Default Billet Intake Manifolds for 5.0 Coyote Applications
The new MMR Billet manifold is the ultimate in 5.0 / 5.2 engine induction for applications making 600HP and up. Perfect for Turbos, prochargers and Vortech/Paxton superchargers.
Featuring state of the art CAD design and then put to the test on the MMR dyno and the MMR Coyote Powered Pro Mods. Built, designed and tested by the World Coyote experts and record holders! The Only Manifold available proven to produce over 3500RWHP, rev beyond 10,000rpm but still spool the largest turbos with its incredible runner design that makes HUGE low end power while still unleashing HUGE high rpm power! Capable and proven to run 212+ MPH in the 1/8 mile and over 256mph in the 1/4 mile!
Features:
*100% USA Made
*100% Billet Design Pressure Tested beyond 65psi
*Multiple Vacuum ports up on rear
*Thick CNC flange uses factory O ring gaskets
*Fully O ringed to eliminate messy silicone and air leaks
*MMR Billet Fuel Rails Included
*Multiple Throttle Body Options
*BIG HP gains over ALL Factory & Aftermarket Brands
*Perfect for 600+hp Forced induction Street & strip engines
*Tapered/Tuned Runner length boosts peak performance over ALL other manifolds
*8 or 16 Injector options
*Dyno Proven CAD/CAM Design
*Airflow design Supports up to 3900hp!
*Compatible/Bolts on to all 2011-2019 5.0 and 5.2 Cylinder heads.
*Lifetime Guarantee
Clears most factory hoods (8.5" from cylinder head ports to top of manifold)
More info & order here: http://www.modularmotorsportsracing....oducts_id=1077
Manifold Upgrades
NHRA SFI Spec 23.1 Burst Panel ( +$199.99 )
Manifold Plenum Color
(Top)Natural CNC Finish
Black Anodized ( +$150.00 )
Block Deck Height
Factory / Stock
Tall Deck MMR Gen X ( +$400.00 )
# of Injectors
1 injector per cylinder
2 injectors per cylinder ( +$200.00 )
Throttle Body Flange
Stock or GT350
90mm (cable) ( +$150.00 )
Single Oval (Cobra Jet) ( +$300.00 )
Twin 90mm (available on Tall deck version only) ( +$300.00 )
Manifold Runner ColorNatural CNC Finish
Black Anodized ( +$75.00 )
www.modularmotorsportsracing.com - 2014 NMCA Champions WORLD MODULAR/COYOTE RECORD HOLDER 3.72 @ 212 1/8 & 5.80 @ 256.3 - Worlds Fastest Modular Mustang (non tube chassis) 6.75 @ 219.74 Worlds Fastest Modular on 10.5's - 3.95 @ 196 1-877-MOD-POWR.
