09:21 AM   #6
Coloradoracer
Coloradoracer's Avatar
I'm using a flaming river Big Switch, and use 4/0 welding cable, 16v system. Not an issue at all, but I also run dedicated grounds, not through the chassis.
Mark Goulette
Owner and driver, Livin' the Dream Racing Dragster
Speed kills but it's better than going slow!
www.livinthedreamracing.com
Authorized Amsoil Dealer
Coloradoracer is online now   Reply With Quote
Old 06-30-2019, 01:05 AM   #7
gmo917
gmo917's Avatar
so i ordered the flaming river big switch and got some 1 gauge fine strand welding cable like you said. hopefully that fixes my issue. thanks for the feedback!
Old 06-30-2019, 01:06 AM   #8
gmo917
gmo917's Avatar
[QUOTE=Coloradoracer;71052585]I'm using a flaming river Big Switch, and use 4/0 welding cable, 16v system. Not an issue at all, but I also run dedicated grounds, not through the chassis.[/Q
what do you mean dedicated grounds?
Old 06-30-2019, 11:48 AM   #9
djh61187
djh61187's Avatar
[quote=gmo917;71056317]
Straight to to battery, Not to to frame,firewall, fender etc.
"The trouble with our Liberal friends is not that they're ignorant, it's just that they know so much that isn't so." - Ronald Reagan
In a Capitalist Society the Guns are Pointed Out.
In a Socialist Society the Guns are Pointed In.
- Andrew Wilkow
"I don't understand how people who cannot predict the weather five days in advance can predict the climate decades from now." -Thomas Sowell
djh61187 is offline   Reply With Quote
Old 06-30-2019, 02:26 PM   #10
Topfun99
Topfun99's Avatar
Location: Temporarily Away, Check Back Later For Updates
On my car I run 2 grounds. One to the rear frame directly below the trunk and a long cable all the way to the front of the car that goes directly to a stud on the cylinder head.
Most of my other grounds come directly from that stud also but I do have the original OEM ground strap on the opposite cylinder head.
Try not to take everything so literally. Just because someone suggests it's time to deal with the Elephant in the room doesn't mean you should break out the peanuts.
HALTECH (Elite 2500 plus REM)
TRZ MOTORSPORTS
REAL STREET PERFORMANCE
FB PERFORMANCE
PTC
M/T Tires
Kris Starnes Racing
EMAIL - [email protected]
Topfun99 is offline   Reply With Quote
