BW S480 who has used them and what hp #s - Page 7 - Yellow Bullet Forums
Old 02-16-2012, 11:56 PM   #91
Collinsautomotive
Default Re: BW S480 who has used them and what hp #s
Quote:
Originally Posted by LilJohn View Post
Typhoon
getting ready to put a pair of those on a 540 with the cast bw wheel.
Im liking what you say about the backpressure.
Doesnt look like that 2400 hp target will be too hard to hit.
if it don't make 2400hp, you fucked up
Henry Ford, on the stock market
Quote:
"As betting at the race ring adds neither strength nor speed to the horse, so the exchange of shares in the stock market adds no capital to business, no increase in the production and no purchasing power to the market."
Old 02-16-2012, 11:59 PM   #92
LilJohn
LilJohn's Avatar
Lol very true.
With a 9.5:1 540 wearing brodix headhunter heads.... Im hoping it uses every ounce of air the turbos have to offer and makes closer to 2600.
888-583-4408
www.LilJohnsMotorsports.com
[email protected]
Dealer for Brian Tooley Racing, Bullet Cams, Comp Cams, Borg Warner, Garrett, Forced Inductions, Callies, Wiseco, Billet Atomizer Injectors , Ultimate Converter Concepts, and many more.
Some men want the glory of being like John Force. Me, I wanna be Austin Coil.
Like us on Facebook:
https://www.facebook.com/?sk=nf#!/Li...sportSolutions
LilJohn is offline   Reply With Quote
Old 02-17-2012, 01:42 AM   #93
PuRpS
FUCK TONS OF FUN
PuRpS's Avatar
Garage
Bullseye S480R (1.32 rear) we made 964hp & 810ft @ crank 355ci iron headed holden engine @ only 18psi @ only 6500rpm it would make a lot more but a stock block aint going to take that also non intercooled just watermeth kit kicking in at 7psi
The #2 Dart Fan boy
PuRpS is offline   Reply With Quote
Old 02-17-2012, 06:38 AM   #94
boostedbowtie
boostedbowtie's Avatar
Quote:
Originally Posted by billycart View Post
The mais are going to fail at some point ..
Mine did , but caught it before it destroyed the motor .
boostedbowtie is offline   Reply With Quote
Old 02-18-2012, 07:39 PM   #95
Typhoon1600
Launchin
Typhoon1600's Avatar
Quote:
How many runs did you get on the combo before you caught it? Were you at 4,400#?
The Bullseye BatMo83 is a real nice piece...with the T6 -VFL housings David has, they can make some serious steam!
[email protected]
Typhoon1600 is offline   Reply With Quote
Old 02-18-2012, 08:16 PM   #96
boostedbowtie
Yea 4400lbs . Not sure how many passes it had , but it was around two years with the turbo and 3 years before that on the blower . The blower made about 750 to 800 hp .
The only reason I even knew the main had failed was because I broke a distributor gear , and decided to pull the motor and look things over . Also found that the Probe pistons I was using were also not up to par .
What are VFL housings ?
I wanted to go stainless , but man , it really drives the price up . Especially with the 87mm wheel .
Old 02-18-2012, 08:59 PM   #97
Don Lamana
Don Lamana's Avatar
Just dynoed my 339 sbf 80mm, s480 1.32ar, t6, th400, and made 955rwhp @ 22lbs. with 45lbs of back pressure.
Don Lamana is offline   Reply With Quote
Old 02-18-2012, 09:18 PM   #98
Typhoon1600
Launchin
VFL - very fucking large!
[email protected]
Old 02-18-2012, 09:25 PM   #99
Don Lamana
Don Lamana's Avatar
http://www.youtube.com/watch?v=sqUBCuBvnnQ
Old 02-18-2012, 11:19 PM   #100
Collinsautomotive
Quote:
what size exhuast ? which turbine wheel, I assume the 96mm
Old 02-18-2012, 11:39 PM   #101
Don Lamana
Don Lamana's Avatar
Quote:
87/96 turbine wheel
Old 02-19-2012, 12:59 AM   #102
Collinsautomotive
87/96 turbine wheel
This thing got enough downpipe on it ? where did you measure your backpressure at ?
Old 02-19-2012, 09:01 AM   #103
Don Lamana
Don Lamana's Avatar
have a 1/8" bung in the downpipe. The downpipe is 4"
Old 02-19-2012, 11:49 AM   #104
n8secstangg
n8secstangg's Avatar
i thought that housing was 5"?
ULTIMATE STREET PROJECT..... GAME ON!!!!....OOPS....game off I guess
363" TFS High Ports,EFI, M1 and an S480
[email protected] and [email protected] on drag radials
NOW A DEALER FOR
Kaenen Composites
Champion Wheels
Big Stuff 3
Lightning Force Performance
NLR Systems
Racecraft Inc
Speedwire Systems
n8secstangg is offline   Reply With Quote
Old 02-19-2012, 12:09 PM   #105
388Tweek
Spooled up
388Tweek's Avatar
See sig. This was at 3250lbs on ~10lbs A/A IC, 1.32 hot side shifting at 7K. It was lean too cause I ran out of injector(50lbs). I plan on trying E85 this year and see what it does on the same boost level.
1982 Camaro - 388SBC - Electromotive TEC3 - S480.
Best 1/8 mile - [email protected] on 275 MT DR's
388Tweek is offline   Reply With Quote
