76mmT4 street Nova runs 8.3/163.75 2nd time out. - Page 9 - Yellow Bullet Forums
Old 07-31-2013, 10:13 AM   #121
Johnston Motorsports
Johnston Motorsports's Avatar
Default Re: 76mmT4 street Nova runs 8.3/163.75 2nd time out.
Quote:
Originally Posted by Mark J View Post
When the 4850 pound truck, (that everybody wanted to sweep under the rug) 4 wheel drive, tranfer cased, 480LE, air conditioned fully loaded truck went out and ran 145 mph, really, what did you guys think think the same engine setup was going to run in a 3300-3350 pound power glided car? LOL, Im going to explain what your seeing here, and its really quite simple, and its not going to be well accepted, but here goes: this is what happens when you combine using a different approach with some intelligences, with a STRONG BACKGROUND IN NA ENGINE BUILDING then put a turbo on it, thats what your seeing, pure and simple. Think about it, gear it high, tighten the converter to make it more efficent, cam it small to spool, then foot brake it, run it low RPM, no tranz brake keeps the stock short block together. Look for it to go faster. Nice work Jarrett.
you forgot to mention the nitrous
Johnston Motorsports is offline   Reply With Quote
Old 07-31-2013, 10:17 AM   #122
Quote:
Originally Posted by DrTurbo View Post
New stuff coming on the for this car...... . Time to step up the turbo game once again. Shooting for 170mph out of a T4 , 76mm.
How far does the tip to tip dimensions of the turbo stay 76mm?
Do you have specs like inducer/exducer?
Old 07-31-2013, 10:17 AM   #123
Mark J
Mark J's Avatar
Quote:
Theres no nitrous there, just common sense.
You're only as good as your worst employee
[URL="http://www.VortecproPerformance.com"]
Career Test/N/Tuning at it's best
Mark J is offline   Reply With Quote
Old 07-31-2013, 10:45 AM   #124
DrTurbo
DrTurbo's Avatar
True 76mm wheel....no cut down. Exducer is 102mm at base. Tips extend beyond floor.
Forced Inductions.com
1-(256)-796-1230
1-(256)-658-5798
Authorized Distributor/Dealer and Builder of:
Garrett
Borg Warner
Holset
Turbonetics
Precision Turbo
Mitsubishi
Rajay
IHI
DrTurbo is offline   Reply With Quote
Old 07-31-2013, 11:00 AM   #125
Stock48
Wouldn't be the 1st 2nd, or 10'th time I have been accused of nitrous. Used to bother me yrs ago but nowdays I just take it as a complement....
72 Nova JFR 365 CI, 7.89/176.8, foot [email protected] lbs.
-2003 GMC 4x4,SBE 6.0L, JFR 3x12 cam, PY3400, Cast 76mm, 9.73/140, 4860 lbs.
JFRacing custom camshafts, Tq converters, Forcedinductions custom turbochargers, and Racetec pistons.
Stock48 is offline   Reply With Quote
Old 07-31-2013, 11:06 AM   #126
cam-
Back to some tech here. What injectors are you running on that thing? Cant recall if I saw that listed somewhere or not. Looking forward to more vids
cam- is offline   Reply With Quote
Old 07-31-2013, 11:10 AM   #127
Stock48
Quote:
Damn I was wanting more complements lol
Car has fic 2000 cc's.
Old 07-31-2013, 11:22 AM   #128
2baditsnotachev
2baditsnotachev's Avatar
What rear gear are you running? Sorry if you've already said.
2baditsnotachev is offline   Reply With Quote
Old 07-31-2013, 11:25 AM   #129
cam-
Got some pics of the engine bay? Gotta see how this is set up, very inspiring build
Old 07-31-2013, 11:40 AM   #130
Stock48
https://www.yellowbullet.com/forum/sh...d.php?t=588344
Old 07-31-2013, 11:45 AM   #131
skinnies
Member
Pullin gears
Holley efi and fic2000's here also, idle great! People shouldn't be afraid of that big of an injector on a street car!
rx7 - junkyard 5.3 with 76mm - 8.65 at 167.9 mph, first LS stock shortblock in the 8's. (sold)
1985 Ford LTD "4 door hooptie" - 9.79 at 144.6 on 235 drag radials and thru 6 mufflers
1989 fox - 9.00 at 163 on true radials(mud and snow tires)
skinnies is offline   Reply With Quote
Old 07-31-2013, 11:49 AM   #132
Stock48
Quote:
Thing purrs like a kitten at 800 rpm. Sounds just like your typical 13 sec resto rod lol.
Old 07-31-2013, 12:14 PM   #133
zbrown
congrats man!
i dont see why the fuss, looks like it is a true 1k whp
seems well in the realm with a proper setup and a stout 76 with his boost level
would share what the exhaust lobe looks like? just curious
Vbox whore FC
TT cummins
zbrown is offline   Reply With Quote
Old 07-31-2013, 01:45 PM   #134
CSIMS87T
Launchin
Car looks and performs great.Novas is still one of my fav rides. just dont let all the haters mess it up. it takes alot of test hits and tuning to get to where he is. nice job and concrats to you and crew.
CSIMS87T is offline   Reply With Quote
Old 07-31-2013, 03:49 PM   #135
jleews6
Its funny you say this because this is the exact thing I have always said about the Buick Grand Nationals. They dont use high rpms to scream down the track,instead they do just what you explained (on a smaller scale) and let the motor pull down the track. High gear,small cam,tight converter,foot brake and low rpms and a stock 3.8 V6 can pull a big heavy car to some surprisingly good times.
jleews6 is offline   Reply With Quote
