Post up your turbocharged engine bay!! - Page 101 - Yellow Bullet Forums
Old 05-10-2011, 04:40 PM   #1501
tt69camaro
tt69camaro's Avatar
Default Re: Post up your turbocharged engine bay!!
Quote:
Originally Posted by Scotts87LX View Post
I wasn't there, but several people I know were. They all gave the same description: "super bad ass black twin turbo 69 Camaro". Sounds like you to me.
LOL, I like that description!
Drag racing is a sport you need two balls for!
www.forcedpsi.com
9.0:1 conventional headed 509 ci w/ twin 88's
3400# "Street car"= 1.18, 3.13, 4.70 @ 156.8mph
192.8mph in the 1/4 (lifting twice) 29.6#s of balls & boost
tt69camaro is offline   Reply With Quote
Old 05-10-2011, 04:47 PM   #1502
tt69camaro
tt69camaro's Avatar
Quote:
Originally Posted by jon volk View Post
Do you have fans both in front and in back of the radiators? Do you also run a glass nose that is sealed up? I have mine setup like in my sig but with the glass nose it tends to get to around 210* on hot days where previously it would only get to 175 tops. Im considering swapping the fan around to the back side to draw air from the engine bay vs the 6" of dead air behind the fiberglass.
I use a factory grill with a lexan cover to deflect bugs and stones on the street. I just added the pusher fans to go along with the pullers this year.
www.forcedpsi.com
Old 05-10-2011, 05:25 PM   #1503
jon volk
jon volk's Avatar
Cool. Let me know if they make a noticeable change
92 325i Mtech, 4.8 LS, th400.
95 M3, forged L33, 7675 CEA, TH400/Gear Vendors
[email protected] on pump gas at 3530lbs
jon volk is offline   Reply With Quote
Old 05-10-2011, 08:21 PM   #1504
JROUTLAW
Pre-Staged
Heres my old set-up with 47/88 but cars at chassis shop now gettin 25.2 and forward facing 98mm turbo and a/w intercooler with super victor efi intake and sheetmetal elbow so I will post new pics when its done.
JROUTLAW is offline   Reply With Quote
Old 05-10-2011, 10:02 PM   #1505
Scotts87LX
Collecting dust
Scotts87LX's Avatar
Quote:
Originally Posted by tt69camaro View Post
It is a streetable (tagged, licenced, power windows,etc) 509 w twin 88's. 3400 pounds. I've been to the track just a few times and have been working out the bugs. Been 5.10 and 142mph with low boost. When I try and turn it up those little bugs show their ugly faces. (trans problems) My goal with it is to eventually run in the high 6's at over 200mph in the 1/4 mile. So far it hasn't been easy to creep up on it but it sure has been fun!
Did you have that car at Jackson Dragway recently?
I was in Jackson a couple of weeks ago. Were you there?
A couple of guys who work for me were there and they were very impressed. I'd love to see that beast in person. SUPER nice looking car! What is the chassis spec? and what tire do you run?
My buddy Dean's house is only a couple of miles from the track and we do all our work on both cars at his shop. I'm there in the evenings regularly working on one or the other of our two cars.
Shoot me a PM next time you plan to go to Jackson. I'll try and stop in.
Scotts87LX is offline   Reply With Quote
Old 05-10-2011, 11:01 PM   #1506
92_foxgt
Spooled up
92_foxgt's Avatar
Here's my dd. Water meth tank on the right. Diy kit, holset hx40w turbo
92_foxgt is offline   Reply With Quote
Old 05-10-2011, 11:02 PM   #1507
MustangBilly/JunkYard302
Launchin
MustangBilly/JunkYard302's Avatar
Quote:
that is so clean..nice n custom from what i see..
MustangBilly/JunkYard302 is offline   Reply With Quote
Old 05-10-2011, 11:03 PM   #1508
Launchin
Quote:
nothn like doin it yourself...
Old 05-10-2011, 11:52 PM   #1509
Scotts87LX
Collecting dust
Scotts87LX's Avatar
Default 93LX Coupe, twin GT4708 (80mm) turbos
Here's a few pics of the twins going on in place of my old single 94mm setup.
Dean made the center of the radiator support removable. One bolt on top and one in front on each side.
Turbos with the support removed. Easy access to the oil fittings on the turbos.
I had initially planned to re-route the inlet pipe out of the engine compartment over the right front tire out in the fender well and go in through the firewall just behind the shock tower. However, I didn't realize there was a bar tieing the A-Pillar bar of the roll cage to the under side of the shock tower in the spot I'd planed to run the intercooler pipe through.
So rather than remove the bar, or go in through the cowl, I elected to use the existing route through the firewall from the old 94mm setup.
This is as far as I've gotten to this point.
The merge of the two 3" pipes into a 4" was done by cutting V's in the top of the lower pipe and bottom of the upper pipe and spreading the 3 inch pipe(s) out to form two half 4" diameters. Lots of work with a light weight body hammer and an anvil. Fit was perfect. Super tight. But contamination from the body hammer screwed up the welds. I've cut out the hand formed section and I'm replacing it with some cone shaped 4" to 3" aluminum cone reducers from Burns Stainless.
When it's done there will be an individual Big Red ProCharger BOV for each turbo.
I've also added a Gary Markwich lower valence, which will be painted to match before the car comes back out.
Here's a link to all the pics anyone could want of the car through it's various phases over the 3 years I've owned it.
http://www.streetfire.net/photo/93lx-20110326-1024x768jpg_2011233.htm
Old 05-11-2011, 08:35 PM   #1510
Broke EF
Broke EF's Avatar
An updated pic of the TA from a couple weeks back
We have cleaned it up more since this pic, and still have more to do.
Sean
I dont like it unless its flat black
My Photography: http://www.facebook.com/SmythPhotography
Broke EF is offline   Reply With Quote
Old 05-11-2011, 08:42 PM   #1511
Mach1Marauder
bye
Looks nice Sean!
Mach1Marauder is offline   Reply With Quote
Old 05-11-2011, 08:44 PM   #1512
Broke EF
Broke EF's Avatar
Thanks! It has a way to go until it is as nice as we like, but we have been more concerned with making it run than making it pretty
Sean
Old 05-11-2011, 09:02 PM   #1513
gg64ss
Member
Pullin gears
gg64ss's Avatar
Car looks good. I like the mounting of the coils.
Sheldon <><
Special thanks to-
EKR Racing
Eric Kenward Vero Beach, FL
Tim Bishop
gg64ss is offline   Reply With Quote
Old 05-11-2011, 09:09 PM   #1514
chrischabre
Launchin
chrischabre's Avatar
some insane builds here guys....Its always cool to see how others package stuff and the mentalities behind it.
chrischabre is offline   Reply With Quote
Old 05-11-2011, 09:14 PM   #1515
Mach1Marauder
bye
Yeah.........it's hard to do both at the same time Sean!
