#136 |
Great thread, I have one showing up this week!
'66 Chevelle 300 Deluxe post - 582 pump gas w/ F2 blow thru Just a simple 8 sec street car |
Sponsored Links | |||
Advertisement |
#137 |
Spooled up
I am seriously considering dumping the a1000 and running this pump instead. Great thread with lots of really good feedback
64 Dodge Polara - Drag Week Build Aluminum gen3 426 Hemi Twin Turbo Follow my build https://www.yellowbullet.com/forum/sh...=879834&page=5 |
#138 |
Boss
I'll be running two on my car. Let me know if I can help you guys.
#139 |
Launchin
What Holley reg has two inlets and 1 outlet that you guys are running?I am fixing to order the 12-1800 pump and hit a y to feed both rails but i do not see one listed on their website and the wait time is terrible to talk to them.I know aeromotive and fuel lab both have one but dont see a holley listed.
#140 |
Boss
You can plumb the Holley 12-848 so that one rail enters the "inlet", one rail enters the "outlet", and the return is common.
#141 |
Pre-Staged
anybody use a boost-a-pump with these holley 12-1800s? i have a ls 390/billet s480 with race cover, 127s, this pump and and e85, and want to make 1000 rwhp. made 801 rwhp with the same combo except had 96lb injectors, 17psi on e85 and 90% dc.
#142 |
Drag Week Survivor
Holley's literature says the pump is good to 18.5 volts.
#143 |
Pre-Staged
#144 |
Launchin
Would I run into any problems if the pump is mounted a little higher than my sump? I have a 69 nova with a factory style take with a sump. I was going to mount it on the floor area right behind the take (right in front of the bumper). Will this be ok?
Thanks Al. |
#145 |
Launchin
#146 |
Bumping this.
#147 |
how are you guys mounting the filters to the pump? Do they make a straight -12 to straight -10
Also has anyone ever had problems with second side not coming on? I have thought about running them together don't plan on much street driving, maybe 15 miles one way couple times a month. |
#148 |
ls1 s/s notch on 28s
aeromotive makes a straight -12 orb to -10 orb union..its a bitch to find though when searching..i priced it with the reducers and using hose between and it came up to the same amount as just buying 2 of the fittings below and just connecting the pre,pump and after filter as one.
here you go http://www.jegs.com/i/Aeromotive/027...rentProductId=
Tony laino Last edited by Suicidal Racing; 06-10-2014 at 07:03 AM. |
#149 |
I'm sure race part solution has that fitting too. Prolly cheaper.
1980 Chevy luv truck Stock 6.0 Twin turbo Holley efi Circle d converter True street truck |
Advertisement |
#150 | |
Drag Week Survivor
![]() Quote:
You could just use a normal male to male union and us AN o-rings. The radius fitting is a little friendlier to flow. |
Thread Tools | |
Display Modes | |
