Twin Coyote Build - Page 8 - Yellow Bullet Forums
Old 12-12-2012, 09:50 PM   #106
Greg 1320'
Greg 1320''s Avatar
Default Re: Twin Coyote Build
They sell a radius that tight? It's what I had on the shelf to work with.
Twin Coyote In The Works......
Old set up "TwinBullitt" 281ci mod motor [email protected] on E85
http://www.youtube.com/watch?v=wyQdmMCHlmw
Greg 1320' is offline   Reply With Quote
Old 12-13-2012, 04:20 PM   #107
Greg 1320'
Greg 1320''s Avatar
Passed the smoke test....
Old 12-13-2012, 05:04 PM   #108
6T6mustang
6T6mustang's Avatar
absolutely, you can get dounuts also that are REAL tight. or, you could have swept the bends together into the merge the other way to use a larger radius. keep at it, lookin good..
6T6mustang is offline   Reply With Quote
Old 12-13-2012, 05:13 PM   #109
FoPar
Launchin
FoPar's Avatar
much progress in such little time, ur working too quick, slow down makes others look bad
lookin' good, keep up the great work.
Coming Soon:
Outlaw 10.5 Daytona with an E98 drinking 4.6L 4V Ford Modular DOHC V8 and Twin Precision PT7675 turbo's!
2014 Goal:
get the cunt out racing!
FoPar is offline   Reply With Quote
Old 12-13-2012, 06:39 PM   #110
Greg 1320'
Greg 1320''s Avatar
I have only been working on it a hour here and there after hours. During the day tuning cars and built this one the last week.
Old 12-15-2012, 09:58 PM   #111
Greg 1320'
Greg 1320''s Avatar
Had a couple hours to work on the car today. Mounted the y-block, hooked up the coolant crossover I made, and dummy fit the shifter. I am going to hook the parachute cable to the ebrake lever.
Old 12-16-2012, 02:14 AM   #112
D1TKO
D1TKO's Avatar
Quote:
I was under the impresion that it was ilegal to mount fuel related components in the firewall are.....
D1TKO is offline   Reply With Quote
Old 12-16-2012, 10:20 AM   #113
doctorace1
Launchin
what size rear tires you running in the back?
doctorace1 is offline   Reply With Quote
Old 12-16-2012, 12:03 PM   #114
Greg 1320'
Greg 1320''s Avatar
I have seen a lot of cars faster then this with a yblock right there. Hopefully tech doesn't give me problems, its really the only clean space avail for it.
Rear slicks are 28x11x15.
Old 12-16-2012, 12:32 PM   #115
Briansshop
Briansshop's Avatar
Wouldn't it need to be SS braid to be there?
SBE 351W 10.26/134, 4280lbs
Briansshop is offline   Reply With Quote
Old 12-16-2012, 01:16 PM   #116
Turbo 70 Camaro
Turbo 70 Camaro's Avatar
Quote:
yes, hope its okay for you greg. Where is your shop ?
70 Camaro RS BBC, 91mm, Holley HP, tial..................... in progress
03 Dodge 3500 SRW 4x4(http://www.thecarlisuspension.com/do...ominator3.html)
Turbo 70 Camaro is offline   Reply With Quote
Old 12-16-2012, 01:20 PM   #117
Greg 1320'
Greg 1320''s Avatar
Quote:
Downey. Worse case scenario I will just have to switch those two lines.
Old 12-16-2012, 01:41 PM   #118
luv2xlr8
luv2xlr8's Avatar
SS line by the bell housing or any other line with a steel/chromoly tube to protect it. if you have the y block there it technically isnt legal but if you dont fast it to the firewall its technically not mounted lol. im serious
TROY @ RACEWIRES
JACE @ ACCELERATED MOTORSPORTS & PERFORMANCE
LIL JOHN'S MOTORSPORT SOLUTIONS
JOSE @ FORCED INDUCTIONS
LENNY @ ULTIMATE CONVERTERS
RON/RON @ R&W ENTERPRISES (MOTOR)
luv2xlr8 is offline   Reply With Quote
Old 12-27-2012, 09:25 PM   #119
Greg 1320'
Greg 1320''s Avatar
Just need to run the lines back to the tank and fuel system is done.
Old 12-27-2012, 10:29 PM   #120
98 blk/blk
Pre-Staged
Put a 8.5 tire on it .... haha Looks good buddy!!!!!
98 blk/blk is offline   Reply With Quote
