what should the no prep rules be for small tire cars? - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Fire your bullets!!! > Grudge, No ET and No Prep Racing
Grudge, No ET and No Prep Racing Talk about Grudge and No ET racing. Trash talk is allowed. Use common sense when posting..
Old 11-14-2016, 02:18 PM   #1
chriscrna
chriscrna's Avatar
Default what should the no prep rules be for small tire cars?
I get a backhand car should be allowed in small tire stuff due to the stock suspension being just as good or better. But, how about 3/4 double frail rail chassis. Where should it stop. I have a true back half car with stock floors from back of seat forward and know what it weighs. I can only imagine what a 3/4 chassis that is stock just forward of firewall weighs
chriscrna is offline   Reply With Quote
Old 11-14-2016, 02:34 PM   #2
Bacarty2
Default Re: what should the no prep rules be for small tire cars?
should be weight and tire size....
Bacarty2 is offline   Reply With Quote
Old 11-14-2016, 08:00 PM   #3
chriscrna
chriscrna's Avatar
I don't think straight up weight is doable right now. There are a ton of people who wouldn't race if weight was mandatory. A lot of people get in and go racing. On a true no prep people aren't coming in tin canned and doing well. You really have to add weight. I think a stricter back half rule would keep the 3/4 tube chassis carbon front to back cars out
Old 11-14-2016, 10:47 PM   #4
83mc406
83mc406's Avatar
Our AZ No Prep tire rules. 28x10.5 or smaller no full fiberglass unless OEM (Corvette). Fiberglass hoods door trunk ok. Working head and tail light. No decals on body. Not a fan of full tube chassis in class but its not a deal breaker.
83mc406 is offline   Reply With Quote
Old 11-14-2016, 11:34 PM   #5
VanillaGuerilla
VanillaGuerilla's Avatar
Enforcing weight is class racing.
If you are in a group where the only limitation is tire then boom. There's your rule, nothing else needed.
If it's supposed to be a small tire street car race then yes, tire size, stock suspension and frame rails should be the main rules and add any from there. I raced in Chicago KOTS, they have 3 groups of cars and rules to keep things in order, it works GREAT
VanillaGuerilla is offline   Reply With Quote
Old 11-14-2016, 11:52 PM   #6
chriscrna
chriscrna's Avatar
Well a true backhalf should be able to run with the "stock suspension" cars. The full tube stuff should be limited to big tire.
Old 11-15-2016, 07:11 AM   #7
VanillaGuerilla
If my leaf spring car vs your back half is all cool then why shouldn't your back half be able to run tube stuff? At a no prep stock style front suspension could actually be better than a strut with little travel.
I don't actually care but that's one argument that could be made
Old 11-16-2016, 01:50 AM   #8
z289sec
z289sec's Avatar
So, you would exclude some X275 legal cars from running small tire? My car is legal for X, has a modified factory rear frame rail, in the stock location, stock floorpans from the b pillar forward, stock firewall, and stock type suspension, but the rules allow moving the rear leaf springs. It is also a tube car though, with a "bolt in" Smith tubular front end.
RTCTTFMF!!!!
Stock suspension 67 Camaro
565 Conventional head BBC with fogger and a plate on 275's
Just about done
Texas Racewerks, Sanger, Texas
Nyes Automotive Racing Engines, Muncie, Indiana
FTI Converters and Transmissions, Deland, Florida
ACE Racing Transmissions, Garland ,Texas
z289sec is offline   Reply With Quote
Old 11-16-2016, 11:12 PM   #9
1969dart
1969dart's Avatar
agree^^^^^
recommendation:
stock firewall and floor back to "B" pillar or rear of cab for trucks
2x3 square tube back half or OEM frame (no chassis cars)
steel rear quarters and roof for cars and steel roof and bed sides for trucks (other then OEM glass or aluminum vehicles)
All the BS pro-mod top sportsman cars need to be put into another class--then they can decide if they want small or big tires themselves.
1995 S10 421 sb glide 4 link 33x18.5x15 street drive
1986 Mustang 5.0 / 5speed convertible 36K 2nd owner
1974 Nova Hatchback 383/ TH350/ 12 bolt 4:11
soon to be 4 speed car
Wanted 4 SPEED PEDAL ASSY Nova/Camaro will work.
1969 Dodge Dart 340 swinger
1969dart is offline   Reply With Quote
Old 11-17-2016, 08:16 AM   #10
chriscrna
chriscrna's Avatar
Originally Posted by 1969dart View Post
agree^^^^^
recommendation:
Thee 2x3 back half is maybe 75 lbs tops and no advantage suspension wise so i would't care if it was round tube. If someone is building a round tube is like a moly cage. It sells faster and holds a b it more value.
Old 12-25-2016, 01:18 PM   #11
THE STING
I agree , SS or true back half only and a tire rule is all ya need for no prep...keep it simple.
(aka AMC Boyz) Rob.
THE STING is offline   Reply With Quote
Old 12-26-2016, 07:23 PM   #12
Mr Z
Mr Z's Avatar
DADS is a prepped track an the other is NO Prepp ! one weekend a month of badass Heads Up Drag Racing, pick your poison !
Mr Z is offline   Reply With Quote
Old 11-15-2016, 12:31 AM   #13
shadys281
At an actual no prep a consistent 4.80-5.00 car will go to a lot of finals.. Was pitted next to a guy with a new gen with 540" BBC with twin 94's and it was running 5.00's at 160 with one 4.88 at 175 when he got on the oh shit button at the 60'.. Lol He was pretty cool and since we were in a different class he wasn't tight lipped about what it was running..
shadys281 is offline   Reply With Quote
Old 11-15-2016, 08:50 AM   #14
chriscrna
chriscrna's Avatar
They can make up for the short travel with 300lbs over the tires and still be under 2500 with driver. My backhalf still has stock floors, 100% stock everything but rear suspension. Stock front subframe, doors etc. It is just a backhalf. My point was this backhalf stuff is just that a backhalf.
Who says u have to have no travel on a tube chassis
Old 11-15-2016, 09:36 AM   #15
VanillaGuerilla
Strut front ends typically travel less than what you can get a lot of the stock style front suspension to do.
I see your point, just because you have a back half doesn't mean it's a full on race car. Around here we'll run small tire ladder bar cars with SS cars all the time
