AMS-2000 - Page 9 - Yellow Bullet Forums
Old 02-07-2014, 08:27 PM   #121
control freak
control freak's Avatar
Default Re: AMS-2000
Late model vehicle can bus interface for mph and engine rpm for ams2000! This allows a connection into obd2 ports or hard wired into the can bus of over 40 vehicle manufacturers and 350 different models that use can bus. No need for fitting a wheel speed sensor or trying to pick up engine rpm from a coil etc . This unit will provide the info to the ams2000 . Most street cars today have abs and sealed hubs with no access to anything for wheel speed.
Makes the installation on a street car that much easier!
Size of interface below . Then a picture of a interface built into the harness with a OBD2 plug set up. True plug and play.
AMS-2000
Manufacture of the AMS-2000 Management System for BOOST and NITROUS
www.amsboostcontrol.com
www.nmsnitrouscontrol.com
control freak is offline   Reply With Quote
Old 02-08-2014, 07:54 AM   #122
Blitzkrieg Motorsports
Blitzkrieg Motorsports's Avatar
Will the interface log any other channels of data from the factory vehicle ecu?
Dennis Equitz
Caledonia, WI
262.835.1339
[email protected]
www.blitzkriegmotorsports.com
Precision Turbo, NLR, Big Stuff; Holley EFI, F.A.S.T., Strange Engineering, R.J. Race Cars/Quartermax Components, Deutsch Connectors, Pro-Glass Windows, SPD Exhaust, Racepak, Stroud, Prolite Batteries and many more!
WE ARE NOW A DEALER FOR PROLITE BATTERIES - CALL US FOR YOU BATTERY NEEDS!
--Custom Laser Cutting, Machining, and Design Services--
Blitzkrieg Motorsports is offline   Reply With Quote
Old 02-08-2014, 09:56 AM   #123
control freak
No it is specifically only to bring in speed and rpm . Once we finish up the CAN software completely we will be able to bring everything in.
AMS-2000
Old 02-08-2014, 09:49 PM   #124
JOHNBOY66
Smoked another CTD
JOHNBOY66's Avatar
Quote:
Oh Hell Yes!
Any chance that will work a GM 411 PCM(2002 LS1b Truck PCM?
If so then you just made things simpler. Any chance of getting driveshaft RPM form stock VSS tailshaft sensor later on?
Great work!
2003 GMC Sonoma LQ4 6.0/4l80E
With stuff from.
Nitrous Express
Precision Turbo
TRZ motorsports
NGM Diesel
EFI Live
Current Performance
Liljohn
Injector Dynamics
Hutter Racing Engines
Quote:
Originally Posted by unlimited View Post
This is why you should only build generic junk for the masses because really thats all they can handle! The moment they feel insecure straight to the key board they go! Being creative and trying to push stuff is only worth doing for yourself.
JOHNBOY66 is offline   Reply With Quote
Old 02-09-2014, 10:23 AM   #125
control freak
I do not think 2002 had can bus so it will not work however I may be wrong. This is something you will have to check. Vss sensor is something you can pick up now by hardwiring the signal with one wire
AMS-2000
Old 02-17-2014, 01:47 PM   #126
3QTR LBS
Launchin
3QTR LBS's Avatar
Just curious why datalogging AFRs isn't allowed with the basic. Is there a way to make it work without upgrading to pro? I'm doing blow thru so I would like to be able to do that without spending the extra coin on the pro.
3QTR LBS is offline   Reply With Quote
Old 02-17-2014, 02:22 PM   #127
control freak
No the pro is what offers all the datalogging , offset functions, user programmable outputs as well as gmeter and selector switch. In order to get the data package the pro must be purchased. If you want to save some money we can do a pro without a selector switch ? Just call the shop and let us know.
