The New Holley Dominator Fuel Pump 12-1800 - Page 45 - Yellow Bullet Forums
Old 06-23-2018, 11:25 PM   #661
Tom89lx
Spooled up
Default Re: The New Holley Dominator Fuel Pump 12-1800
I just saw this. I ran an 1800 for two years now. Some street mostly strip. I just pulled it because at 800 lbs/hr it is only good to about 55-60 psi. It dead heads 75-80 psi in a 12V system.
I replaced it with a MagnaFuel 750 EFI pump. The 750 EFI does way better. It dead heads over my gauge limit of 100 psi (but takes a ton of current) and has no trouble at 900 lbs/hr at 70 psi.
I wish these companies would publish flow charts.
Tom89lx is offline   Reply With Quote
Old 06-24-2018, 08:03 AM   #662
forcd02
forcd02's Avatar
I ran the Holley 12-1400 for 3 years, had it level with the bottom of the sumped tank,
and dual relays. I had the pumps staged, sec. one came on with boost. I had switches
on the dash so I could man. turn on/off pumps also, incase one failed. On my new build
I went with dual AEM 380's, my thinking was if one failed, I could just replace it as opposed
to a whole pump assembly. But the 1400 served me well.
when your credit cards are max\'ed-call and raise the limits
forcd02 is offline   Reply With Quote
Old 06-24-2018, 08:16 AM   #663
boostedbowtie
boostedbowtie's Avatar
Mine burned up . Holley blamed my wiring .
Yea right .
Just glad it didnt burn to the ground .
boostedbowtie is offline   Reply With Quote
Old 06-24-2018, 09:55 AM   #664
taco33150
Aem seems like a better choice
taco33150 is offline   Reply With Quote
