Intake air temp - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Supercharged
Old 06-04-2019, 09:57 AM   #1
jstahemi119
Default Intake air temp
I went to the track this past weekend.It was in 80's with high humidity.The intake air temps were reaching 185*.
My question is,,,,at what IAT will the power be effected and start falling off??
AFR was 13 @ wot.I have a 1071 BDS roots and after a few passes I increased the boost from 6 to 8 to 10 and the MPH only increased 3 MPH
I have been 9.3 @ 146 with 6 lbs through the 4 inch exhaust and it was choking with reversion.This weekend I uncapped the dumpers and hoped the crack the 8's but couldn't get faster than 9.6 with 10 lbs of boost. That was 28* timing and 13 @ wot.
Engine is a 545 2nd gen hemi with fueler aluminum heads.
I was rather disappointed!
jstahemi119 is offline   Reply With Quote
Old 06-04-2019, 02:37 PM   #2
Ron Clevenger
Default Re: Intake air temp
Carbs.....or ??
Creekside Racing Ministry...John 14:6
Now testing new Travis Quillen Motorsports Engineering Methanol boost referenced high pressure MFI system
Easy tune and killing power......6.02 @ 229 ([email protected])
Steve Morris www.stevemorrisengines.com
Ron Clevenger is offline   Reply With Quote
Old 06-04-2019, 03:56 PM   #3
MOPARJAKE
Originally Posted by Ron Clevenger View Post
Carbs.....or ??
Pair of SV1 carbs like 1800cfm.
MOPARJAKE is offline   Reply With Quote
Old 06-04-2019, 06:01 PM   #4
427f2
427f2's Avatar
3-4 tenths vs. a cool low humidity good weather day pretty easy if it
will take the extra power.
427f2 is offline   Reply With Quote
Old 06-04-2019, 08:09 PM   #5
Ron Clevenger
"Choking with reversion" what does your cam look like?
Old 06-05-2019, 11:00 AM   #6
jstahemi119
Valve timing @ .050 int open 19 btdc, close 65 abdc
ex 71 bbdc 25 atdc
Dur @ .050 int 264,,ex 276
Lobe sep 113
Old 06-05-2019, 11:29 AM   #7
jstahemi119
Ron the reversion was with the 4 inch exhaust system with tailpipes out the rear bumper.
Old 06-06-2019, 12:28 AM   #8
Ron Clevenger
May be just a combination of parts not working well together. You didn't say which fuel heads, but suspect ports are pretty good size for what your doing. Just my thoughts.
Old 06-06-2019, 06:12 PM   #9
SAMMY CHRISTIAN
SAMMY CHRISTIAN's Avatar
about 20* short on both, can't imagine it's going to do well.
SAMMY CHRISTIAN is offline   Reply With Quote
Old 06-06-2019, 10:15 PM   #10
jstahemi119
Car is street driven over 1000 miles a season. If I can get to the track 4 or 5 times a year I'm happy. Have the valve covers off to leak it & do a compression test.
If I had that 20* would it still survive through the tailpipes?
Old 06-07-2019, 04:59 PM   #11
Ron Clevenger
With the Fuel heads it's already hurting for street use. Motors just not gonna be happy.
Old 06-08-2019, 12:55 PM   #12
jstahemi119
I am quite happy with the street manors,I was disappointed with my last trip to the track.The heat and humidity was high,the N/A guys were of 3 tenths and I couldn't get over 140 MPH when I should have cracked 150.
I'm going over to the garage and leak it down and do a compression test. Imight even take the springs off and see if they are going soft on me.........
I just have to think it was the weather as it has gone 146 MPH throught the tail pipes.
https://www.facebook.com/dan.tomchik...2759128164427/
Old 06-08-2019, 06:39 PM   #13
Taff
Taff's Avatar
Why is your total timing at WOT only 13 degrees? Seems very low to me. Afr would be quite a bit richer too if it was mine.
Taff is offline   Reply With Quote
Old 06-08-2019, 07:27 PM   #14
jstahemi119
13 was the AFR,timing was 28*
It sure wasn't 70* LMOL
Old 06-08-2019, 10:54 PM   #15
427f2
427f2's Avatar
Cool Car sir......thanks for the vid.
I would not overthink it until you get to run on a decent weather day.
I have seen air temp and humidity kill some substantial power
on my boosted cars.......more so than NA applications IMO.
