#31 |
Pre-Staged
I'm seriously interested in this discussion as well. Building a 408w powered mustang street car with a pair of 6766's on e85. I've been on the fence on wether or not to run a A/w setup or injection.
91 LX hatch 408w turboless twin turbo hoping for an 8sec daily street car! Ford Romeo Engine Team |
Sponsored Links | |||
Advertisement |
#32 | |
Burnout box
![]() Quote:
#33 |
Burnout box
The car has to be able to run 5.40s or quicker 1/8th miles at 3300lbs with intercooler or 3150lbs without
#34 |
Burnout box
The car has to be able to run 5.40s or quicker 1/8th miles at 3300lbs with intercooler or 3150lbs without. My current setup is with an Air-to-water with 160lb injectors with 8-10 psi running 6.00s in the 1/8 at 115-120 mph with 110 octane fuel. Can push it to 25 psi With current fuel and should take me from the 700hp range at now to the 1000+ range but if can ditch the intercooler I can drop 150lbs on the car in the class rules so will help out a great deal. If nothing else if keep the intercooler how much hp and tq gain is it to go to E85 roughly if know. Thanks!
#35 |
Burnout box
Just called Wolf Racing and they said they have never run E85 in their turbo car. Methanol is what they run with no intercooler. No intercooler was not recomended at high boost but they do not have experience with E85 so no real recommendations on it.
#36 |
Launchin
talking about ethanol.
even, if your losing 20-50hp it might be worth considering, but anything more than that, i don't know. interested to see just how much of a change it makes with and without.
Coming Soon: Outlaw 10.5 Daytona with an E98 drinking 4.6L 4V Ford Modular DOHC V8 and Twin Precision PT7675 turbo's! 2014 Goal: get the cunt out racing! |
#37 |
Member
Pullin gears
Sorry just seen the Meth monster in your sig, so wasn't sure if you were talking meth or ethanol! I think a air to air with short piping is the way to go not much wieght and drop the IAT pre injectors.
1997 Talon 3250Lbs Best ET 9.6 Best Mph158 2009 VOI Edition Viper [email protected] |
#38 | |
Launchin
![]() Quote:
we were thinking possibly just for racing, bypass the I/C and go direct saves 20ft of pipework ![]() less pipework should see it at least spool slightly faster and have a better throttle response.
#39 |
Bump...
I have tight space on my new build and am thinking of ditching the air to water intercooler. Not having to chase ice down, draining/filling, and the extra weight would be a plus. Car will be running E85, BS3 and around 25# - 30#. Thinking of running methanol on the inlet pipe, but then started thinking why not pull out a couple pounds of boost and run a 50 shot of nitrous. Should provide plenty of cooling and jump the tq up. Thoughts?
![]() Twin Coyote In The Works...... Old set up "TwinBullitt" 281ci mod motor [email protected] on E85 http://www.youtube.com/watch?v=wyQdmMCHlmw |
#40 |
Mark55 is only guy I know that ran with and without an A/W IC on his BBC Twin Turbo Drag Boat. He would be the best person to contact about this.
I can only speak in terms of my car.....which is most street car..but I run a 418 with an mid sized 88mm S400 and it makes great power. In a 3500lb car it runs just shy of 150mph on a 17" tire only seeing 20PSI. The inlets are freaking as it pegs the IAT sensor at 255 within 2 seconds of WOT. This was my 3rd season running the car with no IC on E85 and have had no issues.
#41 |
That inlet temp would bother me, especially when making around 1200rwhp.
I am up in the air on this one. I would think a wet 50 shot would work good, nitrous exits the bottle around -140*, and being wet with E85 would cool it even more.
#42 |
It will take more than a 50 shot to get air temps cooled down!!! Now on a 50 shot the car will pick up but from what we have seen it takes 150-200 worth of nitrous to get the air temps to come down........ Good luck....
Auston Pasquith ACP Performance & Custom Fabrication Hot Springs, AR. Custom manifold porting/EFI conversions Dealer for: Induction Solutions/ Woody's Pluming/Jerry Bickel Race Cars/RJ Race Cars/Race Parts Solutions/Hyperformance/BTE-Memphis Performance/Strange Eng./FAST Fuel Injection/Schoneck Composites and more! |
#43 |
you cant really go by what the iat sensor is reading on a efi setup.. the sensor is before the air is seeing the e85.. measure that air temp at the intake valve where its getting mixed with e85 and i bet its alot lower than what the sensor is seeing..
70 duster turbo street car https://www.yellowbullet.com/forum/sh...6eb2c&t=932290 |
#44 |
Great point. I have always said who cares wat IAT shows...what is the combustion temp showing....I'm gonna do EGT's soon to try to understand what is going on.
Advertisement |
#45 |
So you guys think a methanol kit would have a better cooling affect then nitrous?
Thread Tools | |
Display Modes | |
