Has anyone here successfully tuned EFI Stack Injection? - Page 11 - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Fire your bullets!!! > Hot Rod - Nostalgia - Gasser
Hot Rod - Nostalgia - Gasser Talk about Hot Rod/Nostalgia/Gassers. Trash talk is allowed. Use common sense when posting..
Old 08-31-2017, 09:17 AM   #151
a468bu
Spooled up
a468bu's Avatar
Default Re: Has anyone here successfully tuned EFI Stack Injection?
Brand new manifold, it does have a manifold under the intake tapped to each runner for the map signal
a468bu is offline   Reply With Quote
Old 08-31-2017, 01:16 PM   #152
Geerbangr
Geerbangr's Avatar
Ok so you do have a plenum under the intake. No iac...hmmmm. Seems pretty important to me being that the ecm is going to constantly making adjustments. How about an air temp sensor and coolant sensor? Also who did the conversion? I'm plumbed out of the plenum for the map AND the iac. I'm not sure how mixing a mechanical feature in with the ecm would work. Even setting the blades correctly the ecm is going to manage a/f at idle. Once again I'm not familiar with holleys program. How does the ecm control idle air? The standard 2 thou on the blades may need to be changed with holleys program, idk.
November 8, 2016, Redemption Day!!
Oct 6, 2018, Restoration Day for the law of the land!!
Geerbangr is offline   Reply With Quote
Old 09-01-2017, 07:52 AM   #153
a468bu
Spooled up
a468bu's Avatar
I believe I have figured it out. It all was all throttle plate adjustment. They need to be closed. They need to be adjusted when the car is Hot. But right now as the car cools down they stick in the bores. So they car will have to warm up until your able to drive it. I have no done a cold start yet with them adjusted this way, so we will find that out today. I am also probably going to cut the shafts in half and get the adjusters Hilborn has on their setup. I was told .002 clearance but that's for mechanical injection not Efi. There is no IAC on this setup and idles fine when warm, but this cold start may be an issue which I could see having a Iac would be handy.
Old 09-01-2017, 01:44 PM   #154
Geerbangr
Geerbangr's Avatar
Quote:
There's a lot of finesse into getting these units to perform properly. Are you for certain it's all blades sticking when the engines cold? Maybe it's just 1?? Personally I'd pull 1 blade at a time until I found the culprit or culprits then pull the shaft and do a light hone on that hole or holes. I'm pretty much confused on this holley system. What makes it idle? The map and a/f reading? And this setup has no air temp sensor?
