Wiring trans break to digital6? - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Electrical
Old 10-18-2012, 03:30 AM   #1
cornfeed
Default Wiring trans break to digital6?
I know the soleinod on the trans has 2 wires one is a ground but does the other go to power or the wire from the 2 step in the 6 box and still need power?
cornfeed is offline   Reply With Quote
Old 10-18-2012, 11:14 AM   #2
369dragster
369dragster's Avatar
Default Re: Wiring trans break to digital6?
12 volts to one side of the button
Other side of the button needs to be split.One wire goes to the digital 6 launch rev limiter,then the other wire goes to one side of the trans-brake solenoid.
Ground the other side of the trans-brake
Unless you are using a delay box then it depends on which one.
Ken
369dragster is offline   Reply With Quote
Old 10-18-2012, 02:07 PM   #3
cornfeed
Yea no other stuff hooked to it thanks I'll give it a try
