Dump valve for powerglide - Page 2 - Yellow Bullet Forums
Old 05-16-2019, 07:23 AM   #16
3pedals
Gigity
3pedals's Avatar
Default Re: Dump valve for powerglide
Thanks for clarifying that
3pedals is offline   Reply With Quote
Old 05-16-2019, 10:03 AM   #17
tempname
Thx. I still gotta get my head around it though.
tempname is offline   Reply With Quote
Old 07-01-2019, 01:54 PM   #18
tempname
Tighter converter in, and now refining my staging and starting line method. I have the mentioned solenoid above. What size hoses are appropriate? It looks like we dump back to the pan. Do I T into one of the trans cooler lines? Which one?
Or, anyone have a picture or diagram?
Old 07-01-2019, 01:56 PM   #19
tempname
Well crap I found instructions on Summit right after I posted.
https://static.summitracing.com/glob.../fti-f4065.pdf
Old 07-01-2019, 03:33 PM   #20
Why is the T on the line IN ?
Is that right ?
Old 07-01-2019, 05:14 PM   #21
Third Gen Racer
Third Gen Racer's Avatar
Is that right ?
That way the fluide is going through the cooler before it's dumped. Instead of dumping hot fluide to the pan. Imo it probably doesn't get cooled much as fast as it most likely moving.
Third Gen Racer is offline   Reply With Quote
Old 07-02-2019, 08:26 PM   #22
Fast16Racer
Fast16Racer's Avatar
In general, heat transfer increases with increased fluid velocity. That's true on both sides of the heat exchanger, air and liquid in this case.
Fast16Racer is offline   Reply With Quote
Old 07-02-2019, 08:32 PM   #23
tempname
Could a person bleed at the servo cover instead? Just drill and tap?
Old 07-03-2019, 12:53 PM   #24
zbrown
Lol no.
You would be bleeding off main line pressure
Vbox whore FC
TT cummins
zbrown is offline   Reply With Quote
Old 07-03-2019, 01:13 PM   #25
TurboII
TurboII's Avatar
X2^^^ the servo pressure behind the cover is want is holding the band for 1st gear when on the trans brake. It would also effect the reverse servo/apply piston and probably just smoke the band and reverse clutch pack. I'm looking forward to the new Bruno-Lenco setup in the new car. It has a true converter dump that is supposed to act very similar to a clutch pedal from what I have seen. You can also manipulate the converter charge pressure to have almost 100% lockup along with what the new Pro Torque Evolution converter is capable of doing. Every setup has its faults and the powerglide has very few especially considering when and what power level it was originally designed for. The Bruno-Lenco is awesome but its huge compared to a glide. This is the first car I've had that could actually fit one since its double frame rail.
Leader of the Methanol Mulisha
KINETIC RACECRAFT
"Turning your potential into motion"
Dealer for: Haltech EFI, Billet Atomizer Injectors, ProTorque Converters
Coming Soon - 6000HP Mainline Pro Hub Dyno
Manifold EFI conversions, Fuel Hoop installation, Dry Deck Conversions, LS/LSX 1/2" Stud Conversions
Custom crimped AN hoses
"He who is without oil shall throw the first rod."
-Compressions 11.5:1
TurboII is offline   Reply With Quote
Old 07-03-2019, 06:48 PM   #26
badfarmtruck
don't forget fluid dumping across a pressure relief creates its own heat. I have plumed warm up circuit on large hydraulic systems this way.
badfarmtruck is offline   Reply With Quote
Old 07-03-2019, 09:12 PM   #27
Morris Race Trans
Morris Race Trans's Avatar
Powerglides have the pressure regulator in the valve body , so converter charge starts there. There was a patent design years ago where a solenoid was incorporated on bottom of valve body that dumped converter charge at the start. I think it was called variable stall. Anyways if you wanted to or needed to make a change why not start at the source? Solenoids have to be able to withstand high temps and compatible with the fluids your using. So seals need to be high temp.
Morris Race Trans is offline   Reply With Quote
Old 07-03-2019, 09:47 PM   #28
buda_racing
buda_racing's Avatar
Freddy Brown Variable Stall Control (VSC). I'm still using it with great results
8.2 DECK 356ci/GARRETT GEN2 98MM/GLIDE
"[email protected]"
https://www.youtube.com/user/budaracing/videos
buda_racing is offline   Reply With Quote
Old 07-09-2019, 11:20 AM   #29
93alexcoupe
93alexcoupe's Avatar
Did you just get the valve body from them or you had to send them the whole trans?
Built By Lujan Motorsports in Miami,Fl
Tuned By Errol TPS, Bullseye Power, Pro EFI SBF.
93alexcoupe is offline   Reply With Quote
Old 07-09-2019, 12:34 PM   #30
buda_racing
Complete valve body.
"[email protected]"
