Seam sealers adhesives - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Auto Body and Paint
Old 08-21-2019, 07:43 AM   #1
outlaw56
outlaw56's Avatar
Default Seam sealers adhesives
There have been many questions on what to use on sealing floors, trunks, or wheel tubs.
I've been using DOW U418 urethane window adhesive in a regular caulk tube for under 10 bucks a tube. Goes on nice and self levels.
56 Belair, 525 F2, C&S carb on corn, CS1 4spd
outlaw56 is offline   Reply With Quote
Old 08-21-2019, 08:48 AM   #2
NuKidOnDaBlock
Default Re: Seam sealers adhesives
Loctite PL3X Adhesive works great for $5.00 a tube, probably a bit more flexible then the urethane window sealer.
https://www.homedepot.com/p/Loctite-...0595/202020473
NuKidOnDaBlock is offline   Reply With Quote
Old 08-30-2019, 09:57 AM   #3
FRANKTHECRANK
FRANKTHECRANK's Avatar
One thing I recommend is to think about whether what you are caulking is going to be painted or not. Many sealers, like silicone based but not just those, are not paintable. Paint will repel from them as you're applying it, or will just flake off later if it does cover in the first place.
I am an automotive painter because I don't mind hard work. If I wanted to do something easy, I'd call your sister.
FRANKTHECRANK is offline   Reply With Quote
Old 09-19-2019, 07:34 AM   #4
outlaw56
outlaw56's Avatar
Yes Frank the Dow can be primed or painted. I would post pics if this site was more user friendly.
