Foxbody lower bar angle? - Page 2 - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Stock Suspension
Old 10-13-2019, 02:03 PM   #16
midniteta
midniteta's Avatar
Default Re: Foxbody lower bar angle?
MOved lower of rear bar down 1" for this race. Track looked very sketchy as we had a lot of rain the day before and it was 35 degrees the night before the race. Sun came out and after first qual in pro they announced super pro to do burnouts past he start line for rubber. Car never spun like it did before but not much separation in rear yet. Car went a pb of 6.06
midniteta is offline   Reply With Quote
Old 10-22-2019, 05:16 PM   #17
fast89stang
fast89stang's Avatar
Maybe your shocks are doing their job too well if its not separating with more AS?? But congrats on the new best.
92 coupe 364, FTI cam, stock heads, stock shortblock. Pro Systems 950hp , Vic jr intake, BTE converter, turbo350 trans, 4.30 gear. [email protected] 1.24 60ft
fast89stang is offline   Reply With Quote
Old 10-24-2019, 11:43 PM   #18
midniteta
midniteta's Avatar
Man I wouldn't think that would be it. Im leaving really soft I think yet. 3500 rpm is the 2 step. Could go as high as almost 6. Maybe try and raise it once and see. The harder we hit it the more it will want to extend.
Old 10-25-2019, 02:22 PM   #19
fast89stang
I leave at about 28-2900, but no 2 step, just footbrake
Old 10-25-2019, 06:50 PM   #20
midniteta
midniteta's Avatar
Hell maybe ill lower it one more notch and see what happens. Lower bar in the rear that is. Worse case is it doesnt work.
Old 10-25-2019, 08:05 PM   #21
rick90lx
rick90lx's Avatar
What kind of brackets do you have on your rear end that gives you the adjustability? My lowers are also parallel the the ground and the uppers are angled down at its current ride height.
383
S480
225 highports
Super Vic
Extreme automatics TH400
UCC converter
Holley Dominator EFI
rick90lx is offline   Reply With Quote
Old 10-25-2019, 08:17 PM   #22
midniteta
midniteta's Avatar
I run these on rear end lowers
http://www.teamzmotorsports.net/Weld...-icb-8.8-w.htm
I also run this on the upper front mount. Tore the upper off frame earlier this year. https://wildridesracecars.com/shop/f...placement-kit/
Have UPR upper and lower control arms and solid heim joint in upper mount on rear end.
Old 10-27-2019, 05:11 PM   #23
rick90lx
rick90lx's Avatar
Those are both nice pieces. I've looked at the wild rides stuff several times. I wish I would have done the uppers like that before I welded them all up. Now it would just be a real pain to remove.
383
S480
225 highports
Super Vic
UCC converter
Old 10-27-2019, 09:39 PM   #24
Suicidal Racing
ls1 s/s notch on 28s
Suicidal Racing's Avatar
ask gray86hatch about his 8.8 lower ones https://mafracing.com/mustang-suspensions.html
Tony laino
Suicidal Racing is offline   Reply With Quote
Old 10-27-2019, 11:03 PM   #25
rick90lx
rick90lx's Avatar
Thanks, will do.
383
S480
225 highports
Super Vic
UCC converter