Thanks,
Seb
AMS-2000
Old 02-23-2014, 07:17 PM   #128
control freak
Congrats to Ktrtturbo, Josh Ledford(crew chief) and Drag 965 team on the superstreet 8 Qatar racing championship and record at 4.31- AMS2K all the way!
AMS-2000
Old 02-23-2014, 07:57 PM   #129
control freak
AMS-2000
Old 03-12-2014, 05:16 PM   #130
control freak
Installed a ams2k on this guys prostreet bike. Hes not a small guy 215 lbs in shorts. Quickest he has ever gone! Had an ams1000 before.
AMS-2000
Old 03-23-2014, 12:44 PM   #131
control freak
Battle of the States!
Top two qualifiers in x275- Fisher and Bruder Brothers ! Bruder brothers took the record with a 4.520 and minutes later Fisher takes it with a 4.519!
Top two qualifiers in ODR- Mullins and Valden! Mullins sets a new record at 4.110 with Valden on so very close with a 4.12!
AMS2k- its not hype! Its all fact!
AMS-2000
Old 03-28-2014, 09:40 PM   #132
control freak
"So how can the ams2000 be so much better than the ams1000 ? "-I get asked every single day.
My answer is pretty simple. The ams1000 was designed in 2004 and it is now 2014. I then proceed to ask what turbo they have on the vehicle. The answer is always the same. Latest and greatest from Precision Turbo or Garrett , Borg Warner, or whomever. Hell some guys have told me they just sold the new release stuff from the middle of last year to get the newest stuff these companies released. I tell them to take those turbos off and get some turbos from 2004. They just laugh and say your crazy. I also laugh and say your even crazier lol. Then it hits them that they just answered the question.
The technology and capability in the 2000 is unmatched and is 10 years ahead of its time. A base unit 2000 is 375 more than a 1000 and will absolutely murder it and anything else out there as well. Want all the features go with the pro. Both offer extremely well thought out software that looks professional and is very easy to use. Base unit can be upgraded at any time to a pro unit via code. Add a 5 position selector switch to pull up tunes on the fly to a base unit and your all in at 1480.00
Version 2 beta software and firmware on the website. YOU MUST ERASE ALL AMS SOFTWARE FROM YOUR COMPUTER WHEN YOU UPGRADE. ALWAYS DO BOTH A SOFTWARE AND FIRMWARE UPGRADE ANYTIME YOU DOWNLOAD. INSTRUCTIONS ARE IN THE MANUAL.
Features:
Manifold pressure limitation capability- If your racing in a organization that requires boost pressure limitation and that tech password locks it you will need to use our 100 psi spec sensor for the manifold. If you want to use the limitation with out password lock you can do so with any sensor.
Manifold pressure targeting strategy- Plot an actual boost curve
NLR GHOST control algorithms - So fast you gotta see it to believe it. You thought the current 2000 control is fast.... just wait. Those who have seen it in action know what IM talking about.
AMS-2000
Old 03-28-2014, 11:24 PM   #133
Jimefam
Jimefam's Avatar
Do you know if your obd2 adapter could work with a 13 gtr? And in that car I have switched to the motec ecu, will that affect how it works with the obd2?
Jimefam is offline   Reply With Quote
Old 03-29-2014, 09:21 AM   #134
control freak
OBD2 will with a factory ecu but not a motec and obd2. Unless motec uses a standardized can messaging now.
AMS-2000
Old 03-29-2014, 11:14 AM   #135
Husted Motorsports
Outlaw Drag Radial
Husted Motorsports's Avatar
Time to start saving for a 2000
1993 LDR Mustang
Lights Out 6 ODR Winner
No Mercy 3 & 5 ODR Winner
2013 & 2014 Track Champion ODR-Bradenton Motorsports
2012 Runner Up LS/ODR-Bradenton Motorsports
2011 Track Champion ODR-Sunshine Dragstrip
Thanks To: My Wife #ballerwife,AMS2000, TRZ, Nelson, M&M
Husted Motorsports is offline   Reply With Quote
