8.8 with stock 28 spline axles: What are you getting away with at the track and how? - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Rearends and Differentials - Mark Williams Enterprises
Old 10-31-2019, 03:45 PM   #1
jbtautoman
Spooled up
Default 8.8 with stock 28 spline axles: What are you getting away with at the track and how?
This is not a thread to convince me to run 31 or larger spline axles.
This is a thread to find out what people are doing with 28-spline axles in an 8.8, and how they're doing it. Low horsepower, big power? Transbrake, footbrake? Tightened posi, welded diff, or mini-spool? Typical 60ft and et's you get from it?
Let us know. Thanks.
jbtautoman is offline   Reply With Quote
Old 10-31-2019, 06:59 PM   #2
ulev1st
Member
Pullin gears
ulev1st's Avatar
Default Re: 8.8 with stock 28 spline axles: What are you getting away with at the track and h
If you shock them real hard like a sticky tire clutch dump/transbrake launch with more that 300 hp it's gonna let go. Roll into the power and don't shock them and they will last for a little while ...if the stock diff doesn't go first.
Don Spahr
Older than dirt and just as smart!
Not a real racer...that shit costs TOO MUCH!
There I was, minding my own business...when all of a sudden.........
ulev1st is offline   Reply With Quote
Old 11-03-2019, 01:42 AM   #3
juiced coupe 78
juiced coupe 78's Avatar
I've been upper 6's with stock axles. Automatic, foot brake car. Mid 1.5 60'.
The axles weren't what failed on mine. It was the cross pin and spider gears. It stayed together through the pass but locked up on the return road. The broken cross pin caused the differential to break the cap, so I had to get another housing (didn't trust that one).
Replaced it with new housing, spool, and 35 spline axles.
juiced coupe 78 is online now   Reply With Quote
Old 11-03-2019, 01:02 AM   #4
Lumbergh
Lumbergh's Avatar
3500lb 460hp stick car on slicks, launching at 5k twisted the splines after 15 launches, didn’t break them but killed the spiders in the stock diff.....
Fuck you Greta!
Lumbergh is offline   Reply With Quote
Old 11-21-2019, 06:20 PM   #5
Camaropwr
Member
Pullin gears
Camaropwr's Avatar
Default
Ran mid to high 10s. 1.5 60' at about 3400 lbs on stock GM 28 spline. Assumed I was pushing my luck.
Can say I had buddies running low to mid 9s. 1.3xx 60' on stock 28 spline axles. Probably closer to 3100 lbs turbo ls. Would get a few track days before the 7.5" 10 bolt ring gear would get pissed or snap an axle. Usually ring gear would go first, but 10 bolts were almost free.
Only problem is there's a good chance it takes out the trans when you break an axle, that and the engine is on the rev limiter.
Camaropwr is offline   Reply With Quote
Old 11-21-2019, 07:07 PM   #6
fast89stang
Member
Pullin gears
fast89stang's Avatar
Went low 1.4, high 1.3 60fts I think it was. Running 6.4s to 6.5s at 2935lbs. Footbrake car.
92 coupe 364, FTI cam, stock heads, stock shortblock. Pro Systems 950hp , Vic jr intake, BTE converter, turbo350 trans, 4.30 gear. [email protected] 1.24 60ft
fast89stang is offline   Reply With Quote
Old 11-22-2019, 11:45 AM   #7
ndmp40
I twisted the stock 28 splines on a stick 350hp lightweight mustang on Hoosier dirt boss tires.
ndmp40 is offline   Reply With Quote
Old 11-22-2019, 12:44 PM   #8
Blown38
Launchin
Blown38's Avatar
Same exact thing happened to us. But we were probably running 12s maybe high 11s in the 1/4 at 4300lbs back then.
Now have a detroit locker with 31 splines and 1.4x 60s at 4200lbs.
Blown38 is offline   Reply With Quote
