Compressed air line piping again. - Page 4 - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Fire your bullets!!! > Let's Talk Drag Racing
Let's Talk Drag Racing Talk about drag racing with censorship...
Old 12-02-2019, 04:14 PM   #46
vonzipper396
vonzipper396's Avatar
Default Re: Compressed air line piping again.
I dont get you guys.Black pipe is reasonably priced ,easy to put together and bulletproof.Did it in 2 full 6000sq ft body shops in 25 years and it is still all rock solid.
69 camaro,3550#,n/a525,liberty proshift833,9"tires,stock suspension.
10.10 136.5mph 1.44 60ft
vonzipper396 is offline   Reply With Quote
Old 12-02-2019, 04:21 PM   #47
Originally Posted by bigblockmark View Post
Did we already cover if PEX reacts with compressor oil over time and fails? Rapid Air has 15% Black Friday sale on.
number 9 is PEX
https://www.plumbingsupply.com/chemicals.html
boostedbowtie is online now   Reply With Quote
Old 12-02-2019, 05:28 PM   #48
bigblockmark
bigblockmark's Avatar
Van
Did it rust or stay nice? Going against white metal walls and ceiling. Would not want staining on the white.
bigblockmark is online now   Reply With Quote
Old 12-02-2019, 06:41 PM   #49
bottlefed1
bottlefed1's Avatar
They are scared it will eat all the watermelon.....
bottlefed1 is offline   Reply With Quote
Old 12-02-2019, 06:54 PM   #50
10SEC86GT
LEADING THE FREAK PARADE!
10SEC86GT's Avatar
Originally Posted by WoundUp View Post
Because these days people have more sense than to use pvc why create a liability in your shop when you don't have to?
As I stated earlier, we have sch 40 pvc in our shop. I started working there 2 months after they moved into the building back in 1999. It was in the building before we moved in. Other than cutting and adding to it, it has been flawless.
Norman Henson
10SEC86GT is offline   Reply With Quote
Old 12-02-2019, 07:13 PM   #51
markadams
markadams's Avatar
Van
Wipe it down and brush on a coat of black rustoleum. I did that for my out door gas lines and they turned out very nice.
Big THANKS to:
Trend Performance, LGM Racing, Ferrea, Holeshot, Deist, Mallory, Valvoline, Innovate Motorsports, Stroud, BTE, Ultimate Converter, Davis Technologies, VP Racing Fuels, Fluidyne, Redhorse, Chiseled Performance, PSI Springs, Randy's Ring and Pinion, Comp Cams, Sonnax, Probe, Chris Alston Chassisworks, Borg Warner, The Driveshaft Shop, Mittler Brothers, NLR, CFM, Tial, Weldon, Currie, CSU, Titan, Milodon, Melling, Firecore50, Cloyes, Naylor Racing Engines, SCE Gaskets, ARP, BAM
markadams is online now   Reply With Quote
Old 12-02-2019, 07:16 PM   #52
Yoyodyne
Yoyodyne's Avatar
PVC is like riding without a helmet. It works fine, until it doesn't.
FWIW I call my plumber in with his threading machine, he can thread the steel pipe and have it all together and leakproof in the time it takes me to cut the material to length and climb the ladder. I have steel pipe in a 35X100 building full of machines and hose drops, the oldest part of the system is over 50 years old.
Yoyodyne is offline   Reply With Quote
Old 12-03-2019, 12:42 AM   #53
bigblockmark
With galvanized would not have to even paint it. I would think a filter at every drop would prevent issues with flaking?
The Fast Pipe system has 20' lengths of aluminum pipe but has non metallic fittings. The Rapid system has metal compression fittings but only comes in rolls of tubing you have to try to straighten.
Old 12-03-2019, 12:58 AM   #54
markadams
markadams's Avatar
Mark, you might be over worried about the flaking. I've done dozens of paint jobs in my shop with galvanized air lines over several years with no issues. No filters either. I do have a refrigerant dryer though for moisture.
Big THANKS to:
Old 12-03-2019, 01:09 AM   #55
Yoyodyne
Yoyodyne's Avatar
Mine is galvanized. Zero trouble. I have lots of filters and traps on machines, have never seen debris in any of them.
A straightener should be easy and cheap to make - https://www.amazon.com/M8097-MAXLINE...09718368&psc=1
Old 12-03-2019, 11:34 AM   #56
seanss454
seanss454's Avatar
I put black pipe in my facility and never have had a leak. We put 2-220 gallon tanks in a run and then 2 industrial water/air separators and never have moisture and 6" drops every 20 ft with petcock never see moisture. Run 6 da sanders all day, 2 paint guns, 3-air hammers etc. I always liked the look of rapid air stuff but plastic fittings scare me.
seanss454 is offline   Reply With Quote
